My NRF52811 Custome board not working as my application.
1) I am using the PCA10040 to program a nrf52811 chip on a custom board with SDK 15.3.0.
2) I'm using the example ble_app_uart_pca10040_s112 on uKeilV5
3) Initially i tried to flash Softdevice and application using nRFgo Studio,
but when i connect my board with PCA10040's P20 connector, and nRFgo studio showing "recover" and "enable reset pin" boxes.
4) Then I am following the steps in Infocenter
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.3.0%2Fgetting_started_installing.html
for flashing SD and application code and it showing below attached text of JLInk segger.
ISSUE:-
1) As per "ble_app_uart_pca10040_s112" code LED_4(P0.20) should blink with delay of 1second but it is not working lke that but some extra port0 pins are showing high.
2) Actually my aim is to use custom board (NRF52811 SoC) for advertising ble and use mobile bluetooth app for communicating it(custom board)
for my application which softdevice should i use? S112 or S140 for NRF52811?
3) I read some where S112 won't support Codec PHY?
So please can anyone help me to come out of this problem.
Thank you in advance,
Rgds,
amarr
  • Thank you Jimmy wong,
    Can i use PCA10040 board as JLink programmer for my custom board which having NRF52811 SoC. I go through your shared link and downloaded and unzip it. but i  cannot open in keil as a project.  can you please suggest me how to use it?
    Thank you
  • HI,
    Yes, you can use the PCA10040 debug out to program your target board given VDD = 3.0V.
    YOu can use the Segger Embedded studio instead of KEIL for running the example.
  • Hi jimmy,
    Sorry for late replay. Present i am using PCA10040 Board for developing my application.
    As per my application i want to use Four ADC Channels (AIN0-AIN3) in NRF52832 From Four channels
    Two channels(AIN0 &AIN1) for reading two external batteries voltages and reamining two(AIN2 and AIN3)
    for reading external peripheral voltages.  From four ADC
    channels i  configured one ADC for for reading one external peripheral voltage like below attached source
    code.
    I think NRF52832 using one Buffer for serving to all four adc channels. am i right or wrong?
    But my aim is to use multiple ADCs  channels, How can i approch to do this? please suggest me.
    void saadc_init(void)
        ret_code_t err_code;
        nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);  //0.6v for vdd
        channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);  //This is the function call for ADC Default configuration
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
    		    err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            int i;
            for (i = 0; i < SAMPLES_IN_BUFFER; i++)
    	    	int neg_buffer = p_event->data.done.p_buffer[i];
    			if(neg_buffer < 0)
    				neg_buffer = 0;
    				printf("ADC Value = %d \r\n", neg_buffer); //amarr
    				p_event->data.done.p_buffer[i] = 0;
    				printf("ADC Value = %d \r\n", p_event->data.done.p_buffer[i]); //amarr
            m_adc_evt_counter++;
    	   printf("saadc_event_handler else condition: %d \n", p_event->type);
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
    	 /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
        uart_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        saadc_init();
    	saadc_sampling_event_init();
    	  nrf_delay_ms(3000);
        // Enter main loop.
    while(1)
    Thank you,
