nrf52832 hangs in non-debug mode
We have custom developed board using nrf52832. When I run the example program developed in SDK15.0.0 with Soft device S132 V6.1.1, no issue noticed in running debug mode (with J-link Debugger) or non-debug mode.
 If we run the already developed code in SDK14.2.0 with soft device S132 V5.0.0, I didn’t see any issue on debug mode. As expected, peripherals are working and BLE communication started and sending data. Same setup, run in non-debug mode, noticed that it hangs on the while loop. Please advise any reason for this issue
  • 1. I enable the  DCDC in "sdk_config.h" and noticed that 1.265V @ DCC4 pin. Issue still exist. 1.265V Voltage at "DEC4" pin is acceptable level?
    2. One more suspect, before entering the while loop, we  call "nrf_drv_timer_ms_to_ticks" as below. When I include the test code to turn On/Off LED before and after this call, I noticed it doesn't work as expect. Not sure, this is the root cause. Please advise.
      /*Get Timer u32Ticks to provide 1sec transmission via BLE */
      u32PowerTicks = nrf_drv_timer_ms_to_ticks(&gstPOWER_TIMER, 1000);
      nrf_delay_ms(2000);
      while(true)
            /* Check button pressed or not */
        u32ErrCode = handle_push_button_functionality(&bStartAdvertise);
        if(NRF_SUCCESS != u32ErrCode)
    Any help is much appreciated.
    Thank You.
  • Ok, it doesn't appear to be related to the DCDC regulator. I was just trying to think of reasons as to why it only works in debug mode.
     Does the LED blink at all? nrf_drv_timer_ms_to_ticks() is only used to convert time in ms to timer 'ticks', it won't start your gstPOWER_TIMER instance.
  • Hi Vidar Berg,
    Thanks for your clarification.  LED is toggle one time only inside the “while” loop” and after first iteration, it hangs.
     Further debug on this issue, I noticed that end of the first iteration on the “while” loop,  it’s entered in to the low power mode. After that, it cannot be waked up by key press interrupt or Power timer interrupt (1 Sec. power timer) from our code. In the low power mode, we expect to be in the “System ON, Full RAM retention, Wake on any event”.
    In order to enter in low power mode “sd_app_evt_wait()” function is called originally in our code. When I change this to “__WFE()”,  I couldn’t noticed any hang issue on “while” loop on non-debug mode.
    Could you please advise possible root cause for this behaviour?  We suppose to have ultra-low power mode when the instrument is idle in order to save power.
  • sd_app_evt_wait() and __WFE() has the same effect, but  the Softdevice must be enabled before you can use sd_app_evt_wait(). The function which initializes and enables the Softdevice is usually named 'ble_stack_init()' in our code examples.
