Some clarity on Gazell packet rates needed
I'm a little confused by the packet rate I'm getting on Gazell. Or rather I'm confused by the low number of 'timeouts' I'm seeing - I'd expect to see more, and would like to understand why I'm not.
I'm currently using mostly default settings for Device and Host, i.e. timeslot period = 600us, rate  = 2Mbps, 2 timeslots/channel, 5 channels in the table. I have the channel selection policy set to 'use current' so that the Device hops with the Host, and I'm seeing 1 packet every 1.2ms on average, which makes sense for imperfect frame sychronisation. But what puzzles me is that surely I should see a transmission timeout / failure reported for every timeslot when the Device and Host have slipped out by 1 channel?  If sycnhronisation was perfect I'd expect to get a successful transaction every 600us, or 2 per channel, but as I see half that then I would expect the number of failed transactions to roughly equal the number of successful transactions, but I only see a very small handful reported, typically < 10. What am I missing ? Is there another failure 'bucket' that I'm not watching ?
When I change the channel selection policy to 'use successful' the rate drops down by a fact of 10, which I now understand. But again, the reported failures are very low. Does the Device stop transmitting on that channel until it know when the Host will have [probably] returned? And does it only attempt 1 packet transmission on that last successful channel, knowing that the Host is unlikely to receive 2 ? Or does it continue attempting transmission on all slots, eventually getting an Ack from the Host when it comes back on channel?  I assume not as it would be a waste of power.
Pete
    There is drift between device and host and there is no time information in any of the packets. So the device simply synchronize to the last successful transmit acknowledgement. This successful exchange may have happened at any time with the 600us * 2 "window" (2 is required to ensure that independent of packets size in either direction 1 complete transmit + ack is guaranteed to get through on the channel, even due to drift in clocks between the two peers). So it is not designed to do more than 1 packet in each 1.2ms window in best case.
    Kenneth
  • Thanks for the reply Kenneth. I missed the bit in the user guide where it says that the timeslot counter resets to 0 when the Ack is received, and an attempt to send the next new packet is only made when the counter rolls back to 0, which makes sense.
    Regards
    Pete
