change shared channel address when channel is open
Can I change the shared channel address (first one or first two bytes in the message) when the channel is open?
The manual says after opening the channel, send a broadcast data with the desired shared channel address in the first one for two bytes in the message.
My question is, can I change the shared channel address later by sending another broadcast data with different shared channel address in it?
Will try it on Monday, but I thought it is a interesting question to ask here.
Thanks
Will post my test result on Monday too :-)
  • Yes, it can be changed when the channel is open. I have confirmed with Nordic engineer that sending one broadcast is the only way to change the shared channel address.
