Register soc_evt_handler()
I intend to check some of the NRF_SOC_EVTS in my application. Where should I register soc_evt_handler(uint32_t sys_evt, void * p_context) function? Will this function be called by SD when one of these event is triggered in the system?
  • Hi Justin,
    you can register the soc_evt_handler in any .c file in your project with the NRF_SDH_SOC_OBSERVER macro.  The nrf_drv_clock.c driver registers a soc_evt_handler to listen for the NRF_EVT_HFCLKSTARTED event.
    // In nrf_drv_clock.c
    static void soc_evt_handler(uint32_t evt_id, void * p_context)
        if (evt_id == NRF_EVT_HFCLKSTARTED)
            m_clock_cb.hfclk_on = true;
            clock_clk_started_notify(NRF_DRV_CLOCK_EVT_HFCLK_STARTED);
    NRF_SDH_SOC_OBSERVER(m_soc_evt_observer, CLOCK_CONFIG_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    Yes, the  soc_evt_handler that is registered with the NRF_SDH_SOC_OBSERVER macro will be called when the SD forwards SoC events to the application.
    Best regards
    Bjørn
