"BLE_ERROR_GATTS_SYS_ATTR_MISSING" (0x3401) occurs during continuous BLE transmission
OS in development environment :Windows7
HARD :(Taiyo Yuden)EBSHSN Series Evaluation Board : Central / Peripherals
CPU :(Nordic) nRF52832 / ARMR Cortex-M4F 32 bit processor 28-pin Land Grid Array / 15GPIOs / SWD
Soft Ver:nRF5_SDK_15.3.0_59ac345
“BLE_ERROR_GATTS_SYS_ATTR_MISSING” occurs when 2k bytes of data are sent repeatedly.
Please tell me how to resolve.
* This does not occur when sending a single shot.
* Peripheral device for one central vs. 4 peripheral communication
* The central and peripheral settings are the same.
------------------------< Setting >-------------------------
/* Communication cycle: 15ms to 30ms */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) /**< Minimum acceptable connection interval (15 ms) */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum acceptable connection interval (30 ms) */
/* Data length: 247byte */
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
------------------------< program >-------------------------
do
      APP_ERROR_CHECK(err_code);   <---   (Error location)
} while (err_code == NRF_ERROR_RESOURCES);
Thanking you in advance
    You say that ble_nus_data_send() returns BLE_GATTS_VAR_ATTR_LEN_MAX only when you send a lot of data? Does that mean that it initially return NRF_SUCCES, and then after a while, it returns BLE_GATTS_VAR_ATTR_LEN_MAX? Or does it return BLE_GATTS_VAR_ATTR_LEN_MAX immediately (on the first attempt)?
    What does the following event in your ble_evt_handler() look like?
  • 1) Returns BLE_ERROR_GATTS_SYS_ATTR_MISSING when a large amount of data is sent. NRF_SUCCES is returned at first, and BLE_ERROR_GATTS_SYS_ATTR_MISSING is returned after a while.
    ”BLE_ERROR_GATTS_SYS_ATTR_MISSING is not returned from the beginning.
    2) The structure of the BLE_GATTS_EVT_SYS_ATTR_MISSING event of ble_evt_handler () is the same.
    The BLE_GATTS_EVT_SYS_ATTR_MISSING event of ble_evt_handler () does not occur.
  • Ok. Is it possible to reproduce this on a DK so that I can test this here in my office? I have not seen this return value coming "after a while". Only from the beginning.
  • There seems to be a problem with Central.
    Checked Central Error 4 occurred in UART communication.
  • So you receive the APP_UART_COMMUNICATION_ERROR event?
    Check line 117 in app_uart.h:
    uint32_t error_communication; /**< Field used if evt_type is: APP_UART_COMMUNICATION_ERROR. This field contains the value in the ERRORSRC register for the UART peripheral. The UART_ERRORSRC_x defines from nrf5x_bitfields.h can be used to parse the error code. See also the \nRFXX Series Reference Manual for specification. */
    So the ERRORSRC register is described here.
    If it has the value 4, it means D = 0, C = 1, B = 0, A = 0. C = 1 means framing error. Either you have an unaccurate clock in one end, or you have a floating input pin, so that the UART think it receives data which doesn't match the frames.
