I'm working on a bootloader based on the "secure_bootloader/pca10056_ble" example. Everything works fine until I send the new application binaries (.zip file) and the chip resets:
... <debug> nrf_dfu_flash: Flash write success: addr=0x000FE000, pending 0 <debug> app: Resetting bootloader. <info> nrf_dfu_settings: Backing up settings page to address 0xFE000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> app: Inside BL main?
After a lot of debugging I noticed that if I disable NRF_LOG_ENABLED, the updated app starts correctly.
Also, just by adding NRF_LOG_FLUSH() in nrf_bootloader_app_start.c right before the interrupts are disabled, the app also starts OK without having to disable the logs.
The NRF_LOG_DEFAULT_LEVEL is currently set to 4.
Is there any known reason for this behaviour?
Thanks.
