nRF51822 rogram received signal SIGTRAP, Trace/breakpoint trap
I download my elf file using SEGGER Jlink via Eclipse. The instruction pointer gets positioned on the Reset_Handler. But when I try to run the code after that, I get a SIGTRAP and control doesn't hit "main".
However, when I use the command line gdb I don't get/have this issue. I have checked my eclipse IDE to remove all breakpoints. I have already power cycled the board and started from scratch.
Note : my board is BOARD_PCA10001.
Program received signal SIGTRAP, Trace/breakpoint trap
0xfffffffe in ?? ()
void Reset_Handler(void)
  unsigned long *pSrc, *pDst;
  /* Copy data segment initializers from flash to SRAM. */
  pSrc = &__etext;
  pDst = &__data_start__;
  while (pDst < &__data_end__)
    *pDst++ = *pSrc++;
When I pause to inspect the call stack I see this ...
nordic [GDB Hardware Debugging]
	fit-obj.elf
		Thread [1] <main> (Suspended : Signal : SIGTRAP:Trace/breakpoint trap)
			0xfffffffe
			<signal handler called>() at 0xfffffff9
			systemVectors() at 0x0
			0x0
	gdb
