Hi
I am trying to install the SES toolchain on my PC (Win 8.1) following exactly the nRF Connect v3.2.0 Getting Started Assistant. When trying to "Open nRF Connect Project..." into SES 4.20a I get the following prompt:
CMakeError.log
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed. Compiler: C:/work/gnuarmemb/bin/arm-none-eabi-gcc.exe Build flags: Id flags: The output was: 1 c:/work/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): In function `exit': exit.c:(.text.exit+0x2c): undefined reference to `_exit' collect2.exe: error: ld returned 1 exit status Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed. Compiler: C:/work/gnuarmemb/bin/arm-none-eabi-gcc.exe Build flags: Id flags: The output was: 1 c:/work/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): In function `exit': exit.c:(.text.exit+0x2c): undefined reference to `_exit' collect2.exe: error: ld returned 1 exit status
CMakeOutput.log
The target system is: Generic - 1.14.99 - arm The host system is: Windows - 6.3.9600 - AMD64 Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded. Compiler: C:/work/gnuarmemb/bin/arm-none-eabi-gcc.exe Build flags: Id flags: -c The output was: 0 Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o" The C compiler identification is GNU, found in "C:/work/git/ncs/nrf/samples/nrf9160/http_application_update/build_nrf9160_pca10090ns/CMakeFiles/3.15.2/CompilerIdC/CMakeCCompilerId.o" Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded. Compiler: C:/work/gnuarmemb/bin/arm-none-eabi-gcc.exe Build flags: Id flags: -c The output was: 0 Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o" The CXX compiler identification is GNU, found in "C:/work/git/ncs/nrf/samples/nrf9160/http_application_update/build_nrf9160_pca10090ns/CMakeFiles/3.15.2/CompilerIdCXX/CMakeCXXCompilerId.o" Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)": arm-none-eabi-gcc.exe (GNU Tools for Arm Embedded Processors 7-2018-q2-update) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907] Copyright (C) 2017 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Performing C SOURCE FILE Test toolchain_is_ok succeeded with the following output: Change Dir: C:/work/git/ncs/nrf/samples/nrf9160/http_application_update/build_nrf9160_pca10090ns/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_c7f85 && [1/2] Building C object CMakeFiles/cmTC_c7f85.dir/src.c.obj [2/2] Linking C executable cmTC_c7f85 c:/work/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: cannot find entry symbol _start; defaulting to 00008000 Source file was: int main(void) { return 0; }
There is no other output in SES Console.
The strange thing is, that the other samples such as lte_ble_gateway or asset_tracker build without problem with exactly the same setup.
I checked out tag v1.0.0 from the nrf github repo and I'm using cmake version 3.15.2 and west v0.6.2.
What is wrong with my setup or with this sample? I am stuck here.
BR, Marc
