Passing data from PDM callback to USB audio device
I'm trying to pass audio data from PDM callback function to a USB device and I'm kind of stuck.
Background:
I'm using the nRF52840-DK board and 2 MP34DT05-A microphones. Since there is no PDM example in the SDK I took the liberty of writing the code from scratch based on the non-legacy PDM driver. It is very similar to I2S in design so didnt take much to make it work. To verify that it works I used fstorage library to save the samples into memory nd then Segger J-Flash to dump contents to file on a windows computer and the WaveSurfer to make sure it is actual audio data. (basically up to date code and applications described here)
IT WORKED
Here is a snippet of the relevant code in my program:
static void nrfx_pdm_event_handler(nrfx_pdm_evt_t const *const p_evt) {
	/*NRF_LOG_INFO("nrfx_pdm_event_handler(buffer_released:%d buffer_requested:%d error:%d)",
			p_evt->buffer_released == NULL ? 0 : 1,
			p_evt->buffer_requested ? 1 : 0,
			p_evt->error);*/
	// we have an error ?
	if (p_evt->error != NRFX_PDM_NO_ERROR) {
		NRF_LOG_INFO("PDM error event: %d", p_evt->error);
		return;
	// got a buffer with data ?
	if (p_evt->buffer_released != NULL) {
		// we have buffer ready
		audio_buffer_txed = 0;
		// do we have space to write ?
		if (flash_addr + NRFX_PDM_BUFFER_SIZE*2 < FSTORAGE_END_ADDR) {
			if (fstorage_write_done /*nrf_fstorage_is_busy(&fstorage_instance)*/) {
				// write to flash
				fstorage_write_done = 0;
				ret_code_t rc = nrf_fstorage_write(
					&fstorage_instance,     /* The instance to use. */
					flash_addr,             /* The address in flash where to store the data. */
					p_evt->buffer_released, /* A pointer to the data. */
					NRFX_PDM_BUFFER_SIZE*2, /* Lenght of the data, in bytes. */
					NULL                    /* Optional parameter, backend-dependent. */
				if (rc != NRF_SUCCESS)
					NRF_LOG_ERROR("nrf_fstorage_write() = %d", rc);
			} else NRF_LOG_ERROR("fstorage busy -> dumping buffer");
	// expected to set a new buffer ?
	if (p_evt->buffer_requested) {
		NRF_LOG_INFO("PDM buffer requested");
		// update buffer index
		pdm_buffer_i = pdm_buffer_i == 0 ? 1 : 0;
		// set new buffer
		nrfx_pdm_buffer_set(pdm_buffer[pdm_buffer_i], NRFX_PDM_BUFFER_SIZE);
    nrfx_pdm_config_t config = NRFX_PDM_DEFAULT_CONFIG(ARDUINO_SCL_PIN, ARDUINO_SDA_PIN);
    ret = nrfx_pdm_init(&config, nrfx_pdm_event_handler);
    APP_ERROR_CHECK(ret);
Now, the problem I'm facing is how to pass that data to a USB audio device.
I started with the USB audio device example in the SDK and stripped all the headphones related code since it is irrelevant.
When I looked at the code I could see that the function app_usbd_audio_class_tx_start() that actually passes data to the USB device is called inside the SOF handler of the headphones.
I needed to find a new home for it ..
My naive first attempt was to place it directly inside the PDM handler (where fstorage_write_done() is right now). To cut a long story short - it didnt work, it returns with code 8 (invalid state). So I went to the documentation and it says there that writing can only occur during an SOF event. (and it has a small example here that I tried to use).
I came up with this code (which doesnt work .. same old return code 8 - invalid state):
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SOF:
	    // make sure we're in proper state (configured)
            if (APP_USBD_STATE_Configured != app_usbd_core_state_get()) break;
            // are we in the middle of a transfer ?
            if (!usb_tx_done) break;
            // do we have a buffer ready for transfer ?
            if (audio_buffer_txed) break;
        	// transfer the off-line buffer to the USB device now
            usb_tx_done = 0;
            ret_code_t ret = app_usbd_audio_class_tx_start(&m_app_audio_microphone.base,
        			pdm_buffer[pdm_buffer_i == 0 ? 1 : 0], NRFX_PDM_BUFFER_SIZE);
            // haven't started transferring -> wont reach TX done
            if (ret != NRF_SUCCESS) {
            	usb_tx_done = 1;
            	NRF_LOG_INFO("APP_USBD_EVT_DRV_SOF -> app_usbd_audio_class_tx_start = %d", ret);
            // this buffer is being transferred
            else audio_buffer_txed = 1;
My question is - how can I pass the data from the PDM callback to the USB device reliably with no errors ?
Remark #1:
In the code snippets I attached the "// ." signify mode code there that I didnt bother to attach.
Remark #2:
I didnt change anything in the definition of the USB microphone which might be a problem.
Especially the following line:
#define MIC_INTERFACES_CONFIG() APP_USBD_AUDIO_CONFIG_IN(2, 3)
When I connect the board to a Linux machine and look at dmesg output I get a warning/error that max interface should be 1. I guess the 2 and 3 values here are wrong.
Remark #3:
I read in the documentation that the isochroneous USB device can have a maximum buffer size of 1000 bytes, so I use a double buffer of 500 int16_t for the PDM:
// buffers for the PDM source
#define NRFX_PDM_BUFFER_SIZE 500
static volatile int8_t pdm_buffer_i = 0;
static int16_t pdm_buffer[2][NRFX_PDM_BUFFER_SIZE];
  • Is there no way you can strip away the PDM for now so I may run this on a devkit without PDM?
    Kenneth
  • You dont need to strip the PDM parts, it will perform just the same without microphones connected and will fill the buffers with trash.
    The USB part will still behave the same
  • Unfortunately I am not able to take time to sit down and debug your project at the moment, but if you can send me the precompiled hex file I can take a quick look at the USB sniffer trace.
  • I'm attaching here all information that might be relevant
    Linux dmesg:
    [590038.946652] usb 1-3: new full-speed USB device number 6 using xhci_hcd
    [590039.097423] usb 1-3: New USB device found, idVendor=1915, idProduct=521a
    [590039.097430] usb 1-3: New USB device strings: Mfr=1, Product=1, SerialNumber=1
    [590039.097434] usb 1-3: Product: 000000000000
    [590039.097437] usb 1-3: Manufacturer: 000000000000
    [590039.097439] usb 1-3: SerialNumber: 000000000000
    [590109.320154] retire_capture_urb: 431 callbacks suppressed
    [590153.033160] retire_capture_urb: 708 callbacks suppressed
    Query USB device under Linux (lsusb -d 1915:521a -v):
    Bus 001 Device 006: ID 1915:521a Nordic Semiconductor ASA
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x1915 Nordic Semiconductor ASA
      idProduct          0x521a
      bcdDevice            1.00
      iManufacturer           1
      iProduct                1
      iSerial                 1
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength          113
        bNumInterfaces          2
        bConfigurationValue     1
        iConfiguration          4
        bmAttributes         0xc0
          Self Powered
        MaxPower              100mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceClass         1 Audio
          bInterfaceSubClass      1 Control Device
          bInterfaceProtocol      0
          iInterface              0
          AudioControl Interface Descriptor:
            bLength                 9
            bDescriptorType        36
            bDescriptorSubtype      1 (HEADER)
            bcdADC               1.00
            wTotalLength           43
            bInCollection           1
            baInterfaceNr( 0)       1
            bLength                12
            bDescriptorType        36
            bDescriptorSubtype      2 (INPUT_TERMINAL)
            bTerminalID             1
            wTerminalType      0x0201 Microphone
            bAssocTerminal          0
            bNrChannels             2
            wChannelConfig     0x0003
              Left Front (L)
              Right Front (R)
            iChannelNames           0
            iTerminal               0
            bLength                13
            bDescriptorType        36
            bDescriptorSubtype      6 (FEATURE_UNIT)
            bUnitID                 2
            bSourceID               1
            bControlSize            2
            bmaControls( 0)      0x01
            bmaControls( 0)      0x00
              Mute Control
            bmaControls( 1)      0x01
            bmaControls( 1)      0x00
              Mute Control
            bmaControls( 2)      0x01
            bmaControls( 2)      0x00
              Mute Control
            iFeature                0
            bLength                 9
            bDescriptorType        36
            bDescriptorSubtype      3 (OUTPUT_TERMINAL)
            bTerminalID             3
            wTerminalType      0x0101 USB Streaming
            bAssocTerminal          0
            bSourceID               2
            iTerminal               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           0
          bInterfaceSubClass      2 Streaming
          iInterface              0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       1
          bNumEndpoints           1
          iInterface              0
          AudioStreaming Interface Descriptor:
            bLength                 7
            bDescriptorType        36
            bDescriptorSubtype      1 (AS_GENERAL)
            bTerminalLink           1
            bDelay                  0 frames
            wFormatTag              1 PCM
            bLength                11
            bDescriptorType        36
            bDescriptorSubtype      2 (FORMAT_TYPE)
            bFormatType             1 (FORMAT_TYPE_I)
            bNrChannels             2
            bSubframeSize           2
            bBitResolution         16
            bSamFreqType            1 Discrete
            tSamFreq[ 0]        16000
            AudioControl Endpoint Descriptor:
              bLength                 7
              bDescriptorType        37
              bDescriptorSubtype      1 (EP_GENERAL)
              bmAttributes         0x00
              bLockDelayUnits         0 Undefined
              wLockDelay              0 Undefined
            bLength                 9
            bDescriptorType         5
            bEndpointAddress     0x88  EP 8 IN
            bmAttributes            1
              Transfer Type            Isochronous
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval               1
            bRefresh                0
            bSynchAddress           0
    Full source code (main.c 414 lines based on usb_audio example):
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "app_util.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_drv_power.h"
    #include "nrf_drv_pdm.h"
    #include "app_usbd.h"
    #include "app_usbd_core.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_audio.h"
    #include "app_error.h"
    #include "boards.h"
    #include "nrf_fstorage_nvmc.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    // buffers for the PDM source (base NRFX_PDM_MAX_BUFFER_SIZE)
    #define NRFX_PDM_BUFFER_SIZE (32)
    static int8_t pdm_buffer_i = 0;
    static volatile uint8_t usb_tx_idle = 1, audio_buffer_ready = 0;
    #define LED_USB_RESUME (BSP_BOARD_LED_0)
    #define LED_USB_START  (BSP_BOARD_LED_1)
    #define LED_AUDIO_RX   (BSP_BOARD_LED_2)
    #define LED_AUDIO_TX   (BSP_BOARD_LED_3)
     * @brief Enable power USB detection
     * Configure if example supports USB port connection
    #ifndef USBD_POWER_DETECTION
    #define USBD_POWER_DETECTION true
     * @brief Audio class user event handler
    static void mic_audio_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                          app_usbd_audio_user_event_t   event);
    /* Channels and feature controls configuration */
     * @brief   Input terminal channel configuration
    #define MIC_TERMINAL_CH_CONFIG()        \
            (APP_USBD_AUDIO_IN_TERM_CH_CONFIG_LEFT_FRONT | APP_USBD_AUDIO_IN_TERM_CH_CONFIG_RIGHT_FRONT)
     * @brief   Feature controls
     *      general
     *      channel 0
     *      channel 1
    #define MIC_FEATURE_CONTROLS()        \
            APP_USBD_U16_TO_RAW_DSC(APP_USBD_AUDIO_FEATURE_UNIT_CONTROL_MUTE),                         \
    /* Microphone descriptors */
     * @brief   Audio class specific format descriptor
    APP_USBD_AUDIO_FORMAT_DESCRIPTOR(m_mic_form_desc,
                                     APP_USBD_AUDIO_AS_FORMAT_I_DSC(    /* Format type 1 descriptor */
                                        2,                              /* Number of channels */
                                        2,                              /* Subframe size */
                                        16,                             /* Bit resolution */
                                        1,                              /* Frequency type */
                                        APP_USBD_U24_TO_RAW_DSC(16000)) /* Frequency */
     * @brief   Audio class input terminal descriptor
    APP_USBD_AUDIO_INPUT_DESCRIPTOR(m_mic_inp_desc,
                                    APP_USBD_AUDIO_INPUT_TERMINAL_DSC(
                                        1,                                     /* Terminal ID */
                                        APP_USBD_AUDIO_TERMINAL_IN_MICROPHONE, /* Terminal type */
                                        MIC_TERMINAL_CH_CONFIG())              /* Channels config */
     * @brief   Audio class output terminal descriptor
    APP_USBD_AUDIO_OUTPUT_DESCRIPTOR(m_mic_out_desc,
                                     APP_USBD_AUDIO_OUTPUT_TERMINAL_DSC(
                                        3,                                     /* Terminal ID */
                                        APP_USBD_AUDIO_TERMINAL_USB_STREAMING, /* Terminal type */
                                        2)                                     /* Source ID */
     * @brief   Audio class feature unit descriptor
    APP_USBD_AUDIO_FEATURE_DESCRIPTOR(m_mic_fea_desc,
                                      APP_USBD_AUDIO_FEATURE_UNIT_DSC(
                                        2,                      /* Unit ID */
                                        1,                      /* Source ID */
                                        MIC_FEATURE_CONTROLS()) /* List of controls */
    /* Interfaces lists */
     * @brief Interfaces list passed to @ref APP_USBD_AUDIO_GLOBAL_DEF
    #define MIC_INTERFACES_CONFIG() APP_USBD_AUDIO_CONFIG_IN(0, 1)
    /*lint -save -e26 -e64 -e123 -e505 -e651*/
     * @brief Microphone Audio class instance
    APP_USBD_AUDIO_GLOBAL_DEF(m_app_audio_microphone,
                              MIC_INTERFACES_CONFIG(),
                              mic_audio_user_ev_handler,
                              &m_mic_form_desc,
                              &m_mic_inp_desc,
                              &m_mic_out_desc,
                              &m_mic_fea_desc,
                              0,
                              APP_USBD_AUDIO_AS_IFACE_FORMAT_PCM,
                              64,
                              APP_USBD_AUDIO_SUBCLASS_AUDIOSTREAMING
     * @brief Actual microphone mute state
    static uint8_t  m_mute_mic;
     * @brief Actual microphone sampling frequency
    static uint32_t m_freq_mic;
     * @brief Audio class specific request handle (microphone)
    static void mic_audio_user_class_req(app_usbd_class_inst_t const * p_inst)
        app_usbd_audio_t const * p_audio = app_usbd_audio_class_get(p_inst);
        app_usbd_audio_req_t * p_req = app_usbd_audio_class_request_get(p_audio);
        UNUSED_VARIABLE(m_mute_mic);
        UNUSED_VARIABLE(m_freq_mic);
        switch (p_req->req_target)
            case APP_USBD_AUDIO_CLASS_REQ_IN:
            	NRF_LOG_INFO("APP_USBD_AUDIO_CLASS_REQ_IN");
                if (p_req->req_type == APP_USBD_AUDIO_REQ_SET_CUR)
                    //Only mute control is defined
                    p_req->payload[0] = m_mute_mic;
            case APP_USBD_AUDIO_CLASS_REQ_OUT:
            	NRF_LOG_INFO("APP_USBD_AUDIO_CLASS_REQ_OUT");
                    m_mute_mic = p_req->payload[0];
                    NRF_LOG_INFO("m_mute_mic = %d", m_mute_mic);
            case APP_USBD_AUDIO_EP_REQ_IN:
            	NRF_LOG_INFO("APP_USBD_AUDIO_EP_REQ_IN");
            case APP_USBD_AUDIO_EP_REQ_OUT:
            	NRF_LOG_INFO("APP_USBD_AUDIO_EP_REQ_OUT");
                    //Only set frequency is supported
                	NRF_LOG_INFO("APP_USBD_AUDIO_EP_REQ_OUT -> APP_USBD_AUDIO_REQ_SET_CUR");
                    m_freq_mic = uint24_decode(p_req->payload);
            	NRF_LOG_INFO("mic_audio_user_class_req(default)");
     * @brief User event handler @ref app_usbd_audio_user_ev_handler_t (microphone)
        UNUSED_VARIABLE(p_audio);
        switch (event)
            case APP_USBD_AUDIO_USER_EVT_CLASS_REQ:
                mic_audio_user_class_req(p_inst);
            case APP_USBD_AUDIO_USER_EVT_TX_DONE:
            	usb_tx_idle = 1;
                bsp_board_led_invert(LED_AUDIO_TX);
                //NRF_LOG_INFO("mic frame txed");
            	NRF_LOG_INFO("mic_audio_user_ev_handler(default)");
     * @brief USBD library specific event handler.
     * @param event     USBD library event.
        switch (event)
            case APP_USBD_EVT_DRV_SETUP:
            	NRF_LOG_INFO("USB setup");
            case APP_USBD_EVT_DRV_SUSPEND:
            	NRF_LOG_INFO("USB suspend");
                bsp_board_leds_off();
            case APP_USBD_EVT_DRV_RESUME:
            	NRF_LOG_INFO("USB resume");
                bsp_board_led_on(LED_USB_RESUME);
            case APP_USBD_EVT_STARTED:
            	NRF_LOG_INFO("USB started");
                bsp_board_led_on(LED_USB_START);
                // start PDM
                APP_ERROR_CHECK(nrfx_pdm_start());
            case APP_USBD_EVT_STOPPED:
            	NRF_LOG_INFO("USB stopped");
            	// start PDM
            	APP_ERROR_CHECK(nrfx_pdm_stop());
                app_usbd_disable();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                app_usbd_start();
    static void mic_sof_ev_handler(uint16_t framecnt)
    	if (APP_USBD_STATE_Configured != app_usbd_core_state_get()) return;
    	if (!usb_tx_idle) return;
    	if (audio_buffer_ready == 0) return;
    	usb_tx_idle = 0;
    			pdm_buffer[pdm_buffer_i == 0 ? 1 : 0], NRFX_PDM_BUFFER_SIZE*2);
    		usb_tx_idle = 1;
    		NRF_LOG_ERROR("mic_sof_ev_handler() -> app_usbd_audio_class_tx_start() = %d", ret);
    		return;
    		// set new buffer
    		audio_buffer_ready = 1;
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler,
            .enable_sof = true
        ret = NRF_LOG_INIT(NULL);
        ret = nrf_drv_clock_init();
        NRF_LOG_INFO("USBD audio example started.");
        // Initialize LEDs and buttons
        bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_inst_mic =
            app_usbd_audio_class_inst_get(&m_app_audio_microphone);
        ret = app_usbd_audio_sof_interrupt_register(class_inst_mic, mic_sof_ev_handler);
        ret = app_usbd_class_append(class_inst_mic);
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
            app_usbd_enable();
            app_usbd_start();
        NRF_LOG_INFO("Entering main loop");
        while (true)
            while (app_usbd_event_queue_process())
                /* Nothing to do */
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            /* Sleep CPU only if there was no interrupt since last loop processing */
            __WFE();
    hex file (for nRF52840-DK):
    5241.nrf52840_xxaa.hex
    If you need anything else just say
  • Adding the USB sniffer file, I do believe you should be able to open it by downloading Ellisys Visual USB. Seems as the application does not reply to the first 'get device descriptor' from the USB host, instead the intended data is sent on the next 'get configuration descriptor'.
    Sniffer trace:
    Case_236141.zip
    Seems as the IN transaction from the nRF52840 which should be a response to 'get device descriptor', is instead replied on the next 'get configuration descriptors' from the USB host.
    For comparison see the USB audio reference:
    Case_236141_reference_usb_audio_sdk15.2.zip
