freertos with wdt reset problem, nrfjprog
Hello
my setup is a nrf52840, the sdk15.3, Softdevice s140.
I'm running an application with freertos and wdt and have the openbootloader and s140 also flashed.
- if in freertos the wdt is disabled and i set the GPREGRET register and make a reset with NVIC_SystemReset, i have to make a reset from outside by nrfjprog -r over jlink and then the dfu device comes up...
- and after update the device over dfu it has to be reset by nrfjprog -r and it resetarts in application as wanted
- If the wdt is enabled and do the same, set the GPREGRET register and make a reset with NVIC_SystemReset, the device restarts in application....
How can i make a reset or restart similar to nrfjprog -r from software so that no jlink is needed ?
Thanks in advance
twittich
  • It is reloaded in the 'loop_forever' loop, but the CPU also enters sleep there so there must be periodic interrupts to wake the CPU so nrf_bootloader_wdt_feed() can be called in time. Maybe the nrf_bootloader_wdt_feed_timer_start() is not called for some reason?
  • Yes it should be...
    At the function " void nrf_bootloader_wdt_init(void) "  " nrf_wdt_started() " is true and " nrf_bootloader_wdt_feed_timer_start() " is called.
    I also tried it to call the function directly " nrf_bootloader_wdt_feed () " in main and it goes also into it but the watchdog is not fed or where could it also be placed or do i have to init anything ?
    How and where do i have to do this ?
    Just to be clear this " NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS " is set to the same time as the wdt interval ?
  • As a test, please try to comment out the __WFE instruction from the wait for event loop and see if you still a WD timeout.
     Based on the NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS value, the bootloader implementation should ensure that the CPU is woken at regular intervals. So not sure why it's not working.
  • I commented out both _WFE and now it works partially.
    wdt interval is 20 sec and NRF_BL_WDT_MAX_SCHEDULER_LATENCY_MS  too, dfu inactivity still set to 0. It stays for 2 min in the dfu mode then it disappears and the application is not restarting, same if i debug the bootlaoder, it comes to " nrf_bootloader_app_start(); " but don't continue...?
  • The inactivity timer expires after 2 minutes by default, and it's supposed to reset the device and on subsequent startup enter DFU mode or boot the main application if one exists. So that part seems to be as expected.
     Are you sure it's not entering the main application? There are no while loops,etc that should cause the program to hang in nrf_bootloader_app_start().
