nrf9160 uart Pull-Up and power consumption
hi all,
i'm trying to disable uart for lower power consumption, i've disables it with:
NRF_UARTE1->TASKS_STOPTX = 1;
NRF_UARTE1->TASKS_STOPRX = 1;
but when i measure the voltage on the rx pin i see 1.8V  (this seems to consume current on the device on the other side of the uart interface - which is turned off )
i assume its in pulled up state, so i'm trying to change it's state to no-pull:
nrf_uarte_txrx_pins_disconnect(NRF_UARTE0);
gpio_pin_configure(uart_wifi, 18, GPIO_PUD_PULL_DOWN);
gpio_pin_configure(uart_wifi, 19, GPIO_PUD_PULL_DOWN);
gpio_pin_write(uart_wifi, 18,0);
gpio_pin_write(uart_wifi, 19,0);
 but it doesnt seem to have any effect.
how can i set this pin to 0, and back to 1 when I need it , on runtime?
Thanks
Moshe
  • Hi Moshe,
    Are you 100 % certain that its the nRF that is keeping this line high?
    If you power off only the nrf91, does the voltage drop to gnd?
    Is this measured on a nRF91-DK or a custom board?
    If it still is set high, can you please post any changed overlay/dts files?
    PS: your stop/disable routines will not work as you intend them to, because when you issue TASKS_STOPRX=1, you have to wait for the EVENTS_RXTO to occur before you disable the UART instance (same goes for the TX, although its less of a change for that the occurring while you disable the peripheral), as stated here in the PS:
    https://infocenter.nordicsemi.com/topic/ps_nrf9160/uarte.html?cp=2_0_0_5_18_6#concept_twi_low_power
    Håkon
  • Hi Hakon,
    1. I'm pretty sure it is the NRF since the device on the other size is powered off.
    2. if I disable UART completely, I see the line on LOW.
    3. it is measured on a costum board.
    4. attached.
    Thanks !!!
  • Hi Moshe,
     Never initialize it? ie: CONFIG_SERIAL=n?
    MosheSmartAmr said:
    4. attached.
     Looks like they weren't attached. Could you try .zip'ing it and then attach it?
    Did you try disabling per the recommendation in the datasheet, ie: wait for the events on RX and TX before completely disabling the peripheral to see if this has a difference on the behavior?
    Håkon
    Sorry for the delay ,
    1.about CONFIG_SERIAL=n, this is exactly wht i did .
    2. attaching again .
    3. just tried what you suggested (waiting for the event before disabling) , thath did not work too ...
    overlay file:
    /* SPDX-License-Identifier: Apache-2.0 */
    &uart1 {
            current-speed = <115200>;
            status = "okay";
            tx-pin = <19>;
            rx-pin = <18>;
    dts file :
     * Copyright (c) 2018 Nordic Semiconductor ASA
    	model = "Nordic PCA10090 Dev Kit";
    	compatible = "nordic,pca10090-dk", "nordic,nrf9160-sica",
    		     "nordic,nrf9160";
    	chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio0 2 GPIO_INT_ACTIVE_HIGH>;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = <&gpio0 3 GPIO_INT_ACTIVE_HIGH>;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = <&gpio0 4 GPIO_INT_ACTIVE_HIGH>;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = <&gpio0 5 GPIO_INT_ACTIVE_HIGH>;
    			label = "Green LED 3";
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = <&gpio0 8 GPIO_PUD_PULL_UP>;
    			label = "Switch 1";
    		button1: button_1 {
    			gpios = <&gpio0 9 GPIO_PUD_PULL_UP>;
    			label = "Switch 2";
    		button2: button_2 {
    			gpios = <&gpio0 6 GPIO_PUD_PULL_UP>;
    			label = "Push button 1";
    		button3: button_3 {
    			gpios = <&gpio0 7 GPIO_PUD_PULL_UP>;
    			label = "Push button 2";
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		sw0 = &button2;
    		sw1 = &button3;
    		sw2 = &button0;
    		sw3 = &button1;
    &adc {
    	status ="ok";
    &gpiote {
    	status = "ok";
    &gpio0 {
    	status = "ok";
    &uart0 {
    	status = "ok";
    	tx-pin = <26>;
    	rx-pin = <30>;
    &uart0 {
    	status = "okay";
    	tx-pin = <29>;
    	rx-pin = <28>;
    	rts-pin = <27>;
    	cts-pin = <26>;
    &uart1 {
    	status = "ok";
    	tx-pin = <1>;
    	rx-pin = <0>;
    	rts-pin = <14>;
    	cts-pin = <15>;
    &i2c2 {
    	status = "ok";
    	sda-pin = <12>;
    	scl-pin = <31>;
    &pwm0 {
    	status = "ok";
    	ch0-pin = <2>;
    &spi3 {
    	status = "ok";
    &timer0 {
    	status = "ok";
    &timer1 {
    	status = "ok";
    &timer2 {
    	status = "ok";
    &flash0 {
    	 * For more information, see:
    	 * http://docs.zephyrproject.org/latest/guides/dts/index.html#flash-partitions
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x00000000 0x10000>;
    		slot0_partition: partition@10000 {
    			label = "image-0";
    		slot0_ns_partition: partition@40000 {
    			label = "image-0-nonsecure";
    		slot1_partition: partition@80000 {
    			label = "image-1";
    		slot1_ns_partition: partition@b0000 {
    			label = "image-1-nonsecure";
    		scratch_partition: partition@f0000 {
    			label = "image-scratch";
    			reg = <0x000f0000 0xa000>;
    		storage_partition: partition@fa000 {
    			label = "storage";
    			reg = <0x000fa000 0x00006000>;
    	/* SRAM allocated and used by the BSD library */
    	sram0_bsd: memory@20010000 {
    		device_type = "memory";
    		compatible = "mmio-sram";
    	/* SRAM allocated to the Non-Secure image */
    	sram0_ns: memory@20020000 {
    /* Include partition configuration file */
    #include "nrf9160_pca10090_partition_conf.dts"
    When the UART is disabled, the RXD is left as an input, and TXD is left as an output (with high level).
    This is the routine that I have tested your scenario with:
    #include <zephyr.h>
    #include <misc/printk.h>
    #include <uart.h>
    #define TXD_PIN 19
    static u8_t uart_buf[1024];
    void uart_cb(struct device *x)
    	uart_irq_update(x);
    	int data_length = 0;
    	if (uart_irq_rx_ready(x)) {
    		data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
    		uart_buf[data_length] = 0;
    	printk("%s", uart_buf);
    void main(void)
    	struct device *uart = device_get_binding("UART_1");
    	uart_irq_callback_set(uart, uart_cb);
    	uart_irq_rx_enable(uart);
    	printk("UART loopback start!\n");
    	while (1) {
    		static u32_t wakeup_cnt;
    		k_cpu_idle();
    		wakeup_cnt++;
    		if (wakeup_cnt > 40) {
    			wakeup_cnt = 0;
    			NRF_UARTE1->TASKS_STOPRX=1;
    			while(NRF_UARTE1->EVENTS_RXTO == 0);
    			NRF_UARTE1->EVENTS_RXTO = 0;
    			while(NRF_UARTE1->EVENTS_TXSTOPPED == 0);
    			NRF_UARTE1->EVENTS_TXSTOPPED = 0;
    			NRF_UARTE1->ENABLE = 0;
    			NRF_UARTE1->PSEL.TXD = 0xFFFFFFFF;
    			NRF_P0_NS->OUTCLR = (1 << TXD_PIN);
    This code assumes that I loopback UART0:TXD to UART1:RXD, and when it has gotten 40 chars, it disconnects the UART1 interface completely.
    If I do not clear the GPIO, it is held high. When I run NRF_P0_NS->OUTCLR = 1<<19;, the pin goes low again after disconnecting it from the UARTE1 peripheral.
    Could you try this and see if that works at your end?
    Håkon
