nrf9160 uart Pull-Up and power consumption
hi all,
i'm trying to disable uart for lower power consumption, i've disables it with:
NRF_UARTE1->TASKS_STOPTX = 1;
NRF_UARTE1->TASKS_STOPRX = 1;
but when i measure the voltage on the rx pin i see 1.8V  (this seems to consume current on the device on the other side of the uart interface - which is turned off )
i assume its in pulled up state, so i'm trying to change it's state to no-pull:
nrf_uarte_txrx_pins_disconnect(NRF_UARTE0);
gpio_pin_configure(uart_wifi, 18, GPIO_PUD_PULL_DOWN);
gpio_pin_configure(uart_wifi, 19, GPIO_PUD_PULL_DOWN);
gpio_pin_write(uart_wifi, 18,0);
gpio_pin_write(uart_wifi, 19,0);
 but it doesnt seem to have any effect.
how can i set this pin to 0, and back to 1 when I need it , on runtime?
Thanks
Moshe
  • Hi Moshe,
    Is the external IC power gated? It should drive the RX line to 'high' when it's inactive and powered. So that may explain why you see the current draw when you set the output to 0.
    Also, from your code snippets, it appears that you are stopping UART instance 1 while nrf_uarte_txrx_pins_disconnect() call takes instance 0 as an argument. Not sure if this is intended or not.
    Vidar
  • Hi Vidar,
    Thanks for your answer,
    1. I called `nrf_uarte_txrx_pins_disconnect()` on both UARTs (didnt copy it into the snippet).
    2. I test this while the external IC is powered off  (it is gated ) .
    3. Just to be clear, even when I  disable UART from the SW, I still measure 1.8v on the TX pin . I guess it is still pulled up .
    Thanks and BR
    Just to make sure, did you disable the UARTE before you re-configured the pins? UART pins can't be re-configured while the interface is enabled.
  • 1514 void disable_uart(){
    1515         NRF_UARTE0->TASKS_STOPTX = 1;
    1516         NRF_UARTE0->TASKS_STOPRX = 1;
    1517         NRF_UARTE0->ENABLE= UARTE_ENABLE_ENABLE_Disabled;
    1518
    1519         NRF_UARTE1->TASKS_STOPTX = 1;
    1520         NRF_UARTE1->TASKS_STOPRX = 1;
    1521         NRF_UARTE1->ENABLE= UARTE_ENABLE_ENABLE_Disabled;
    1522
    1523         NRF_UARTE0_NS->TASKS_STOPTX = 1;
    1524         NRF_UARTE0_NS->TASKS_STOPRX = 1;
    1525         NRF_UARTE0_NS->ENABLE= UARTE_ENABLE_ENABLE_Disabled;
    1526
    1527         NRF_UARTE1_NS->TASKS_STOPTX = 1;
    1528         NRF_UARTE1_NS->TASKS_STOPRX = 1;
    1529         NRF_UARTE1_NS->ENABLE= UARTE_ENABLE_ENABLE_Disabled;
    1530
    1531         nrf_uarte_txrx_pins_disconnect(NRF_UARTE0);
    1532         nrf_uarte_txrx_pins_disconnect(NRF_UARTE1);
    1533         nrf_uarte_txrx_pins_disconnect(NRF_UARTE0_NS);
    1534         nrf_uarte_txrx_pins_disconnect(NRF_UARTE1_NS);
    1535
    1536         nrf_uarte_disable(NRF_UARTE0);
    1537         nrf_uarte_disable(NRF_UARTE1);
    1538         nrf_uarte_disable(NRF_UARTE0_NS);
    1539         nrf_uarte_disable(NRF_UARTE1_NS);
    1540
    1541
    1542 }
    this is the code we have used .
    it seems that it is in the right order.
  • Yes, it seems correct to me. So I don't see how the RX line could be 1.8v when the ext. device is powered off. But you mentioned that the external device seems to draw current. Did you determine that based on the total current consumption?
