答复 答复 转发 Android DFU library.msg
Hi!We used a 52832 to make a bracelet. Now some apps on Huawei phones can't be remotely upgraded by the ring. We have verified that Nordic's official Android DFU library throws a bug in the firmware upgrade. Therefore, during the upgrade process, whether the mobile phone is sent incompletely or the wristband is not completely received, our APP cannot be detected here.Before using nRF Sniffer to capture packets, there is no data during the upgrade process.Before using nRF Sniffer to capture packets, there is no data during the upgrade process.Above have our software testing environment, please check.
According to the log of nova 2s combined with the DFU library code analysis, the following is the error when the data is verified.
The error is as follows:
Sending Calculate Checksum command (Op Code = 3)
08-27 11:38:24.029 1637 1802 W bt_btif : HAL bt_gatt_callbacks->client->notify_cb
08-27 11:38:24.030 7911 8203 I DfuImpl : Checksum received (Offset = 256, CRC = 975ECD47)
08-27 11:38:24.030 7911 8203 W DfuImpl : 3840 bytes were lost!
08-27 11:38:24.031 7911 8203 I DfuImpl : CRC does not match! Expected 491D1F48 but found 975ECD47. Retrying...(3/3)
The program sends the data three times and reports the same error.
The judgment is that the receiving firmware data is incomplete and the upgrade fails.
Is DFU lib usage problem or data compatibility issue? Is there a solution?
Thank you for your reply!
