NRF52832
SDK is 14
System has bootloader, softdevice s132 5.0.0 and app.
App uses FDS, FDS config:
NRF52832
SDK is 14
Virtual page size is 3 not 25
The number you specify with FDS_VIRTUAL_PAGES in sdk_config.h is used by pages_init(). It sees the last page before the bootloader as the last FDS page and uses the specified number of pages below that. During initialization, it checks all the FDS pages to see if it is already a valid FDS page (has a valid FDS page header). If so, it is used. If not, it checks if the page is empty. If it is, it is used. But if the page does not have a valid FDS header and is not empty, it is not touched.
This means that in order to expand the number of FDS pages you need to do two things:
I also have the same settings as him, but I am using sdk17. Due to product design issues, I cannot start after upgrading to dfu. So, if I want to increase the size of fds, can I only modify the "FDS.VIRTUAL-PAGES" value of the application?
Looking forward to your reply, thank you.
