Hello ,
I use SDK 15.3, chip is nRF52811
If I want to use DMA+SPI, is there a reference example?
Is this DMA called easyDMA?
Thanks
Hello ,
Thanks
Hi Tony
Yes, there should be multiple SPI examples in the \..\SDK15.3\examples\peripheral folder, and you should be able to enable DMA (EasyDMA) on all of them using the sdk_config.h file.
Simon
Thank you for your reply.
I still don't understand
In sdk_config.h, I did find easyDMA
Then, in main.c, the while(1) loop inside the main function
Have the following line of code
nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length)
This SPI transmission method is DMA?
Thank you.
Hi
Correct, when SPI_USE_EASY_DMA is enabled the SPI transactions will use (Easy)DMA. You should be able to confirm it by seeing a small current increase when EasyDMA is enabled, as opposed to when this is disabled. And yes, this is the only necessary step to enable/disable DMA in the SPI example.
Simon
