High Current Consumption in Secure DFU Bootloader for SDK 14.2
Hi Everyone,
I am using nRF52832 with SDK v14.2 and SD v5.0.0 on a custom chip.
Recently i included DFU support to our application. It turns out that secure bootloader is drawing a constant current of >2 mA.
Before integrating secure bootloader support, we managed to bring down application current consumption during system ON (sleep mode) to 30 uA. But after integration with DFU, even during the sleep mode, i see a constant surge of over 2 mA.
Could any of you guys let me know what can be the cause of bootloader taking in so much current? I found something in the forum which says that the bootloader has not been power optmized and has been considerably optimized in SDK 15.0.0 -> https://devzone.nordicsemi.com/f/nordic-q-a/36570/excessive-power-consumption-in-bootloader_secure_ble
But if i don't want to migrate to 15.0.0, is there a way this can be optimized for SDK 14.2? Please let me know.
Thank you!
  • Hi
    What exactly is your application supposed/expected to do? If it starts up, then does a quick operation before going to sleep (system OFF) mode, which requires it to reset upon wake up, and does this frequently, that will cause the startup and the bootloader activation to trigger often, and might draw current. Please try to enable logging, and print a message upon reset to check if your application restarts frequently.
    Simon
  • Hi
    Simon
