MCUBoot serial download support
I was trying to make sense of the serial support in mcuboot, but it uses a protocol and format I don't recognize.  I expect they're generated by the Apache Newt tools, since that's where mcuboot is originally from.
Is there an example anywhere showing how to use a serial recovery bootloader with NRF/Zephyr applications?
    Yes, the sample in ~/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr
    You need to set CONFIG_MCUMGR_SMP_UART=y,
    # Allow for large Bluetooth data packets.
    #CONFIG_BT_L2CAP_TX_MTU=260
    #CONFIG_BT_RX_BUF_LEN=260
    # Enable the Bluetooth and shell mcumgr transports.
    #CONFIG_MCUMGR_SMP_BT=y
    #CONFIG_MCUMGR_SMP_SHELL=y
    #Enable the Uart mcumgr transports.
    Might also need to set CONFIG_NET_BUF=y
    Build and flash mcuboot, then build and flash the smp_svr(sign the image with imgtool.py)
