It's cool to have a build_all.sh script that supports so many cross-compilers. I've one more small request.
If run from a tool like CMake, the make tool does not pick up that multiple cores can be used. So, say we define an external target:
ADD_CUSTOM_TARGET(micro_eec
COMMAND chmod u+x build_all.sh WORKING_DIRECTORY ${NRF5_DIR}/external/micro-ecc
COMMAND ${CMAKE_COMMAND} -E env "GNU_INSTALL_ROOT=${WORKSPACE_DIR}/tools/gcc_arm_none_eabi/bin/" ./build_all.sh WORKING_DIRECTORY ${NRF5_DIR}/external/micro-ecc
COMMENT "Build micro-eec
This will lead to the following error messages:
make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf51_armgcc/armgcc/micro_ecc_lib_nrf51.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf51_iar/armgcc/micro_ecc_lib_nrf51.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf51_keil/armgcc/micro_ecc_lib_nrf51.lib Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52hf_armgcc/armgcc/micro_ecc_lib_nrf52.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52hf_iar/armgcc/micro_ecc_lib_nrf52.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52hf_keil/armgcc/micro_ecc_lib_nrf52.lib Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52nf_armgcc/armgcc/micro_ecc_lib_nrf52.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52nf_iar/armgcc/micro_ecc_lib_nrf52.a Done make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule. Creating library: ../../nrf52nf_keil/armgcc/micro_ecc_lib_nrf52.lib Done
Note that it's of course just a warning and by setting MAKEFILE=-j1 as additional environment variable it is "solved" as well. Just informing though about breaking parallel builds when run from a parent make process!
