DFU linker settings in gcc
Dear All
We implement a DFU over USB functionality to the custom board nrf52840 board by compiling via gcc. Somehow there is my understanding problem with the linker for bootloader and app. Here is the important part of the secure_bootloader.ld linker file for the bootloader:
MEMORY
  FLASH (rx) : ORIGIN = 0xf4000, LENGTH = 0xa000
  RAM (rwx) :  ORIGIN = 0x20000008, LENGTH = 0x3fff8
  uicr_bootloader_start_address (r) : ORIGIN = 0x00000FF8, LENGTH = 0x4
  bootloader_settings_page (r) : ORIGIN = 0x000FF000, LENGTH = 0x1000
  uicr_mbr_params_page (r) : ORIGIN = 0x00000FFC, LENGTH = 0x4
  mbr_params_page (r) : ORIGIN = 0x000FE000, LENGTH = 0x1000
and here is the generic_gcc_nrf52.ld linker file's part for the memory:
MEMORY
  FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0xca000
  RAM (rwx) :  ORIGIN = 0x20002220, LENGTH = 0x3dde0
All compiles well and mergehex complains that I am overlapping some regions. Clearly I have a lack of understanding, how to create the linker file, as I am trying to sort it out by looking at the examples and reading the blogs. I am using SDK 15.0.0. Here is my confusion and following some questions:
1. According to the memory map, MBR starts at 0, is the statement correct: mbr_params_page (r) : ORIGIN = 0x000FE000, LENGTH = 0x1000
2. Is including in the app linker file: uicr_bootloader_start_address (r) : ORIGIN = 0x00000FF8, LENGTH = 0x4 immportant?
3. Bootloader and settings are as follows:
Bootloader DFU Settings:
* File:                     bootsettings.hex
* Family:                   NRF52840
* Start Address:            0x000FF000
* CRC:                      0x5593BD4D
* Settings Version:         0x00000001 (1)
* App Version:              0x00000002 (2)
* Bootloader Version:       0x00000001 (1)
* Bank Layout:              0x00000000
* Current Bank:             0x00000000
* Application Size:         0x0002785C (161884 bytes)
* Application CRC:          0x55A80F33
* Bank0 Bank Code:          0x00000001
* Softdevice Size:          0x00000000 (0 bytes)
* Boot Validation CRC:      0x00000000
* SD Boot Validation Type:  0x00000000 (0)
* App Boot Validation Type: 0x00000000 (0)
Any idea why the mergehex complains about possible region overlapping when app and bootloader (and settings) are merged?
4. What are the changes regarding DFU and bootloader from 15.0 to 15.3, would changing to 15.3 resolve these issues?
Best, Emek
  • Hi Bilen,
     It is correct that the MBR starts at 0x0000, but it also needs a flash page to store some magic numbers and keep track of pending bootloader copy operations. This flash page is placed at the end of flash, above the bootloader it self at 0x000FE000.
     Yes, this places the bootloader start address within the MBR, i.e. tells the MBR where to jump to on boot if a BL is present.
    * Family:                   NRF52840
    * CRC:                      0x5593BD4D
     So are you getting complaints about overlapping sections when you merge the bootloader and bootloader settings OR when you merge the app with the already merged bootloader + bootlaoder settings hex? If its the latter, then can you post the linker script for your application? I would like to check if you have adjusted the application flash region to allow enough space for the bootloader.
     I think the biggest change we did is that we're placing the bootloader start address and MBR params page address inside the MBR in addition to writing them to the UICR registers, see this https://devzone.nordicsemi.com/f/nordic-q-a/47651/uicr_mbr_params_page-and-uicr_bootloader_start_address-overwrite-the-beginning-of-the-softdevice.
    Best regards
    Bjørn
  • Hi Bjørn
    Many thanks for your prompt reply.
    Merging bootloader with settings work fine. The problem is in merging bootloder_and_settings with the app. In this case I am using the generic_gcc...ld file (see above) with the flash
    such that it ends at 155648+827392 = 983040 byte, if I understand it correctly. Then the bootloader shall start, from secure_bootloader.ld (see above)
    meaning that it starts at 0xf4000 meaning 999424 byte of length 40960 byte. Is this way of thinking correct by simply converting hex/decimal?
    Here is the full linker file for app, we use :
    SEARCH_DIR(.)
    GROUP(-lgcc -lc -lnosys)
    MEMORY
    SECTIONS
      . = ALIGN(4);
      .uicr_bootloader_start_address :
        PROVIDE(__start_uicr_bootloader_start_address = .);
        KEEP(*(SORT(.uicr_bootloader_start_address*)))
        PROVIDE(__stop_uicr_bootloader_start_address = .);
      } > uicr_bootloader_start_address
    SECTIONS
      . = ALIGN(4);
      .mem_section_dummy_ram :
      .cli_sorted_cmd_ptrs :
        PROVIDE(__start_cli_sorted_cmd_ptrs = .);
        KEEP(*(.cli_sorted_cmd_ptrs))
        PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
      } > RAM
      .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
      } > RAM
      .log_dynamic_data :
        PROVIDE(__start_log_dynamic_data = .);
        KEEP(*(SORT(.log_dynamic_data*)))
        PROVIDE(__stop_log_dynamic_data = .);
      } > RAM
      .log_filter_data :
        PROVIDE(__start_log_filter_data = .);
        KEEP(*(SORT(.log_filter_data*)))
        PROVIDE(__stop_log_filter_data = .);
      } > RAM
    } INSERT AFTER .data;
    SECTIONS
      .mem_section_dummy_rom :
      .sdh_ble_observers :
        PROVIDE(__start_sdh_ble_observers = .);
        KEEP(*(SORT(.sdh_ble_observers*)))
        PROVIDE(__stop_sdh_ble_observers = .);
      } > FLASH
      .sdh_soc_observers :
        PROVIDE(__start_sdh_soc_observers = .);
        KEEP(*(SORT(.sdh_soc_observers*)))
        PROVIDE(__stop_sdh_soc_observers = .);
      } > FLASH
      .sdh_stack_observers :
        PROVIDE(__start_sdh_stack_observers = .);
        KEEP(*(SORT(.sdh_stack_observers*)))
        PROVIDE(__stop_sdh_stack_observers = .);
      } > FLASH
      .sdh_req_observers :
        PROVIDE(__start_sdh_req_observers = .);
        KEEP(*(SORT(.sdh_req_observers*)))
        PROVIDE(__stop_sdh_req_observers = .);
      } > FLASH
      .sdh_state_observers :
        PROVIDE(__start_sdh_state_observers = .);
        KEEP(*(SORT(.sdh_state_observers*)))
        PROVIDE(__stop_sdh_state_observers = .);
      } > FLASH
        .nrf_queue :
        PROVIDE(__start_nrf_queue = .);
        KEEP(*(.nrf_queue))
        PROVIDE(__stop_nrf_queue = .);
      } > FLASH
        .nrf_balloc :
        PROVIDE(__start_nrf_balloc = .);
        KEEP(*(.nrf_balloc))
        PROVIDE(__stop_nrf_balloc = .);
      } > FLASH
        .cli_command :
        PROVIDE(__start_cli_command = .);
        KEEP(*(.cli_command))
        PROVIDE(__stop_cli_command = .);
      } > FLASH
      .crypto_data :
        PROVIDE(__start_crypto_data = .);
        KEEP(*(SORT(.crypto_data*)))
        PROVIDE(__stop_crypto_data = .);
      } > FLASH
      .pwr_mgmt_data :
        PROVIDE(__start_pwr_mgmt_data = .);
        KEEP(*(SORT(.pwr_mgmt_data*)))
        PROVIDE(__stop_pwr_mgmt_data = .);
      } > FLASH
      .log_const_data :
        PROVIDE(__start_log_const_data = .);
        KEEP(*(SORT(.log_const_data*)))
        PROVIDE(__stop_log_const_data = .);
      } > FLASH
      .log_backends :
        PROVIDE(__start_log_backends = .);
        KEEP(*(SORT(.log_backends*)))
        PROVIDE(__stop_log_backends = .);
      } > FLASH
    } INSERT AFTER .text
    INCLUDE "nrf_common.ld"
    For merging and then flashing, we use the following lines:
    nrfutil settings generate --family NRF52840 --application _build/nrf52840_xxaa.hex --application-version 2 --bootloader-version 1 --bl-settings-version 1 bootsettings.hex
    mergehex -m _bootloader/nrf52840_xxaa.hex bootsettings.hex -o bootloader_and_settings.hex
    mergehex -m _build/nrf52840_xxaa.hex bootloader_and_settings.hex -o app_firmware.hex
    nrfjprog --family nrf52 --recover
    nrfjprog --family nrf52 --program sdk/nRF5SDK_15.0.0/components/softdevice/s140/hex/s140_nrf52_6.0.0_softdevice.hex --sectorerase
    nrfjprog --family nrf52 --program app_firmware.hex --sectoranduicrerase --reset
  • Hi Bilen,
    I apologize for not replying sooner.
    So the application will occupy the area from 0x26000 to 0xF0000 as 0x26000+0xCA000 = 0xF0000
    The bootloader starts at 0xF4000 and ends at 0xFE000, so there should not be any overlap between the the application and bootloader + settings page hex as there are four 4kB flashpages in between 0xF4000- 0xF0000 = 0x4000 (16384bytes).
    So unless the application specifically places data above 0xF4000, then I dont see why mergehex complains about overlapping regions. I guess the only way to check is to look at the .map files for the compiled application and bootloader.
    Best regards
    Bjørn
  • Hi Bjørn
    I did solve the mergehex problem by using some help from:
    https://github.com/IOsonata/IOsonata/blob/master/ARM/Nordic/nRF52/nRF52840/ldscript/
    and now I am using the following in the linker file of the app:
    MEMORY
    	FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0xda000
    	RAM (rwx) :  ORIGIN = 0x20002220, LENGTH = 0x3DDE0
    	NOINIT (rwx) :  ORIGIN = 0x20007F80, LENGTH = 0x80
    	BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x000FF000, LENGTH = 0x1000
    SECTIONS
    	.bootloaderSettings(NOLOAD) :
    	} > BOOTLOADER_SETTINGS
    	.noinit(NOLOAD) :
    	} > NOINIT
    The mergehex is not complaining anymore and I can flash as expected.
    Now I have this issue. After merging and flashing app+bootloader, the chip resets by opening first the boatloader and then starting the app, exactly as it should be. Then I use reset, but the bootloader never starts and it jumps directly to the app. I know this simply by using LEDs.
    I use the following restart methods (all not working):
    1. Hard reset, simply cutting off the power and back.
    2. Soft device reset, sd_nvic_SystemReset();
    3. Setting gp register and soft reset
    ret_code_t status = sd_power_gpregret_clr(0, 0xFF);
        if (status == NRF_SUCCESS)
              status = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU);
    Here are my concerns:
    --Apparently bootloader is a bit different than in a PC, it is not always starting, but we need to trigger it. Which part is doing this, may be MBR, then is the procedure above (please see the first post) somehow wrong that I overwrite MBR or some other part?
    --App's linker file has only the info of bootloader settings page, is this really enough? I wonder how the app knows the bootloader start address, here is the part from the nrf_bootloader_info.h that I am using
    #define BOOTLOADER_DFU_GPREGRET_MASK            (0xF8)      /**< Mask for GPGPREGRET bits used for the magic pattern written to GPREGRET register to signal between main app and DFU. */
    #define BOOTLOADER_DFU_GPREGRET                 (0xB0)      /**< Magic pattern written to GPREGRET register to signal between main app and DFU. The 3 lower bits are assumed to be used for signalling purposes.*/
    #define BOOTLOADER_DFU_START_BIT_MASK           (0x01)      /**< Bit mask to signal from main application to enter DFU mode using a buttonless service. */
    #define BOOTLOADER_DFU_GPREGRET2_MASK           (0xF8)      /**< Mask for GPGPREGRET2 bits used for the magic pattern written to GPREGRET2 register to signal between main app and DFU. */
    #define BOOTLOADER_DFU_GPREGRET2                (0xA8)      /**< Magic pattern written to GPREGRET2 register to signal between main app and DFU. The 3 lower bits are assumed to be used for signalling purposes.*/
    #define BOOTLOADER_DFU_SKIP_CRC_BIT_MASK        (0x01)      /**< Bit mask to signal from main application that CRC-check is not needed for image verification. */
    #define BOOTLOADER_DFU_START    (BOOTLOADER_DFU_GPREGRET | BOOTLOADER_DFU_START_BIT_MASK)      /**< Magic number to signal that bootloader should enter DFU mode because of signal from Buttonless DFU in main app.*/
    #define BOOTLOADER_DFU_SKIP_CRC (BOOTLOADER_DFU_GPREGRET2 | BOOTLOADER_DFU_SKIP_CRC_BIT_MASK)  /**< Magic number to signal that CRC can be skipped due to low power modes.*/
    --Is it possible to check the restart method 3 above? There are several different posts suggesting
    nrf_power_gpregret_set() over the sd_power_gpregret_set() or setting gpregret2 instead of gpregret.
    Which one is relly true or does it matter? I am using sdk 15.0 (with the patch you mentioned for 15.3 in the above link) and soft device s140 version 6.0.0 on a 52840 chip.
    Best, Emek
     The MBR will __always__  jump to the bootloader if the bootloader start address is written to UICR. So in all the above scenarios you should enter the bootloaders main(). Where in the bootloader code are you setting the LED?
     As written above, the MBR will always jump to the bootloader's vector table when the bootloader start address is written to UICR.
     The application does not need to know the bootloader start address as its the MBR that performs the jump on boot. The only thing the application needs to do is to signal the bootloader to stay in the bootloader and not jump to the application when  you nwat to update the firmware, e.g. by writting to the GPREGRET registers.
    Yes, you should be able to run the bootloader in a debug session when you have the applicaiton and bl settings file flashed. Pressing start execution should cause the BL to jump to the application. After you can see the nRF advertising as the applicaiton you can then set a breakpoint in the BL main and then trigger the jump from app to bootloader. You should then see that you enter the bootloader main and dfu_enter_check() should evaluate to true.
    The bootloader only checks GPREGRET, not GPREGRET2. Make sure that the GPREGRET enter mode is enabled in the sdk_config.h file in the bootloader, e.g. NRF_BL_DFU_ENTER_METHOD_GPREGRET
    The patch for SDK v15.3.0 does not need to be applied in SDK v15.0.0 as the bootloader does not write the mbr params page address and the bootloader start address to the MBR region, only the UICR registers.
     Best regards
