Bluetooth disconnects when notification enabled
I'm using SDK 15.2. The bluetooth disconnects when I enable notifications on nrfConnect. This happens only if I increase the number of bytes to be sent. I'm writing a code for custom gatt. The references I used were -
https://github.com/maidenone/custom_ble_service_example
https://devzone.nordicsemi.com/nordic/short-range-guides/b/bluetooth-low-energy/posts/ble-characteristics-a-beginners-tutorial
My code files -
#include "sdk_common.h"
#include "ble_srv_common.h"
#include "ble_cus.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
/**@brief Function for handling the Connect event.
 * @param[in]   p_cus       Custom Service structure.
 * @param[in]   p_ble_evt   Event received from the BLE stack. */
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_CONNECTED;
    p_cus->evt_handler(p_cus, &evt);
/**@brief Function for handling the Disconnect event.
static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    UNUSED_PARAMETER(p_ble_evt);
    p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
    ble_cus_evt_t evt;
    evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
/**@brief Function for handling the Write event.
static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
	ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    // Custom Value Characteristic Written to.
    if (p_evt_write->handle == p_cus->custom_value_handles.value_handle)
        nrf_gpio_pin_toggle(LED_4);
        NRF_LOG_INFO("GOT WRITE ON: %d",*p_evt_write->data);
        if(*p_evt_write->data == 0x01)
            nrf_gpio_pin_clear(LED_3);
        else if(*p_evt_write->data == 0x02)
            nrf_gpio_pin_set(LED_3);
          //Do nothing
    // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
    if ((p_evt_write->handle == p_cus->custom_value_handles.cccd_handle) && (p_evt_write->len == 2))
        // CCCD written, call application event handler
        if (p_cus->evt_handler != NULL)
            ble_cus_evt_t evt;
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
                evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
            // Call the application event handler.
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
    ble_cus_t * p_cus = (ble_cus_t *) p_context;
    NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
    if (p_cus == NULL || p_ble_evt == NULL)
        return;
        case BLE_GAP_EVT_CONNECTED:
            on_connect(p_cus, p_ble_evt);
            on_disconnect(p_cus, p_ble_evt);
        case BLE_GATTS_EVT_WRITE:
            on_write(p_cus, p_ble_evt);
/* Handling this event is not necessary
        case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
            NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n");
            break;*/
            // No implementation needed.
/**@brief Function for adding the Custom Value characteristic.
 * @param[in]   p_cus_init   Information needed to initialize the service.
 * @return      NRF_SUCCESS on success, otherwise an error code. */
static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    uint32_t            err_code;
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_md_t cccd_md;
    ble_gatts_attr_t    attr_char_value;
    ble_uuid_t          ble_uuid;
    ble_gatts_attr_md_t attr_md;
    // Add Custom Value characteristic
    memset(&cccd_md, 0, sizeof(cccd_md));
    //  Read  operation on cccd should be possible without authentication.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read   = 1;
    char_md.char_props.write  = 1;
    char_md.char_props.notify = 1;
    char_md.p_char_user_desc  = NULL;
    char_md.p_char_pf         = NULL;
    char_md.p_user_desc_md    = NULL;
    char_md.p_cccd_md         = &cccd_md;
    char_md.p_sccd_md         = NULL;
    ble_uuid.type = p_cus->uuid_type;
    ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
    memset(&attr_md, 0, sizeof(attr_md));
    attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
    attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth    = 0;
    attr_md.wr_auth    = 0;
    attr_md.vlen       = 0;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid    = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len  = sizeof(uint8_t);
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = sizeof(uint8_t);
    err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md, &attr_char_value, &p_cus->custom_value_handles);
    if (err_code != NRF_SUCCESS)
        return err_code;
    return NRF_SUCCESS;
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    if (p_cus == NULL || p_cus_init == NULL)
        return NRF_ERROR_NULL;
    uint32_t   err_code;
    // Initialize service structure
    p_cus->evt_handler               = p_cus_init->evt_handler;
    // Add Custom Service UUID
    ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
    err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.uuid = CUSTOM_SERVICE_UUID;
    // Add the Custom Service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
        return err_code;
    return custom_value_char_add(p_cus, p_cus_init);
uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value[20])	/*NEW CHANGE*/
    NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
    if (p_cus == NULL)
    uint32_t err_code = NRF_SUCCESS;
    ble_gatts_value_t gatts_value;
    // Initialize value struct.
    memset(&gatts_value, 0, sizeof(gatts_value));
    gatts_value.len     = 20*sizeof(uint8_t);	/*NEW CHANGE*/
    gatts_value.offset  = 0;
    gatts_value.p_value = &custom_value[0];
    // Update database.
    err_code = sd_ble_gatts_value_set(p_cus->conn_handle, p_cus->custom_value_handles.value_handle, &gatts_value);
        return err_code;
    // Send value if connected and notifying.
    if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_cus->custom_value_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = gatts_value.offset;
        hvx_params.p_len  = &gatts_value.len;
        hvx_params.p_data = gatts_value.p_value;
        err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
        NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
        err_code = NRF_ERROR_INVALID_STATE;
        NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
    return err_code;
ble_cus.h
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log_ctrl.h"
/*new*/
#define DEVICE_NAME                     "Forte"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
/*new*/
#define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(100)
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
/*new*/
BLE_CUS_DEF(m_cus);
APP_TIMER_DEF(m_notification_timer_id);
/*new*/
static uint8_t m_custom_value = 0;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
/*static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
/*new*/
ble_uuid_t m_adv_uuids[] = {{CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN }}; /**< Universally unique service identifiers. */
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
	ret_code_t err_code;
    //pm_handler_on_pm_evt(p_evt);
    //pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
		case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
		case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.", ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle, p_evt->params.conn_sec_succeeded.procedure);
        } break;
		case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons. Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters. Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it. How to handle this error is highly application dependent. */
        } break;
		case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
		case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            advertising_start(false);
		case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
		case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
		case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
		case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // This can happen when the local DB has changed.
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the app_start_timer() call to the timeout handler. */
static void notification_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    // Increment the value of m_custom_value before nortifing it.
    m_custom_value++;
    err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
       APP_ERROR_CHECK(err_code);*/
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service. */
static void on_cus_evt(ble_cus_t     * p_cus_service, ble_cus_evt_t * p_evt)
    switch(p_evt->evt_type)
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
             err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
        case BLE_CUS_EVT_NOTIFICATION_DISABLED:
            err_code = app_timer_stop(m_notification_timer_id);
        case BLE_CUS_EVT_CONNECTED:
        case BLE_CUS_EVT_DISCONNECTED:
	ble_cus_init_t      cus_init = {0};/*new*/
	// Initialize CUS Service init structure to zero.
    cus_init.evt_handler                = on_cus_evt;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
    err_code = ble_cus_init(&m_cus, &cus_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
/**@brief Function for starting advertising. */
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry. */
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
	services_init();	/*new*/
    advertising_init();
    //services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
sdk_config.h
