sd_nvic_critical_region_enter/exit specifications
Is there a list of every interrupt these functions effect. Specifically I am worried about
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
My assumption is that they will disable this callback from the softdevice. Perhaps nordic has published something that better outlines the behavior of sd_nvic_critical_region_enter/exit. From what I can tell the source code for the functions is not available.
  • Does this answer your question?
    Please add a comment to my answer if it doesn't.
  • Hi
    From what I understand, sd_nvic_critical_region_enter will disable all application interrupts, which includes ARM priority 1 and 3 interrupts, because those are the application interrupt priorities. The softdevice callbacks will be blocked as well, e.g. sd_nvic_critical_region_enter, as they have ARM priority 3.
    The sd_nvic_critical_region_enter does however not have any effect on interrupts used by the softdevice itself, so calling sd_nvic_critical_region_enter will not block any BLE radio events.
