Hi everyone
Program crashes after few minutes while trying to run two threads(GPS thread and a thread used for caculating the battery voltage) simultaneously.
* Copyright (c) 2019 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <nrf_socket.h>
#include <net/socket.h>
#include <stdio.h>
#include <device.h>
#include <sys/printk.h>
#include <at_cmd.h>
#include <sys/errno.h>
#include <sys/mutex.h>
//k_tid_t systemThread_id;
#define AT_XSYSTEMMODE "AT\%XSYSTEMMODE=0,0,1,0"
#define AT_CFUN "AT+CFUN=1"
#define battery_voltage "AT%XVBAT"
#define PRIORITY 7
#define STACK_SIZE (512 + CONFIG_TEST_EXTRA_STACKSIZE)
void gpsData();
void getBatteryVoltage();
K_THREAD_STACK_DEFINE(my_stack_area,STACK_SIZE);
K_THREAD_DEFINE(gps_id, STACK_SIZE,
gpsData, NULL, NULL, NULL,
PRIORITY, 0, K_NO_WAIT);
struct k_thread battery_voltage_data;
struct k_thread gps_data;
K_MUTEX_DEFINE(battery_data);
#ifdef CONFIG_BOARD_NRF9160_PCA10090NS
#define AT_MAGPIO "AT\%XMAGPIO=1,0,0,1,1,1574,1577"
static const char update_indicator[] = {'\\', '|', '/', '-'};
static const char at_commands[][31] = {
AT_XSYSTEMMODE,
AT_MAGPIO,
AT_CFUN
static int fd;
static char nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static u32_t nmea_string_cnt;
static bool got_first_fix;
static bool update_terminal;
static u64_t fix_timestamp;
nrf_gnss_data_frame_t last_fix;
int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
int err;
do {
err = recv(fd, buf, size, flags);
} while (err < 0 && errno == EAGAIN);
return err;
void bsd_recoverable_error_handler(uint32_t error)
printf("Err: %lu\n", (unsigned long)error);
void bsd_irrecoverable_error_handler(uint32_t error)
printf("Irrecoverable: %lu\n", (unsigned long)error);
static int enable_gps(void)
int at_sock;
int bytes_sent;
int bytes_received;
char buf[2];
at_sock = socket(AF_LTE, 0, NPROTO_AT);
if (at_sock < 0) {
return -1;
for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
bytes_sent = send(at_sock, at_commands[i],
strlen(at_commands[i]), 0);
if (bytes_sent < 0) {
close(at_sock);
return -1;
do {
bytes_received = recv(at_sock, buf, 2, 0);
} while (bytes_received == 0);
if (memcmp(buf, "OK", 2) != 0) {
close(at_sock);
return -1;
close(at_sock);
return 0;
static int init_app(void)
u16_t fix_retry = 0;
u16_t fix_interval = 1;
u16_t nmea_mask = NRF_CONFIG_NMEA_GSV_MASK |
NRF_CONFIG_NMEA_GSA_MASK |
NRF_CONFIG_NMEA_GLL_MASK |
NRF_CONFIG_NMEA_GGA_MASK |
NRF_CONFIG_NMEA_RMC_MASK;
int retval;
if (enable_gps() != 0) {
printk("Failed to enable GPS\n");
return -1;
fd = nrf_socket(NRF_AF_LOCAL, NRF_SOCK_DGRAM, NRF_PROTO_GNSS);
if (fd >= 0) {
printk("GPS Socket created\n");
} else {
printk("Could not init socket (err: %d)\n", fd);
return -1;
retval = nrf_setsockopt(fd,
NRF_SOL_GNSS,
NRF_SO_GNSS_FIX_RETRY,
&fix_retry,
sizeof(uint16_t));
if (retval != 0) {
printk("Failed to set fix retry value\n");
return -1;
NRF_SOL_GNSS,
NRF_SO_GNSS_FIX_INTERVAL,
&fix_interval,
sizeof(uint16_t));
if (retval != 0) {
printk("Failed to set fix interval value\n");
return -1;
NRF_SOL_GNSS,
NRF_SO_GNSS_NMEA_MASK,
&nmea_mask,
sizeof(uint16_t));
if (retval != 0) {
printk("Failed to set nmea mask\n");
return -1;
NRF_SOL_GNSS,
NRF_SO_GNSS_START,
NULL,
0);
if (retval != 0) {
printk("Failed to start GPS\n");
return -1;
return 0;
static void print_satellite_stats(nrf_gnss_data_frame_t *pvt_data)
u8_t tracked = 0;
u8_t in_fix = 0;
u8_t unhealthy = 0;
for (int i = 0; i < NRF_GNSS_MAX_SATELLITES; ++i) {
if ((pvt_data->pvt.sv[i].sv > 0) &&
(pvt_data->pvt.sv[i].sv < 33)) {
tracked++;
if (pvt_data->pvt.sv[i].flags &
NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
in_fix++;
NRF_GNSS_SV_FLAG_UNHEALTHY) {
unhealthy++;
printk("Tracking: %d Using: %d Unhealthy: %d", tracked,
in_fix,
unhealthy);
printk("\nSeconds since last fix %lld\n",
(k_uptime_get() - fix_timestamp) / 1000);
static void print_pvt_data(nrf_gnss_data_frame_t *pvt_data)
printf("Longitude: %f\n", pvt_data->pvt.longitude);
printf("Latitude: %f\n", pvt_data->pvt.latitude);
printf("Altitude: %f\n", pvt_data->pvt.altitude);
printf("Speed: %f\n", pvt_data->pvt.speed);
printf("Heading: %f\n", pvt_data->pvt.heading);
printk("Date: %02u-%02u-%02u\n", pvt_data->pvt.datetime.day,
pvt_data->pvt.datetime.month,
pvt_data->pvt.datetime.year);
printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
pvt_data->pvt.datetime.minute,
pvt_data->pvt.datetime.seconds);
static void print_nmea_data(void)
printk("NMEA strings:\n");
for (int i = 0; i < nmea_string_cnt; ++i) {
printk("%s\n", nmea_strings[i]);
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
int retval;
retval = nrf_recv(fd, gps_data, sizeof(nrf_gnss_data_frame_t), NRF_MSG_DONTWAIT);
if (retval > 0) {
switch (gps_data->data_id) {
case NRF_GNSS_PVT_DATA_ID:
if ((gps_data->pvt.flags &
== NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
if (!got_first_fix) {
got_first_fix = true;
fix_timestamp = k_uptime_get();
memcpy(&last_fix, gps_data, sizeof(nrf_gnss_data_frame_t));
nmea_string_cnt = 0;
update_terminal = true;
case NRF_GNSS_NMEA_DATA_ID:
if (nmea_string_cnt < 10) {
memcpy(nmea_strings[nmea_string_cnt++],
gps_data->nmea,
retval);
return retval;
void gpsData(){
nrf_gnss_data_frame_t gps_data;
u8_t cnt = 0;
printk("Staring GPS application\n");
if (init_app() != 0) {
//return -1;
printk("Getting GPS data...\n");
while (1) {
do {
/* Loop until we don't have more
* data to read*/
} while (process_gps_data(&gps_data) > 0);
cnt++;
//printk("\033[1;1H");
//printk("\033[2J");
print_satellite_stats(&gps_data);
printk("\nScanning [%c]\n ",
update_indicator[cnt%4]);
if (((k_uptime_get() - fix_timestamp) >= 1) &&
(got_first_fix)) {
printk("\033[2J");
printk("---------------------------------\n");
print_pvt_data(&last_fix);
printk("\n");
print_nmea_data();
printk("---------------------------------");
update_terminal = false;
k_sleep(K_MSEC(500));
void getBatteryVoltage(){
enum at_cmd_state at_state;
int actual_voltage;
char recv_buf[1024];
printk("Getting battery voltage\n");
int at_socket_fd=socket(AF_LTE, 0, NPROTO_AT);
if (at_socket_fd < 0) {
printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
while(1){
k_mutex_lock(&battery_data,K_FOREVER);
int bytes_written = send(at_socket_fd, battery_voltage,
strlen(battery_voltage), 0);
k_sleep(K_MSEC(50));
if (bytes_written > 0) {
int r_bytes =
blocking_recv(at_socket_fd, recv_buf,
sizeof(recv_buf), MSG_DONTWAIT);
if (r_bytes > 0) {
char *s=strstr(recv_buf," ");
actual_voltage=atoi(s);
printk("Actual battery voltage:%d V\n",actual_voltage);
k_mutex_unlock(&battery_data);
k_sleep(K_MSEC(1000));
printk("Closing socket\n\n");
close(at_socket_fd);
printk("Application started\n");
k_tid_t battery_tid = k_thread_create(&battery_voltage_data,
my_stack_area,
STACK_SIZE,
getBatteryVoltage,
NULL, NULL, NULL,
PRIORITY,0,K_FOREVER);
k_thread_start(battery_tid);
k_sleep(K_MSEC(2000));
k_tid_t gps_tid = k_thread_create( &gps_data,
my_stack_area,
STACK_SIZE,
gpsData,
NULL, NULL, NULL,
k_thread_start(gps_tid);
while(1){
printk("Inside while loop\n");
k_thread_suspend(battery_tid);
k_thread_resume(battery_tid);
return 0;
Please help me resolve this issue
Thanks
