freertos with wdt reset problem, nrfjprog
Hello
my setup is a nrf52840, the sdk15.3, Softdevice s140.
I'm running an application with freertos and wdt and have the openbootloader and s140 also flashed.
- if in freertos the wdt is disabled and i set the GPREGRET register and make a reset with NVIC_SystemReset, i have to make a reset from outside by nrfjprog -r over jlink and then the dfu device comes up...
- and after update the device over dfu it has to be reset by nrfjprog -r and it resetarts in application as wanted
- If the wdt is enabled and do the same, set the GPREGRET register and make a reset with NVIC_SystemReset, the device restarts in application....
How can i make a reset or restart similar to nrfjprog -r from software so that no jlink is needed ?
Thanks in advance
twittich
  • Hello Twittich,
    The WD timer is not reset through a NVIC_SystemReset (Reset behavior) so it will keep running on subsequent startup when the program enters DFU mode inside the bootloader.  The bootloader feeds the WD by default for this reason. But you may need to adjust the reload interval if you have a short timeout, see NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS in the bootloader's sdk_config.h file.
  • Hello
    Thank you. This i tested already but it's still the same. While debugging the bootloader at the function
    static bool dfu_enter_check(void)
    it's not entering in the following
       if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
            NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
            return true;
    the problem is at
    i'm not getting 0xb1 .  If I set this hardcoded to 0xb1 it's starting in dfu mode.....
    But in the application i'm setting it and then make a reset.
    Can I use the sd functions ?
    sd_power_gpregret_set(0,0xB1);
    sd_nvic_SystemReset();
    Or use the GPREGRET2 and change that in the application and bootloader ?
    And regarding the reset of the device after the dfu and update, any idea ?
    Thank you for any help....
    twittich
    The retention register will be read as zero if you have a WD reset occurring before the bootloader has had time to read back the flag. So could it be possible that you get a timeout? As a test, can you increase the reload interval when you initialize it in the app to >5 seconds and see if you get the same result? What is your current timeout?
  • Yes i had set it already to 15 and 30 secs but still no difference, the timeout which should be used in future is 1.5 sec if possible.
    Do you mean when i make a wd reset (feed the dog) the register is affected or when the wd time out?
  • I meant to say that the retention register will be reset if you let the WD timer time out (i.e., not reloaded in time). I'm not sure why you still see this with a timeout of 15-30 seconds though. Can you check the RESETREAS register in the bootloader on startup and see if the 'Reset from watchdog detected' bit is set?
