SPI read and write multiple bytes of varying lengths with MCP2515
Recently I was able to get a single read and write SPI operation to work properly with a custom nRF52832 (BL652) with SPI connection to MCP2515 (CAN SPI) using the nrf_drv_spi.c/h. (Solved through the following: https://devzone.nordicsemi.com/f/nordic-q-a/52046/nrf52832-spi-with-mcp2515-nrf_drv_spi_transfer-seems-to-send-properly-but-not-receiving-in-all-cases). I'm now trying to get multiple read and writing of bytes (of varying lengths and multiple different buffers) to work.
I wrote the following code sections to modify a .cpp library (https://github.com/Seeed-Studio/CAN_BUS_Shield/blob/master/mcp_can.cpp) function of mcp2515_readRegisterS and  mcp2515_setRegisterS to try utilize the mcp2515 auto increment of address-pointer and repeated reading/writing from/to a register.
However, I'm not sure if this is the proper way to implement and it doesn't seem to be giving back proper data. Since the previous method wrote multiple separate times (and wasn't working in my single read/write) I've attempted to append the arrays together for each send. The commented code is how it was done in the .cpp library.
1. mcp2515_readRegisterS
** Function name:           mcp2515_readRegisterS
** Descriptions:            read registerS
uint8_t mcp2515_readRegisterS(const uint8_t address, uint8_t values[], const uint8_t n)
    //byte i;
    uint8_t i;
    uint8_t m_tx_buf[] = {MCP_READ, address};
    //uint8_t m_tx_buf[] = {address};
    uint8_t m_rx_buf[n];
    uint8_t m_tx_length = sizeof(m_tx_buf);
    uint8_t m_rx_length = sizeof(m_rx_buf);
    memset(m_rx_buf, 0, m_rx_length);
    spi_xfer_done = false;
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_tx_length, m_rx_buf, m_rx_length));
     while (!spi_xfer_done)
            __WFE();
    //spi_readwrite(MCP_READ);
    //spi_readwrite(address);
    // mcp2515 has auto-increment of address-pointer
    for (i=0; i<n-2 && i<CAN_MAX_CHAR_IN_MESSAGE-2; i++)
      //values[i] = spi_read();
      return values[i] = m_rx_buf[i+2];
    /* NOT SURE IF CORRECT YET*/
***As a test I used the following code using mcp2515_readRegisterS:
   // Enter main loop.
    for (;;)
        uint8_t values[5];
        mcp2515_readRegisterS(MCP_READ_STATUS, values, 5);
        for(uint8_t i = 0; i<5; i++)
            NRF_LOG_INFO("Data Received %d 0x%x", i, values[i]);
          nrf_delay_ms(10);
        idle_state_handle();
This was the output:
<info> app: Data Received 0 0x0
<info> app: Data Received 1 0x7
<info> app: Data Received 2 0x10
<info> app: Data Received 3 0x3
<info> app: Data Received 4 0x3
<info> app: Transfer completed.
Note: This doesn't seem correct, since I'm expecting the data to be repeated for 5 bytes. Maybe this is the address auto-incremented return? However, I have tried to just send the "address" (see commended //uint8_t m_tx_buf[] = {address}...in this case an instruction of MCP_READ_STATUS), but the results were the same.
2. mcp2515_setRegisterS
** Function name:           mcp2515_setRegisterS
** Descriptions:            set registerS
void mcp2515_setRegisterS(const uint8_t address, const uint8_t values[], const uint8_t n)
    uint8_t i;
    uint8_t tx_buf[2] = {MCP_WRITE, address};
    uint8_t* m_tx_buf = malloc(2+n * sizeof(uint8_t));
    memcpy(m_tx_buf, tx_buf, 2 * sizeof(uint8_t)); //copy 2 uint8_t from tx_buf to m_tx_buf
    memcpy(m_tx_buf + n, values, n * sizeof(uint8_t)); //copy n uint8_t from values to m_tx_buf
    APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_tx_length, NULL, 0));
          __WFE();
    //uint8_t i;
    //spi_readwrite(MCP_WRITE);
    //for (i=0; i<n; i++)
        //spi_readwrite(values[i]);
The read and set Registers seem like they should work, but maybe I'm missing something in how auto incremented/repeated SPI operations should function.
The other way I'm trying to implement multiple byte reading/writing is with mcp2515_read_canMsg (not modified yet) and mcp2515_write_canMsg. These functions in the .cpp library contained many more steps that readRegisterS and setRegisterS.
The write_canMsg function at it's core does the following in order.
1. Write the 1 value of "load_address"
2. Write the 4 values of "tbufdata[]" sequentially
3. Write the 1 value of "dlc"
4. Write the 'len' values of "buf[]"
I've attempted to modify in the following by appending the arrays. Is that the proper way to treat multiple writing operations that happen sequentially in nRF52832? Or is there a more defined way to approach this? See the following code.
** Function name:           mcp2515_write_canMsg
** Descriptions:            write msg
**                          Note! There is no check for right address!
void mcp2515_write_canMsg(const uint8_t buffer_sidh_addr, unsigned long id, uint8_t ext, uint8_t rtrBit, uint8_t len, volatile const uint8_t *buf)
  uint8_t load_addr=txSidhToTxLoad(buffer_sidh_addr);
  uint8_t tbufdata[4];
  uint8_t dlc = len | ( rtrBit ? MCP_RTR_MASK : 0 ) ;
  uint8_t i;
  mcp2515_id_to_buf(ext,id,tbufdata);
    uint8_t* m_tx_buf = malloc(6+len * sizeof(uint8_t));
    memcpy(m_tx_buf, &load_addr, 1 * sizeof(uint8_t)); //copy 1 uint8_t from load_addr to m_tx_buf[0]
    memcpy(m_tx_buf + 1, tbufdata, 4 * sizeof(uint8_t)); //copy 4 uint8_t from tbufdata to m_tx_buf[1] -> m_tx_buf[4]
    memcpy(m_tx_buf + 5, &dlc, 1 * sizeof(uint8_t)); //copy 1 uint8_t from dlc to m_tx_buf[5]
    memcpy(m_tx_buf + 6, &buf, len * sizeof(uint8_t)); //copy n uint8_t from values to m_tx_buf[6] -> m_tx_buf[len]
          __WFE();
    /* NOT SURE IF CORRECT YET - the following is the previous .cpp code */
  spi_readwrite(load_addr);
  for (i = 0; i < 4; i++) spi_write(tbufdata[i]);
  spi_write(dlc);
  for (i = 0; i < len && i<CAN_MAX_CHAR_IN_MESSAGE; i++) spi_write(buf[i]);
  mcp2515_start_transmit( buffer_sidh_addr );
The read_canMsg function at it's core does the following in order:
1. Write "buffer_load_addr"
2. Read 4 values into "tbufdata[]"
3. Read 1 value into "pMsgSize"
4. Read 'len' values into "buf[]"
I haven't started to modify this yet, but if the process from the readRegisterS is correct I imagine it would be similar. But, how would the nrf_spi_drv handle reading all these sequentially? Would setting the size of the rx_buf for the size of the values work? (i.e. uint8_t* m_rx_buf = malloc(6+len * sizeof(uint8_t)); And then read the appropriate expected locations of the data into the tbufdata[], pMsgSize, and buf[] be the way to approach this? See the following un-modified way the read_canMsg was done in the .cpp library.
** Function name:           mcp2515_read_canMsg
** Descriptions:            read message
void mcp2515_read_canMsg( const uint8_t buffer_load_addr, volatile unsigned long *id, volatile uint8_t *ext, volatile uint8_t *rtrBit, volatile uint8_t *len, volatile uint8_t *buf)        // read can msg
  byte i;
  //MCP2515_SELECT();
  spi_readwrite(buffer_load_addr);
  for (i = 0; i < 4; i++) tbufdata[i] = spi_read();
  *id = (tbufdata[MCP_SIDH] << 3) + (tbufdata[MCP_SIDL] >> 5);
  *ext = 0;
  if ( (tbufdata[MCP_SIDL] & MCP_TXB_EXIDE_M) ==  MCP_TXB_EXIDE_M )
    // extended id
    *id = (*id << 2) + (tbufdata[MCP_SIDL] & 0x03);
    *id = (*id << 8) + tbufdata[MCP_EID8];
    *id = (*id << 8) + tbufdata[MCP_EID0];
    *ext = 1;
  byte pMsgSize = spi_read();
  *len = pMsgSize & MCP_DLC_MASK;
  *rtrBit = (pMsgSize & MCP_RTR_MASK) ? 1 : 0;
  for (i = 0; i < *len && i<CAN_MAX_CHAR_IN_MESSAGE; i++) {
    buf[i] = spi_read();
  MCP2515_UNSELECT();
What would be the correct way to do all this?
Thanks!
  • Well I had been doing this. But adding 2 to the length (2+5) returns all zeros (0x0 for all).
    // Enter main loop.
        for (;;)
            uint8_t values[5];
              nrf_delay_ms(10);
  • Have you tried to analyze the SPI lines with a logic analyzer? Is there any data coming from the device? Or is it flat at GND?
  • I have tried to analyze the SPI lines using an SDS 1104X-E scope. I don't see any data coming out, only 0x00 on the MISO line. For the first section however (initialization of MCP2515) I get the following readout (This is based on the attached main.c and mcp_can.c/h and mcp_can_dfs.h which I've modified):
    <info> app: Template example started.
    <info> app: Fast advertising.
    <info> app: CAN SPI example started.
    <info> app: Start
    <info> app: Enter setting mode success
    <info> app: set rate success!!
    <info> app: Enter Normal Mode Success!!
    <info> app: CAN initialization ok
    <info> app: Data Received 1 0x0
    <info> app: Data Received 2 0x0
    ...//This repeats
      mcp2515_can.c
       mcp_can.h
      2012 Copyright (c) Seeed Technology Inc.  All right reserved.
      Author:Loovee ([email protected])
      2014-1-16
      Contributor:
      Cory J. Fowler
      Latonita
      Woodward1
      Mehtajaghvi
      BykeBlast
      TheRo0T
      Tsipizic
      ralfEdmund
      Nathancheek
      BlueAndi
      Adlerweb
      Btetz
      Hurvajs
      ttlappalainen
      The MIT License (MIT)
      Copyright (c) 2013 Seeed Technology Inc.
      Permission is hereby granted, free of charge, to any person obtaining a copy
      of this software and associated documentation files (the "Software"), to deal
      in the Software without restriction, including without limitation the rights
      to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
      copies of the Software, and to permit persons to whom the Software is
      furnished to do so, subject to the following conditions:
      The above copyright notice and this permission notice shall be included in
      all copies or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
      IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
      FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
      AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
      LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
      OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
      THE SOFTWARE.
    #include "mcp_can.h"
    #include "nrf_delay.h"
    #include "nrf_drv_spi.h"
    #include "app_timer.h"
    #include "nrf_gpio.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define TICKS_PER_MS APP_TIMER_TICKS(1)
    //#define spi_readwrite      pSPI->transfer
    //#define spi_read()         spi_readwrite(0x00)
    //#define spi_write(spi_val) spi_readwrite(spi_val)
    //#define SPI_BEGIN()        pSPI->beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE0))
    //#define SPI_END()          pSPI->endTransaction()
    mcp2515_can_t m_mcp_can;
    uint8_t dummy_receive;
    #define SPI_CAN_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t can_spi = NRF_DRV_SPI_INSTANCE(SPI_CAN_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    uint32_t millis()
      return (app_timer_cnt_get() / TICKS_PER_MS);
    ** Function name:           mcp2515_spi_handler
    ** Descriptions:            select the device through cs -> LOW
    void spi_can_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
         switch(p_event->type)
               case NRF_DRV_SPI_EVENT_DONE:
                    spi_xfer_done = true;
                    NRF_LOG_INFO("Transfer completed.");
                    if (m_rx_buf[0] != 0)
                        NRF_LOG_INFO(" Received:");
                        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    ** Function name:           mcp2515_spi_initialization
    ** Descriptions:            initialize the spi bus through nrf_drv_spi.h
    void mcp2515_can_initialize()
            uint32_t err_code;
            nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
            spi_config.frequency = NRF_DRV_SPI_FREQ_125K;
            spi_config.mode = NRF_DRV_SPI_MODE_0;
            spi_config.ss_pin   = SPI_SS_PIN;
            spi_config.miso_pin = SPI_MISO_PIN;
            spi_config.mosi_pin = SPI_MOSI_PIN;
            spi_config.sck_pin  = SPI_SCK_PIN;
            spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
            //spi_config.bit_order = (lsb ? NRF_DRV_SPI_BIT_ORDER_LSB_FIRST : NRF_DRV_SPI_BIT_ORDER_MSB_FIRST);
            //if(!nrf_drv_spi_init(&can_spi, &spi_config, spi_can_event_handler, NULL))
                //err_code = nrf_drv_spi_init(&spi_master_instance, &spi_config, spi_master_event_handler, NULL);
                //APP_ERROR_CHECK(err_code);
            err_code = nrf_drv_spi_init(&can_spi, &spi_config, spi_can_event_handler, NULL);
            NRF_LOG_INFO("CAN SPI example started.");
    ** Function name:           mcp2515_spi_transfer
    ** Descriptions:            nRF52832 spi transer (send and receive)
    void mcp2515_spi_transfer(uint8_t p_tx_data, uint8_t p_rx_data, const uint16_t len)
        // Initalize buffers.
        // Start transfer.
        //uint32_t err_code = NRF_SUCCESS;
        // Reset rx buffer and transfer done flag
        memset(&p_rx_data, 0, len);
        NRF_LOG_INFO("tx data %x\n", p_tx_data);
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, &p_tx_data, len, &p_rx_data, len));
            __WFE();
        //spi_master_send_recv(spi_master_hw_instance, &tx_data, len, &p_rx_data, len);
    	NRF_LOG_INFO("rx data %x\n", p_rx_data);
    ** Function name:           mcp2515_select
    void MCP2515_SELECT()
    	nrf_gpio_pin_clear(m_mcp_can.can_spi_cs);
    ** Function name:           mcp2515_unselect
    ** Descriptions:            unselect the device through cs -> HIGH
    void MCP2515_UNSELECT()
    	nrf_gpio_pin_set(m_mcp_can.can_spi_cs);
    ** Function name:           txCtrlReg
    ** Descriptions:            return tx ctrl reg according to tx buffer index.
    **                          According to my tests this is faster and saves memory compared using vector
    uint8_t txCtrlReg(uint8_t i)
      switch (i)
          case 0:
            return MCP_TXB0CTRL;
          case 1:
            return MCP_TXB1CTRL;
          case 2:
            return MCP_TXB2CTRL;
    ** Function name:           statusToBuffer
    ** Descriptions:            converts CANINTF status to tx buffer index
    uint8_t statusToTxBuffer(uint8_t status)
      switch (status)
          case MCP_TX0IF:
            return 0;
          case MCP_TX1IF:
            return 1;
          case MCP_TX2IF:
            return 2;
      return 0xff;
    ** Descriptions:            converts CANINTF status to tx buffer sidh
    int8_t statusToTxSidh(uint8_t status)
      switch (status)
          case MCP_TX0IF:
            return MCP_TXB0SIDH;
          case MCP_TX1IF:
            return MCP_TXB1SIDH;
          case MCP_TX2IF:
            return MCP_TXB2SIDH;
      return 0;
    ** Function name:           txSidhToTxLoad
    ** Descriptions:            return tx load command according to tx buffer sidh register
    uint8_t txSidhToRTS(uint8_t sidh)
      switch (sidh)
          case MCP_TXB0SIDH:
            return MCP_RTS_TX0;
          case MCP_TXB1SIDH:
            return MCP_RTS_TX1;
          case MCP_TXB2SIDH:
            return MCP_RTS_TX2;
      return 0;
    uint8_t txSidhToTxLoad(uint8_t sidh)
      switch (sidh)
          case MCP_TXB0SIDH:
            return MCP_LOAD_TX0;
          case MCP_TXB1SIDH:
            return MCP_LOAD_TX1;
          case MCP_TXB2SIDH:
            return MCP_LOAD_TX2;
      return 0;
    ** Function name:           txIfFlag
    ** Descriptions:            return tx interrupt flag
    uint8_t txIfFlag(uint8_t i)
      switch (i)
          case 0:
            return MCP_TX0IF;
          case 1:
            return MCP_TX1IF;
          case 2:
            return MCP_TX2IF;
      return 0;
    ** Function name:           txStatusPendingFlag
    ** Descriptions:            return buffer tx pending flag on status
    uint8_t txStatusPendingFlag(uint8_t i)
      switch (i)
          case 0:
            return MCP_STAT_TX0_PENDING;
          case 1:
            return MCP_STAT_TX1_PENDING;
          case 2:
            return MCP_STAT_TX2_PENDING;
      return 0xff;
    ** Function name:           mcp2515_reset
    ** Descriptions:            reset the device
    void mcp2515_reset()
        uint8_t m_tx_buf[1] = {MCP_RESET};
        uint8_t m_rx_buf[2];
        uint8_t m_length = sizeof(m_tx_buf);
        memset(m_rx_buf, 0, m_length);
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_length, m_rx_buf, m_length));
                __WFE();
        nrf_delay_ms(10);
    uint8_t mcp2515_readRegister(const uint8_t address)
        uint8_t m_rx_buf[3];
                __WFE();
        return m_rx_buf[2];
    void mcp2515_readRegisterS(const uint8_t address, uint8_t values[], const uint8_t n)
        //byte i;
        uint8_t i;
                __WFE();
        return;
    void mcp2515_setRegister(const uint8_t address, const uint8_t value)
        uint8_t m_tx_buf[3] = {MCP_WRITE, address, value};
        uint8_t m_rx_buf[4];
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, m_tx_buf, m_length, NULL, 0));
                __WFE();
        uint8_t i;
              __WFE();
        //uint8_t i;
    ** Function name:           mcp2515_modifyRegister
    ** Descriptions:            set bit of one register
    void mcp2515_modifyRegister(const uint8_t address, const uint8_t mask, const uint8_t data)
        uint8_t m_tx_buf[4] = {MCP_BITMOD, address, mask, data};
        uint8_t m_rx_buf[5];
                __WFE();
    ** Function name:           mcp2515_readStatus
    ** Descriptions:            read mcp2515's Status
    uint8_t mcp2515_readStatus(void)
        uint8_t m_tx_buf[1] = {MCP_READ_STATUS};
                __WFE();
        return m_rx_buf[1];
    ** Function name:           setSleepWakeup
    ** Descriptions:            Enable or disable the wake up interrupt (If disabled the MCP2515 will not be woken up by CAN bus activity)
    void setSleepWakeup(const uint8_t enable)
        mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, enable ? MCP_WAKIF : 0);
    ** Function name:           mcp2515_requestNewMode
    ** Descriptions:            Set control mode
    uint8_t mcp2515_requestNewMode(const uint8_t newmode)
    	unsigned long startTime = millis();
    	// Spam new mode request and wait for the operation  to complete
    	while(1)
    		// Request new mode
    		// This is inside the loop as sometimes requesting the new mode once doesn't work (usually when attempting to sleep)
    		mcp2515_modifyRegister(MCP_CANCTRL, MODE_MASK, newmode);
    		uint8_t statReg = mcp2515_readRegister(MCP_CANSTAT);
    		if((statReg & MODE_MASK) == newmode){ // We're now in the new mode
                        return MCP2515_OK;
    		else if((millis() - startTime) > 200){ // Wait no more than 200ms for the operation to complete
                        return MCP2515_FAIL;
    ** Function name:           getMode
    ** Descriptions:            Returns current control mode
    uint8_t getMode()
    	return mcp2515_readRegister(MCP_CANSTAT) & MODE_MASK;
    ** Function name:           mcp2515_setCANCTRL_Mode
    ** Descriptions:            set control mode
    uint8_t mcp2515_setCANCTRL_Mode(const uint8_t newmode)
    	// If the chip is asleep and we want to change mode then a manual wake needs to be done
    	// This is done by setting the wake up interrupt flag
    	// This undocumented trick was found at https://github.com/mkleemann/can/blob/master/can_sleep_mcp2515.c
    	if((getMode()) == MODE_SLEEP && newmode != MODE_SLEEP)
    		// Make sure wake interrupt is enabled
    		uint8_t wakeIntEnabled = (mcp2515_readRegister(MCP_CANINTE) & MCP_WAKIF);
    		if(!wakeIntEnabled){
    			mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, MCP_WAKIF);
    		// Set wake flag (this does the actual waking up)
    		mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, MCP_WAKIF);
    		// Wait for the chip to exit SLEEP and enter LISTENONLY mode.
    		// If the chip is not connected to a CAN bus (or the bus has no other powered nodes) it will sometimes trigger the wake interrupt as soon
    		// as it's put to sleep, but it will stay in SLEEP mode instead of automatically switching to LISTENONLY mode.
    		// In this situation the mode needs to be manually set to LISTENONLY.
    		if(mcp2515_requestNewMode(MODE_LISTENONLY) != MCP2515_OK){
    		// Turn wake interrupt back off if it was originally off
                        mcp2515_modifyRegister(MCP_CANINTE, MCP_WAKIF, 0);
    	// Clear wake flag
    	mcp2515_modifyRegister(MCP_CANINTF, MCP_WAKIF, 0);
    	return mcp2515_requestNewMode(newmode);
    ** Function name:           sleep
    ** Descriptions:            Put mcp2515 in sleep mode to save power
    uint8_t sleep()
    	if(getMode() != MODE_SLEEP)
    		return mcp2515_setCANCTRL_Mode(MODE_SLEEP);
    		return CAN_OK;
    ** Function name:           wake
    ** Descriptions:            wake MCP2515 manually from sleep. It will come back in the mode it was before sleeping.
    uint8_t wake()
    	uint8_t currMode = getMode();
    	if(currMode != m_mcp_can.can_mcpMode)
    		return mcp2515_setCANCTRL_Mode(m_mcp_can.can_mcpMode);
    		return CAN_OK;
    ** Function name:           setMode
    ** Descriptions:            Sets control mode
    uint8_t setMode(const uint8_t opMode)
        //if(opMode != MODE_SLEEP) // if going to sleep, the value stored in opMode is not changed so that we can return to it later
    		//mcpMode = opMode;
            m_mcp_can.can_mcpMode = opMode;
        return mcp2515_setCANCTRL_Mode(opMode);
    ** Function name:           mcp2515_configRate
    ** Descriptions:            set baudrate
    uint8_t mcp2515_configRate(const uint8_t canSpeed, const uint8_t clock)
      uint8_t set, cfg1, cfg2, cfg3;
      set = 1;
      switch (clock)
        case (MCP_16MHz) :
          switch (canSpeed)
            case (CAN_5KBPS):
              cfg1 = MCP_16MHz_5kBPS_CFG1;
              cfg2 = MCP_16MHz_5kBPS_CFG2;
              cfg3 = MCP_16MHz_5kBPS_CFG3;
            case (CAN_10KBPS):
              cfg1 = MCP_16MHz_10kBPS_CFG1;
              cfg2 = MCP_16MHz_10kBPS_CFG2;
              cfg3 = MCP_16MHz_10kBPS_CFG3;
            case (CAN_20KBPS):
              cfg1 = MCP_16MHz_20kBPS_CFG1;
              cfg2 = MCP_16MHz_20kBPS_CFG2;
              cfg3 = MCP_16MHz_20kBPS_CFG3;
            case (CAN_25KBPS):
              cfg1 = MCP_16MHz_25kBPS_CFG1;
              cfg2 = MCP_16MHz_25kBPS_CFG2;
              cfg3 = MCP_16MHz_25kBPS_CFG3;
            case (CAN_31K25BPS):
              cfg1 = MCP_16MHz_31k25BPS_CFG1;
              cfg2 = MCP_16MHz_31k25BPS_CFG2;
              cfg3 = MCP_16MHz_31k25BPS_CFG3;
            case (CAN_33KBPS):
              cfg1 = MCP_16MHz_33kBPS_CFG1;
              cfg2 = MCP_16MHz_33kBPS_CFG2;
              cfg3 = MCP_16MHz_33kBPS_CFG3;
            case (CAN_40KBPS):
              cfg1 = MCP_16MHz_40kBPS_CFG1;
              cfg2 = MCP_16MHz_40kBPS_CFG2;
              cfg3 = MCP_16MHz_40kBPS_CFG3;
            case (CAN_50KBPS):
              cfg1 = MCP_16MHz_50kBPS_CFG1;
              cfg2 = MCP_16MHz_50kBPS_CFG2;
              cfg3 = MCP_16MHz_50kBPS_CFG3;
            case (CAN_80KBPS):
              cfg1 = MCP_16MHz_80kBPS_CFG1;
              cfg2 = MCP_16MHz_80kBPS_CFG2;
              cfg3 = MCP_16MHz_80kBPS_CFG3;
            case (CAN_83K3BPS):
              cfg1 = MCP_16MHz_83k3BPS_CFG1;
              cfg2 = MCP_16MHz_83k3BPS_CFG2;
              cfg3 = MCP_16MHz_83k3BPS_CFG3;
            case (CAN_95KBPS):
              cfg1 = MCP_16MHz_95kBPS_CFG1;
              cfg2 = MCP_16MHz_95kBPS_CFG2;
              cfg3 = MCP_16MHz_95kBPS_CFG3;
            case (CAN_100KBPS):
              cfg1 = MCP_16MHz_100kBPS_CFG1;
              cfg2 = MCP_16MHz_100kBPS_CFG2;
              cfg3 = MCP_16MHz_100kBPS_CFG3;
            case (CAN_125KBPS):
              cfg1 = MCP_16MHz_125kBPS_CFG1;
              cfg2 = MCP_16MHz_125kBPS_CFG2;
              cfg3 = MCP_16MHz_125kBPS_CFG3;
            case (CAN_200KBPS):
              cfg1 = MCP_16MHz_200kBPS_CFG1;
              cfg2 = MCP_16MHz_200kBPS_CFG2;
              cfg3 = MCP_16MHz_200kBPS_CFG3;
            case (CAN_250KBPS):
              cfg1 = MCP_16MHz_250kBPS_CFG1;
              cfg2 = MCP_16MHz_250kBPS_CFG2;
              cfg3 = MCP_16MHz_250kBPS_CFG3;
            case (CAN_500KBPS):
              cfg1 = MCP_16MHz_500kBPS_CFG1;
              cfg2 = MCP_16MHz_500kBPS_CFG2;
              cfg3 = MCP_16MHz_500kBPS_CFG3;
            case (CAN_666KBPS):
              cfg1 = MCP_16MHz_666kBPS_CFG1;
              cfg2 = MCP_16MHz_666kBPS_CFG2;
              cfg3 = MCP_16MHz_666kBPS_CFG3;
            case (CAN_1000KBPS):
              cfg1 = MCP_16MHz_1000kBPS_CFG1;
              cfg2 = MCP_16MHz_1000kBPS_CFG2;
              cfg3 = MCP_16MHz_1000kBPS_CFG3;
              set = 0;
        case (MCP_8MHz) :
          switch (canSpeed)
            case (CAN_5KBPS) :
              cfg1 = MCP_8MHz_5kBPS_CFG1;
              cfg2 = MCP_8MHz_5kBPS_CFG2;
              cfg3 = MCP_8MHz_5kBPS_CFG3;
            case (CAN_10KBPS) :
              cfg1 = MCP_8MHz_10kBPS_CFG1;
              cfg2 = MCP_8MHz_10kBPS_CFG2;
              cfg3 = MCP_8MHz_10kBPS_CFG3;
            case (CAN_20KBPS) :
              cfg1 = MCP_8MHz_20kBPS_CFG1;
              cfg2 = MCP_8MHz_20kBPS_CFG2;
              cfg3 = MCP_8MHz_20kBPS_CFG3;
            case (CAN_31K25BPS) :
              cfg1 = MCP_8MHz_31k25BPS_CFG1;
              cfg2 = MCP_8MHz_31k25BPS_CFG2;
              cfg3 = MCP_8MHz_31k25BPS_CFG3;
            case (CAN_40KBPS) :
              cfg1 = MCP_8MHz_40kBPS_CFG1;
              cfg2 = MCP_8MHz_40kBPS_CFG2;
              cfg3 = MCP_8MHz_40kBPS_CFG3;
            case (CAN_50KBPS) :
              cfg1 = MCP_8MHz_50kBPS_CFG1;
              cfg2 = MCP_8MHz_50kBPS_CFG2;
              cfg3 = MCP_8MHz_50kBPS_CFG3;
            case (CAN_80KBPS) :
              cfg1 = MCP_8MHz_80kBPS_CFG1;
              cfg2 = MCP_8MHz_80kBPS_CFG2;
              cfg3 = MCP_8MHz_80kBPS_CFG3;
            case (CAN_100KBPS) :
              cfg1 = MCP_8MHz_100kBPS_CFG1;
              cfg2 = MCP_8MHz_100kBPS_CFG2;
              cfg3 = MCP_8MHz_100kBPS_CFG3;
            case (CAN_125KBPS) :
              cfg1 = MCP_8MHz_125kBPS_CFG1;
              cfg2 = MCP_8MHz_125kBPS_CFG2;
              cfg3 = MCP_8MHz_125kBPS_CFG3;
            case (CAN_200KBPS) :
              cfg1 = MCP_8MHz_200kBPS_CFG1;
              cfg2 = MCP_8MHz_200kBPS_CFG2;
              cfg3 = MCP_8MHz_200kBPS_CFG3;
            case (CAN_250KBPS) :
              cfg1 = MCP_8MHz_250kBPS_CFG1;
              cfg2 = MCP_8MHz_250kBPS_CFG2;
              cfg3 = MCP_8MHz_250kBPS_CFG3;
            case (CAN_500KBPS) :
              cfg1 = MCP_8MHz_500kBPS_CFG1;
              cfg2 = MCP_8MHz_500kBPS_CFG2;
              cfg3 = MCP_8MHz_500kBPS_CFG3;
            case (CAN_1000KBPS) :
              cfg1 = MCP_8MHz_1000kBPS_CFG1;
              cfg2 = MCP_8MHz_1000kBPS_CFG2;
              cfg3 = MCP_8MHz_1000kBPS_CFG3;
              set = 0;
          set = 0;
      if (set) {
        mcp2515_setRegister(MCP_CNF1, cfg1);
        mcp2515_setRegister(MCP_CNF2, cfg2);
        mcp2515_setRegister(MCP_CNF3, cfg3);
        return MCP2515_OK;
      else {
    ** Function name:           mcp2515_initCANBuffers
    ** Descriptions:            init canbuffers
    void mcp2515_initCANBuffers(void)
        uint8_t i, a1, a2, a3;
        a1 = MCP_TXB0CTRL;
        a2 = MCP_TXB1CTRL;
        a3 = MCP_TXB2CTRL;
        for (i = 0; i < 14; i++)                         // in-buffer loop
          mcp2515_setRegister(a1, 0);
          mcp2515_setRegister(a2, 0);
          mcp2515_setRegister(a3, 0);
          a1++;
          a2++;
          a3++;
        mcp2515_setRegister(MCP_RXB0CTRL, 0);
        mcp2515_setRegister(MCP_RXB1CTRL, 0);
    ** Descriptions:            init the device
    uint8_t mcp2515_init(const uint8_t canSpeed, const uint8_t clock)
        uint8_t res;
        mcp2515_reset();
        res = mcp2515_setCANCTRL_Mode(MODE_CONFIG);
        if (res > 0)
    #if DEBUG_EN
          NRF_LOG_INFO("Enter setting mode fail\r\n");
    #else
          nrf_delay_ms(10);
          return res;
    #if DEBUG_EN
        NRF_LOG_INFO("Enter setting mode success \r\n");
    #else
         nrf_delay_ms(10);
        // set boadrate
        if (mcp2515_configRate(canSpeed, clock))
    #if DEBUG_EN
          NRF_LOG_INFO("set rate fall!!\r\n");
    #else
         nrf_delay_ms(10);
          return res;
    #if DEBUG_EN
        NRF_LOG_INFO("set rate success!!\r\n");
    #else
         nrf_delay_ms(10);
        if ( res == MCP2515_OK ) {
          // init canbuffers
          mcp2515_initCANBuffers();
          // interrupt mode
          mcp2515_setRegister(MCP_CANINTE, MCP_RX0IF | MCP_RX1IF);
    #if (DEBUG_RXANY==1)
          // enable both receive-buffers to receive any message and enable rollover
          mcp2515_modifyRegister(MCP_RXB0CTRL,
                                 MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK,
                                 MCP_RXB_RX_ANY | MCP_RXB_BUKT_MASK);
          mcp2515_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK,
                                 MCP_RXB_RX_ANY);
    #else
          // enable both receive-buffers to receive messages with std. and ext. identifiers and enable rollover
                                 MCP_RXB_RX_STDEXT | MCP_RXB_BUKT_MASK);
                                 MCP_RXB_RX_STDEXT);
          // enter normal mode
          res = setMode(MODE_NORMAL);
          if (res)
    #if DEBUG_EN
            NRF_LOG_INFO("Enter Normal Mode Fail!!\r\n");
    #else
          nrf_delay_ms(10);
            return res;
    #if DEBUG_EN
          NRF_LOG_INFO("Enter Normal Mode Success!!\r\n");
    #else
          nrf_delay_ms(10);
        return res;
    ** Function name:           mcp2515_id_to_buf
    ** Descriptions:            configure tbufdata[4] from id and ext
    void mcp2515_id_to_buf(const uint8_t ext, const unsigned long id, uint8_t *tbufdata)
      uint16_t canid;
      canid = (uint16_t)(id & 0x0FFFF);
      if (ext == 1)
        tbufdata[MCP_EID0] = (uint8_t) (canid & 0xFF);
        tbufdata[MCP_EID8] = (uint8_t) (canid >> 8);
        canid = (uint16_t)(id >> 16);
        tbufdata[MCP_SIDL] = (uint8_t) (canid & 0x03);
        tbufdata[MCP_SIDL] += (uint8_t) ((canid & 0x1C) << 3);
        tbufdata[MCP_SIDL] |= MCP_TXB_EXIDE_M;
        tbufdata[MCP_SIDH] = (uint8_t) (canid >> 5 );
        tbufdata[MCP_SIDH] = (uint8_t) (canid >> 3 );
        tbufdata[MCP_SIDL] = (uint8_t) ((canid & 0x07 ) << 5);
        tbufdata[MCP_EID0] = 0;
        tbufdata[MCP_EID8] = 0;
    ** Function name:           mcp2515_write_id
    ** Descriptions:            write can id
    void mcp2515_write_id(const uint8_t mcp_addr, const uint8_t ext, const unsigned long id)
        mcp2515_setRegisterS(mcp_addr, tbufdata, 4);
    ** Function name:           mcp2515_read_id
    ** Descriptions:            read can id
    void mcp2515_read_id(const uint8_t mcp_addr, uint8_t* ext, unsigned long* id)
        *ext    = 0;
        *id     = 0;
        mcp2515_readRegisterS(mcp_addr, tbufdata, 4);
          // extended id
          *ext = 1;
    ** Function name:           mcp2515_start_transmit
    ** Descriptions:            Start message transmit on mcp2515
    void mcp2515_start_transmit(const uint8_t mcp_addr)              // start transmit
        uint8_t m_tx_buf[] = {txSidhToRTS(mcp_addr)};
                __WFE();
        //spi_readwrite(txSidhToRTS(mcp_addr));
      uint8_t i;
              __WFE();
      spi_write(dlc);
      byte i;
      //MCP2515_SELECT();
      *ext = 0;
        // extended id
        *ext = 1;
      MCP2515_UNSELECT();
    ** Function name:           mcp2515_isTXBufFree
    ** Descriptions:            Test is tx buffer free for transmitting
    byte MCP_CAN::mcp2515_isTXBufFree(byte *txbuf_n, byte iBuf)           // get Next free txbuf
      *txbuf_n = 0x00;
      if ( iBuf>=MCP_N_TXBUFFERS ||
          (mcp2515_readStatus() & txStatusPendingFlag(iBuf))!=0 ) return MCP_ALLTXBUSY;
      *txbuf_n = txCtrlReg(iBuf) + 1;                                // return SIDH-address of Buffer
      mcp2515_modifyRegister(MCP_CANINTF, txIfFlag(iBuf), 0);
      return MCP2515_OK;
    ** Function name:           mcp2515_getNextFreeTXBuf
    ** Descriptions:            finds next free tx buffer for sending. Return MCP_ALLTXBUSY, if there is none.
    byte MCP_CAN::mcp2515_getNextFreeTXBuf(byte *txbuf_n)                 // get Next free txbuf
        byte status=mcp2515_readStatus() & MCP_STAT_TX_PENDING_MASK;
        byte i;
        *txbuf_n = 0x00;
        if ( status==MCP_STAT_TX_PENDING_MASK ) return MCP_ALLTXBUSY; // All buffers are pending
        // check all 3 TX-Buffers except reserved
        for (i = 0; i < MCP_N_TXBUFFERS-nReservedTx; i++)
          if ( (status & txStatusPendingFlag(i) ) == 0 ) {
            *txbuf_n = txCtrlReg(i) + 1;                                   // return SIDH-address of Buffer
            mcp2515_modifyRegister(MCP_CANINTF, txIfFlag(i), 0);
            return MCP2515_OK;                                                 // ! function exit
    ** Function name:           MCP_CAN
    ** Descriptions:            Constructor
    MCP_CAN::MCP_CAN(byte _CS) : nReservedTx(0)
      pSPI=&SPI; init_CS(_CS);
    ** Function name:           init_CS
    ** Descriptions:            init CS pin and set UNSELECTED
    void MCP_CAN::init_CS(byte _CS)
      if (_CS == 0) return;
      SPICS = _CS;
      pinMode(SPICS, OUTPUT);
      MCP2515_UNSELECT();
    ** Function name:           CAN begin
    ** Descriptions:            initialize CAN and set speed
    uint8_t mcp_can_begin(uint8_t speedset, const uint8_t clockset)
        //pSPI->begin();
        //mcp2515_can_initialize();
        uint8_t res = mcp2515_init(speedset, clockset);
        return ((res == MCP2515_OK) ? CAN_OK : CAN_FAILINIT);
    ** Function name:           enableTxInterrupt
    ** Descriptions:            enable interrupt for all tx buffers
    void MCP_CAN::enableTxInterrupt(bool enable)
      byte interruptStatus=mcp2515_readRegister(MCP_CANINTE);
      if ( enable ) {
        interruptStatus |= MCP_TX_INT;
      } else {
        interruptStatus &= ~MCP_TX_INT;
      mcp2515_setRegister(MCP_CANINTE, interruptStatus);
    ** Function name:           init_Mask
    ** Descriptions:            init canid Masks
    byte MCP_CAN::init_Mask(byte num, byte ext, unsigned long ulData)
        byte res = MCP2515_OK;
    #if DEBUG_EN
        Serial.print("Begin to set Mask!!\r\n");
    #else
        delay(10);
        if (res > 0) {
    #if DEBUG_EN
            Serial.print("Enter setting mode fall\r\n");
    #else
            delay(10);
            return res;
        if (num == 0) {
            mcp2515_write_id(MCP_RXM0SIDH, ext, ulData);
        else if (num == 1) {
            mcp2515_write_id(MCP_RXM1SIDH, ext, ulData);
        else res =  MCP2515_FAIL;
        res = mcp2515_setCANCTRL_Mode(mcpMode);
        if (res > 0) {
    #if DEBUG_EN
            Serial.print("Enter normal mode fall\r\n");
    #else
            delay(10);
            return res;
    #if DEBUG_EN
        Serial.print("set Mask success!!\r\n");
    #else
        delay(10);
        return res;
    ** Function name:           init_Filt
    ** Descriptions:            init canid filters
    byte MCP_CAN::init_Filt(byte num, byte ext, unsigned long ulData)
    #if DEBUG_EN
        Serial.print("Begin to set Filter!!\r\n");
    #else
        delay(10);
        if (res > 0)
    #if DEBUG_EN
    #else
            delay(10);
            return res;
        switch ( num )
          case 0:
            mcp2515_write_id(MCP_RXF0SIDH, ext, ulData);
          case 1:
            mcp2515_write_id(MCP_RXF1SIDH, ext, ulData);
          case 2:
            mcp2515_write_id(MCP_RXF2SIDH, ext, ulData);
          case 3:
            mcp2515_write_id(MCP_RXF3SIDH, ext, ulData);
          case 4:
            mcp2515_write_id(MCP_RXF4SIDH, ext, ulData);
          case 5:
            mcp2515_write_id(MCP_RXF5SIDH, ext, ulData);
            res = MCP2515_FAIL;
        if (res > 0)
    #if DEBUG_EN
            Serial.print("Enter normal mode fall\r\nSet filter fail!!\r\n");
    #else
            delay(10);
            return res;
    #if DEBUG_EN
        Serial.print("set Filter success!!\r\n");
    #else
        delay(10);
        return res;
    ** Function name:           sendMsgBuf
    ** Descriptions:            Send message by using buffer read as free from CANINTF status
    **                          Status has to be read with readRxTxStatus and filtered with checkClearTxStatus
    byte MCP_CAN::sendMsgBuf(byte status, unsigned long id, byte ext, byte rtrBit, byte len, volatile const byte *buf)
      byte txbuf_n=statusToTxSidh(status);
      if ( txbuf_n==0 ) return CAN_FAILTX; // Invalid status
      mcp2515_modifyRegister(MCP_CANINTF, status, 0);  // Clear interrupt flag
      mcp2515_write_canMsg(txbuf_n, id, ext, rtrBit, len, buf);
      return CAN_OK;
    ** Function name:           trySendMsgBuf
    ** Descriptions:            Try to send message. There is no delays for waiting free buffer.
    byte MCP_CAN::trySendMsgBuf(unsigned long id, byte ext, byte rtrBit, byte len, const byte *buf, byte iTxBuf)
      byte txbuf_n;
      if ( iTxBuf<MCP_N_TXBUFFERS ) { // Use specified buffer
        if ( mcp2515_isTXBufFree(&txbuf_n,iTxBuf) != MCP2515_OK ) return CAN_FAILTX;
      } else {
        if ( mcp2515_getNextFreeTXBuf(&txbuf_n) != MCP2515_OK ) return CAN_FAILTX;
      return CAN_OK;
    ** Descriptions:            send message
    byte MCP_CAN::sendMsg(unsigned long id, byte ext, byte rtrBit, byte len, const byte *buf, bool wait_sent)
        byte res, res1, txbuf_n;
        uint16_t uiTimeOut = 0;
        can_id=id;
        ext_flg=ext;
        rtr=rtrBit;
        do {
            if (uiTimeOut > 0) delayMicroseconds(10);
            res = mcp2515_getNextFreeTXBuf(&txbuf_n);                       // info = addr.
            uiTimeOut++;
        } while (res == MCP_ALLTXBUSY && (uiTimeOut < TIMEOUTVALUE));
        if (uiTimeOut == TIMEOUTVALUE)
            return CAN_GETTXBFTIMEOUT;                                      // get tx buff time out
        if (wait_sent) {
          uiTimeOut = 0;
          do
              uiTimeOut++;
              res1 = mcp2515_readRegister(txbuf_n - 1);  // read send buff ctrl reg
              res1 = res1 & 0x08;
          } while (res1 && (uiTimeOut < TIMEOUTVALUE));
          if (uiTimeOut == TIMEOUTVALUE)                                       // send msg timeout
              return CAN_SENDMSGTIMEOUT;
        return CAN_OK;
    ** Descriptions:            send buf
    byte MCP_CAN::sendMsgBuf(unsigned long id, byte ext, byte rtrBit, byte len, const byte *buf, bool wait_sent)
        return sendMsg(id,ext,rtrBit,len,buf,wait_sent);
    byte MCP_CAN::sendMsgBuf(unsigned long id, byte ext, byte len, const byte *buf, bool wait_sent)
        return sendMsg(id,ext,0,len,buf,wait_sent);
    ** Function name:           readMsgBuf
    ** Descriptions:            read message buf
    byte MCP_CAN::readMsgBuf(byte *len, byte buf[])
        return readMsgBufID(readRxTxStatus(),&can_id,&ext_flg,&rtr,len,buf);
    ** Function name:           readMsgBufID
    ** Descriptions:            read message buf and can bus source ID
    byte MCP_CAN::readMsgBufID(unsigned long *ID, byte *len, byte buf[])
        return readMsgBufID(readRxTxStatus(),ID,&ext_flg,&rtr,len,buf);
    ** Descriptions:            Read message buf and can bus source ID according to status.
    **                          Status has to be read with readRxTxStatus.
    byte MCP_CAN::readMsgBufID(byte status, volatile unsigned long *id, volatile byte *ext, volatile byte *rtrBit, volatile byte *len, volatile byte *buf)
      byte rc=CAN_NOMSG;
      if ( status & MCP_RX0IF )                                        // Msg in Buffer 0
        mcp2515_read_canMsg( MCP_READ_RX0, id, ext, rtrBit, len, buf);
        rc = CAN_OK;
      else if ( status & MCP_RX1IF )                                   // Msg in Buffer 1
        mcp2515_read_canMsg( MCP_READ_RX1, id, ext, rtrBit, len, buf);
        rc = CAN_OK;
      if (rc==CAN_OK) {
        rtr=*rtrBit;
        // dta_len=*len; // not used on any interface function
        ext_flg=*ext;
        can_id=*id;
      } else {
        *len=0;
      return rc;
    ** Function name:           readRxTxStatus
    ** Descriptions:            Read RX and TX interrupt bits. Function uses status reading, but translates.
    **                          result to MCP_CANINTF. With this you can check status e.g. on interrupt sr
    **                          with one single call to save SPI calls. Then use checkClearRxStatus and
    **                          checkClearTxStatus for testing.
    byte MCP_CAN::readRxTxStatus(void)
      byte ret=( mcp2515_readStatus() & ( MCP_STAT_TXIF_MASK | MCP_STAT_RXIF_MASK ) );
      ret=(ret & MCP_STAT_TX0IF ? MCP_TX0IF : 0) |
          (ret & MCP_STAT_TX1IF ? MCP_TX1IF : 0) |
          (ret & MCP_STAT_TX2IF ? MCP_TX2IF : 0) |
          (ret & MCP_STAT_RXIF_MASK); // Rx bits happend to be same on status and MCP_CANINTF
      return ret;
    ** Function name:           checkClearRxStatus
    ** Descriptions:            Return first found rx CANINTF status and clears it from parameter.
    **                          Note that this does not affect to chip CANINTF at all. You can use this
    **                          with one single readRxTxStatus call.
    byte MCP_CAN::checkClearRxStatus(byte *status)
      byte ret;
      ret = *status & MCP_RX0IF; *status &= ~MCP_RX0IF;
      if ( ret==0 ) { ret = *status & MCP_RX1IF; *status &= ~MCP_RX1IF; }
      return ret;
    ** Function name:           checkClearTxStatus
    ** Descriptions:            Return specified buffer of first found tx CANINTF status and clears it from parameter.
    byte MCP_CAN::checkClearTxStatus(byte *status, byte iTxBuf)
      byte ret;
      if ( iTxBuf<MCP_N_TXBUFFERS ) { // Clear specific buffer flag
        ret = *status & txIfFlag(iTxBuf); *status &= ~txIfFlag(iTxBuf);
      } else {
        ret=0;
        for (byte i = 0; i < MCP_N_TXBUFFERS-nReservedTx; i++) {
          ret = *status & txIfFlag(i);
          if ( ret!=0 ) {
            *status &= ~txIfFlag(i);
            return ret;
      return ret;
    ** Function name:           clearBufferTransmitIfFlags
    ** Descriptions:            Clear transmit interrupt flags for specific buffer or for all unreserved buffers.
    **                          If interrupt will be used, it is important to clear all flags, when there is no
    **                          more data to be sent. Otherwise IRQ will newer change state.
    void MCP_CAN::clearBufferTransmitIfFlags(byte flags)
      flags &= MCP_TX_INT;
      if ( flags==0 ) return;
      mcp2515_modifyRegister(MCP_CANINTF, flags, 0);
    ** Function name:           checkReceive
    ** Descriptions:            check if got something
    uint8_t checkReceive(void)
        uint8_t res;
        res = mcp2515_readStatus();                                         // RXnIF in Bit 1 and 0
        return ((res & MCP_STAT_RXIF_MASK)?CAN_MSGAVAIL:CAN_NOMSG);
    ** Function name:           checkError
    ** Descriptions:            if something error
    byte MCP_CAN::checkError(void)
        byte eflg = mcp2515_readRegister(MCP_EFLG);
        return ((eflg & MCP_EFLG_ERRORMASK) ? CAN_CTRLERROR : CAN_OK);
    ** Function name:           getCanId
    ** Descriptions:            when receive something, you can get the can id!!
    unsigned long MCP_CAN::getCanId(void)
        return can_id;
    ** Function name:           isRemoteRequest
    ** Descriptions:            when receive something, you can check if it was a request
    byte MCP_CAN::isRemoteRequest(void)
        return rtr;
    ** Function name:           isExtendedFrame
    ** Descriptions:            did we just receive standard 11bit frame or extended 29bit? 0 = std, 1 = ext
    byte MCP_CAN::isExtendedFrame(void)
        return ext_flg;
    ** Function name:           mcpPinMode
    ** Descriptions:            switch supported pins between HiZ, interrupt, output or input
    bool MCP_CAN::mcpPinMode(const byte pin, const byte mode)
        byte res;
        bool ret=true;
        switch(pin)
            case MCP_RX0BF:
                switch(mode) {
                    case MCP_PIN_HIZ:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B0BFE, 0);
                    case MCP_PIN_INT:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B0BFM | B0BFE, B0BFM | B0BFE);
                    case MCP_PIN_OUT:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B0BFM | B0BFE, B0BFE);
    #if DEBUG_EN
                        Serial.print("Invalid pin mode request\r\n");
                        return false;
                return true;
            case MCP_RX1BF:
                switch(mode) {
                    case MCP_PIN_HIZ:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B1BFE, 0);
                    case MCP_PIN_INT:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B1BFM | B1BFE, B1BFM | B1BFE);
                    case MCP_PIN_OUT:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B1BFM | B1BFE, B1BFE);
    #if DEBUG_EN
                        return false;
                return true;
            case MCP_TX0RTS:
                if(res > 0)
    #if DEBUG_EN
                    Serial.print("Entering Configuration Mode Failure...\r\n");
    #else
                    delay(10);
                    return false;
                switch(mode) {
                    case MCP_PIN_INT:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B0RTSM, B0RTSM);
                    case MCP_PIN_IN:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B0RTSM, 0);
    #if DEBUG_EN
                        ret=false;
                if(res)
    #if DEBUG_EN
                    Serial.print("`Setting ID Mode Failure...\r\n");
    #else
                    delay(10);
                    return false;
                return ret;
            case MCP_TX1RTS:
                if(res > 0)
    #if DEBUG_EN
    #else
                    delay(10);
                    return false;
                switch(mode) {
                    case MCP_PIN_INT:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B1RTSM, B1RTSM);
                    case MCP_PIN_IN:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B1RTSM, 0);
    #if DEBUG_EN
                        ret=false;
                if(res)
    #if DEBUG_EN
    #else
                    delay(10);
                    return false;
                return ret;
            case MCP_TX2RTS:
                if(res > 0)
    #if DEBUG_EN
    #else
                    delay(10);
                    return false;
                switch(mode) {
                    case MCP_PIN_INT:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B2RTSM, B2RTSM);
                    case MCP_PIN_IN:
                        mcp2515_modifyRegister(MCP_TXRTSCTRL, B2RTSM, 0);
    #if DEBUG_EN
                        ret=false;
    			if(res)
    #if DEBUG_EN
    #else
                    delay(10);
                    return false;
                return ret;
    #if DEBUG_EN
                Serial.print("Invalid pin for mode request\r\n");
                return false;
    ** Function name:           mcpDigitalWrite
    ** Descriptions:            write HIGH or LOW to RX0BF/RX1BF
    bool MCP_CAN::mcpDigitalWrite(const byte pin, const byte mode) {
        switch(pin)
            case MCP_RX0BF:
                switch(mode) {
                    case HIGH:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B0BFS, B0BFS);
                        return true;
                        mcp2515_modifyRegister(MCP_BFPCTRL, B0BFS, 0);
                        return true;
            case MCP_RX1BF:
                switch(mode) {
                    case HIGH:
                        mcp2515_modifyRegister(MCP_BFPCTRL, B1BFS, B1BFS);
                        return true;
                        mcp2515_modifyRegister(MCP_BFPCTRL, B1BFS, 0);
                        return true;
    #if DEBUG_EN
                Serial.print("Invalid pin for mcpDigitalWrite\r\n");
                return false;
    ** Function name:           mcpDigitalRead
    ** Descriptions:            read HIGH or LOW from supported pins
    byte MCP_CAN::mcpDigitalRead(const byte pin) {
        switch(pin)
            case MCP_RX0BF:
                if((mcp2515_readRegister(MCP_BFPCTRL) & B0BFS) > 0)
                    return HIGH;
                    return LOW;
            case MCP_RX1BF:
                if((mcp2515_readRegister(MCP_BFPCTRL) & B1BFS) > 0)
                    return HIGH;
                    return LOW;
            case MCP_TX0RTS:
                if((mcp2515_readRegister(MCP_TXRTSCTRL) & B0RTS) > 0)
                    return HIGH;
                    return LOW;
            case MCP_TX1RTS:
                if((mcp2515_readRegister(MCP_TXRTSCTRL) & B1RTS) > 0)
                    return HIGH;
                    return LOW;
            case MCP_TX2RTS:
                if((mcp2515_readRegister(MCP_TXRTSCTRL) & B2RTS) > 0)
                    return HIGH;
                    return LOW;
    #if DEBUG_EN
                Serial.print("Invalid pin for mcpDigitalRead\r\n");
                return LOW;
      END FILE
    mcp_can.hmcp_can_dfs.h
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #define DEVICE_NAME                     "BLE_CAN_CONTROLLER"                       /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_start(bool erase_bonds);
    / CAN MCP2515 Include Files
    #include "inttypes.h"
    #include "SEGGER_RTT.h"
    #include "nrfx_spim.h"
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           ret_code_t err_code;
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                           ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
        /* YOUR_JOB: Add code to initialize the services used by the application.
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Template example started.");
        application_timers_start();
        advertising_start(erase_bonds);
            // Setup CAN Interface.
    	NRF_LOG_INFO("Start\n");
    	START_INIT:
    	if(mcp_can_begin(CAN_500KBPS, MCP_16MHz) == CAN_OK)
    		NRF_LOG_INFO("CAN initialization ok");
    		NRF_LOG_INFO("Can initialization failed\t");
    		NRF_LOG_INFO("Init Can bus again\n");
    		nrf_delay_ms(1000);
    		goto START_INIT;
        // Enter main loop.
        for (;;)
            uint8_t values[5];
              nrf_delay_ms(10);
    I think I'm getting through the initialization because the setup is checking if the received is 0x00, which is what I'm only getting. What could be a cause of no response from the MCP2515 do you think?
    Thanks!
  • Try correcting this error and see if that helps:
    Should be
    void mcp2515_spi_transfer(uint8_t *p_tx_data, uint8_t *p_rx_data, const uint16_t len)
        memset(p_rx_data, 0, len);
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&can_spi, p_tx_data, len, p_rx_data, len));
    In the first case you are using the address of a byte parameter on the stack, not the address of the buffers you require.
    You might also try increasing the drive of the SCK output pin to H0H1, just until you have everything working. This must be done after initialising the SPI which sets that output pin to S0S1. If the CAN chip is off-board maybe long leads or capacitance issues are corrupting transfers, although unlikely at 250kHz
