The issue when using pc-ble-driver-py for nRF52840-Dongle
Dears,
I need to use the nRF52840-Dongle for BLE device to communicate with the end devices, the platform is ubuntu and the programming is python3.7, I have problem on it.
I have installed the nRF-Connect-Desktop, and written the fireware into the nRF-Dongle, cause I can operate the Dongle to scan and discover devices normally from the tool. Then I used the pc-ble-driver-py from GitHub trying to operate it with python. After installed the pc-ble-driver-py completely(including the pc-ble-driver and so on) according to the readme, I ran the example named serial_port_enum.py with the identifier arg ''NRF52". But I got the empty result returned by the BleDriver.enum_serial_ports() .  Is there something or procedure I missed? Or help me for more detailed procedure to use the pc-ble-driver-py for  nRF52480-Dongle. Thank you very much.
My purpose is to do the scan, connect, characteristic and etc(like bluepy) with nRF52480-Dongle normally.
  • I'm having the same issue as you, where BLEDriver.enum_serial_ports() returns an empty result.  Have you tried the other examples?  If I run the Heart Rate Collector, and provide the port, it works.  It finds the other BLE devices in the room.  It seems like the issue is only in enum_serial_ports().
  • Yes, I tried and I found that the issue is only on the enum_serial_ports, so I got the dev files in /dev path directly to resolve this issue. Thank you very much
  • I found this here in common/platform/linux/serial_port_enum.cpp:
    if (((idVendor == SEGGER_VENDOR_ID) || (idVendor == NXP_VENDOR_ID)) &&
    ((manufacturer == "SEGGER") || (strncasecmp(manufacturer.c_str(), "arm", 3) == 0) ||
    (strncasecmp(manufacturer.c_str(), "mbed", 4) == 0)))
    std::string serialNumber =
    to_str(udev_device_get_sysattr_value(udev_usb_dev, "serial"));
    std::string idProduct =
    to_str(udev_device_get_sysattr_value(udev_usb_dev, "idProduct"));
    devices.push_back(
    SerialPortDesc{devname, manufacturer, serialNumber, "", path, idVendor, idProduct});
    I guess this is the reason why the dongle is not listed
    devices.push_back(
