Bluetooth Mesh JSON
Greetings to all,
I'm using nRF52840 with the latests SDKs (nRF5 SDK 15.3.0, mesh SDK 3.2.0). I have two questions which are related-
I'm trying to find a clever way of storing all the provisioning data in flash and be able to export it to a JSON file that could be used to reconfigure a provisioner in case of malfunction of another.
Question 1: Is there a recommended way of storying the provisioned network data in flash and export it? I want to use one of the nodes solely with a nRF52840 to serve as a client to some mesh-models  and as a provisioner. Therefore, this should be a solution contained within the firmware using the Nordic SDKs and any external libraries that may be required.
I was inspecting the JSON file created (by version 2.0.5 of the nRFMesh App for Android) when one exports the Network Settings. There are a few fields I can't understand what they are. I have highlighted them in bold.
Question 2: Could someone please explain to me what are the meaning of the fields I highlighted in bold?
In the netKeys section:
 "netKeys": [
      "name": "Network Key 1",
      "index": 0,
      "key": "5992E9C7DEE2334BA76BDD2B14FF5A3D",
      "phase": 0,
      "minSecurity": "high",
      "timestamp": "1970-01-01T01:00:00+0100"
What are the "phase" and "minSecurity" fields for?
Here is the case for one of the nodes:
      "UUID": "C4FB244B3D5CE042A124D63E0627A21A",
      "name": "nRF5x Mesh Light",
      "deviceKey": "5AAF66D1CE7EBF395EC26214B80FE4B4",
      "unicastAddress": "0002",
      "security": "low",
      "configComplete": false,
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": "0028",
      "features": {
        "friend": 2,
        "lowPower": 2,
        "proxy": 1,
        "relay": 1
      "defaultTTL": 4,
      "networkTransmit": {
        "count": 2,
        "interval": 1
      "netKeys": [
          "index": 0,
          "updated": false
      "appKeys": [
          "index": 0,
          "updated": false
      "elements": [
          "name": "Element: 0x0002",
          "index": 0,
          "location": "0000",
          "models": [
              "modelId": "0000",
              "bind": [],
              "subscribe": []
              "modelId": "0002",
              "bind": [],
              "subscribe": []
              "modelId": "1000",
              "bind": [
                0
              "subscribe": [],
              "publish": {
                "address": "FFFF",
                "index": 0,
                "ttl": 1,
                "period": 2560,
                "retransmit": {
                  "count": 1,
                  "interval": 1
                "credentials": 0
      "blacklisted": false
What are the "cid", "pid", "vid", "crpl", location, bind, updated and credentials fields?
Also in the groups section, what is the parentAddress?
  "groups": [
      "name": "DemoDevices",
      "address": "C000",
      "parentAddress": "0000"
Thank you very much for your assistance!
//E
