I need to have connection status at the application level (IOS).
I'm working with the example "light switch server proxy" where the heartbeat profile is working.
In the IOS application I have already implemented the message "heartbeat publication set message". With this message I can have my embedded module send its status periodically to 0xFFFF (all nodes).
But the application does not receive the return status. I receive a unique return status when I configure the publication of the heartbeat.
Is it possible to configure the node to send the heartbeat value to the ios application ? It seems that the application is not in the destination nodes
My current step is :
1. Configure the node with " CONFIG_OPCODE_HEARTBEAT_PUBLICATION_SET"
2. On the node in heartbeat.c ->
static void heartbeat_publication_timer_cb(timestamp_t timestamp, void * p_context) is called periodically.
3. On the app in AccessMessageParser I added the status in the switch case. But no status comes after the configuration.
Thank you very much.
