Hello, I am using nrf5832 with SDK 15.3.0. I want to filter peripheral device based on mac address. I modified example code "\examples\ble_central\ble_app_blinky_c\pca10040\s132\ses " but unable to make it working. When I changing code to filter based on name its working fine. Please help.
Attaching main.c file. Thanks
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @brief BLE LED Button Service central and client application main file.
* This file contains the source code for a sample client application using the LED Button service.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_timer.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_lbs_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define CENTRAL_SCANNING_LED BSP_BOARD_LED_0 /**< Scanning LED will be on when the device is scanning. */
#define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1 /**< Connected LED will be on when the device is connected. */
#define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
#define LEDBUTTON_BUTTON_PIN BSP_BUTTON_0 /**< Button that will write to the LED characteristic of the peer */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance. */
BLE_LBS_C_DEF(m_ble_lbs_c); /**< Main structure used by the LBS client module. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
static char const m_target_periph_name[] = "RevOS_TEST"; /**< Name of the device we try to connect to. This name is searched in the scan report data*/
static char const m_target_periph_mac[6] = {0xf2, 0x2d, 0xBC, 0xCF, 0xAE, 0xE2};
/**@brief Function to handle asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning.
static void scan_start(void)
ret_code_t err_code;
err_code = nrf_ble_scan_start(&m_scan);
bsp_board_led_off(CENTRAL_CONNECTED_LED);
bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Handles events coming from the LED Button central module.
static void lbs_c_evt_handler(ble_lbs_c_t * p_lbs_c, ble_lbs_c_evt_t * p_lbs_c_evt)
switch (p_lbs_c_evt->evt_type)
case BLE_LBS_C_EVT_DISCOVERY_COMPLETE:
err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c,
p_lbs_c_evt->conn_handle,
&p_lbs_c_evt->params.peer_db);
NRF_LOG_INFO("LED Button service discovered on conn_handle 0x%x.", p_lbs_c_evt->conn_handle);
err_code = app_button_enable();
// LED Button service discovered. Enable notification of Button.
err_code = ble_lbs_c_button_notif_enable(p_lbs_c);
} break; // BLE_LBS_C_EVT_DISCOVERY_COMPLETE
case BLE_LBS_C_EVT_BUTTON_NOTIFICATION:
NRF_LOG_INFO("Button state changed on peer to 0x%x.", p_lbs_c_evt->params.button.button_state);
if (p_lbs_c_evt->params.button.button_state)
bsp_board_led_on(LEDBUTTON_LED);
bsp_board_led_off(LEDBUTTON_LED);
} break; // BLE_LBS_C_EVT_BUTTON_NOTIFICATION
// No implementation needed.
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// For readability.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
// Upon connection, check which peripheral has connected (HR or RSC), initiate DB
// discovery, update LEDs status and resume scanning if necessary. */
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
// Update LEDs status, and check if we should be looking for more
// peripherals to connect to.
bsp_board_led_on(CENTRAL_CONNECTED_LED);
bsp_board_led_off(CENTRAL_SCANNING_LED);
} break;
// Upon disconnection, reset the connection handle of the peer which disconnected, update
// the LEDs status and start scanning again.
NRF_LOG_INFO("Disconnected.");
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
// We have not specified a timeout for scanning, so only connection attemps can timeout.
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_DEBUG("Connection request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accept parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
} break;
case BLE_GATTS_EVT_TIMEOUT:
} break;
/**@brief LED Button client initialization.
static void lbs_c_init(void)
ble_lbs_c_init_t lbs_c_init_obj;
lbs_c_init_obj.evt_handler = lbs_c_evt_handler;
err_code = ble_lbs_c_init(&m_ble_lbs_c, &lbs_c_init_obj);
* @details Initializes the SoftDevice and the BLE event interrupts.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the button handler module.
* @param[in] pin_no The pin that the event applies to.
* @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case LEDBUTTON_BUTTON_PIN:
err_code = ble_lbs_led_status_send(&m_ble_lbs_c, button_action);
if (err_code != NRF_SUCCESS &&
err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
err_code != NRF_ERROR_INVALID_STATE)
if (err_code == NRF_SUCCESS)
NRF_LOG_INFO("LBS write LED state %d", button_action);
APP_ERROR_HANDLER(pin_no);
/**@brief Function for handling Scaning events.
* @param[in] p_scan_evt Scanning event.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
//The array must be static because a pointer to it will be saved in the button handler module.
static app_button_cfg_t buttons[] =
{LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_lbs_on_db_disc_evt(&m_ble_lbs_c, p_evt);
/**@brief Database discovery initialization.
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Function for initializing the log.
static void log_init(void)
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the Power manager. */
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
// Setting filters for scanning.
/* err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
APP_ERROR_CHECK(err_code);*/
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, m_target_periph_mac);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
// Initialize.
log_init();
timer_init();
leds_init();
buttons_init();
power_management_init();
ble_stack_init();
scan_init();
gatt_init();
db_discovery_init();
lbs_c_init();
// Start execution.
NRF_LOG_INFO("Blinky CENTRAL example started.");
scan_start();
// Turn on the LED to signal scanning.
// Enter main loop.
for (;;)
idle_state_handle();
