Peripheral blinky example not advertising
I had to modify the peripheral blinky example by adding UART module .The program compiles and builds but it is not advertising.I guess there is some problem with the advertising_start() as i am getting a warning near the usage of advertising_start() function.I have attached the main file.Kindly let me know where the problem is as I am not able to debug.
 * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief Blinky Sample Application main file.
 * This file contains the source code for a sample server application using the LED Button service.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
 /**#define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
#define DEVICE_NAME                     "Wagon_Master"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256
#define CONFIG_FILE     (0xF010)
#define CONFIG_REC_KEY  (0x7010)
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
/**static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    ret_code_t              err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    APP_ERROR_HANDLER(nrf_error);
static struct
    bool delete_next;   //!< Delete next record.
    bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
} m_delete_all;
/* Array to map FDS return values to strings. */
char const * fds_err_str[] =
    "FDS_SUCCESS",
    "FDS_ERR_OPERATION_TIMEOUT",
    "FDS_ERR_NOT_INITIALIZED",
    "FDS_ERR_UNALIGNED_ADDR",
    "FDS_ERR_INVALID_ARG",
    "FDS_ERR_NULL_ARG",
    "FDS_ERR_NO_OPEN_RECORDS",
    "FDS_ERR_NO_SPACE_IN_FLASH",
    "FDS_ERR_NO_SPACE_IN_QUEUES",
    "FDS_ERR_RECORD_TOO_LARGE",
    "FDS_ERR_NOT_FOUND",
    "FDS_ERR_NO_PAGES",
    "FDS_ERR_USER_LIMIT_REACHED",
    "FDS_ERR_CRC_CHECK_FAILED",
    "FDS_ERR_BUSY",
    "FDS_ERR_INTERNAL",
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
    "FDS_EVT_INIT",
    "FDS_EVT_WRITE",
    "FDS_EVT_UPDATE",
    "FDS_EVT_DEL_RECORD",
    "FDS_EVT_DEL_FILE",
    "FDS_EVT_GC",
static bool volatile m_fds_initialized;
static void fds_evt_handler(fds_evt_t const * p_evt)
    switch (p_evt->id)
        case FDS_EVT_INIT:
            if (p_evt->result == FDS_SUCCESS)
                m_fds_initialized = true;
        case FDS_EVT_WRITE:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
        } break;
        case FDS_EVT_DEL_RECORD:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
            m_delete_all.pending = false;
        } break;
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
    (void) sd_app_evt_wait();
#else
    __WFE();
static void wait_for_fds_ready(void)
    while (!m_fds_initialized)
        power_manage();
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        static uint8_t m_deadbeef[10] = {0};
       // NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
        strcpy(m_deadbeef,p_evt->params.rx_data.p_data);
        //printf("%s ",m_deadbeef);
        fds_record_t        record;
        fds_record_desc_t   record_desc;
         fds_find_token_t  tok ={0};
    // Set up record.
        record.file_id                          = CONFIG_FILE;
        record.key                      = CONFIG_REC_KEY;
        record.data.p_data              = &m_deadbeef;
        record.data.length_words            = sizeof(m_deadbeef)/sizeof(uint8_t);
        ret_code_t rc;
        rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &record_desc, &tok);
        if (rc == FDS_SUCCESS)
             fds_flash_record_t  flash_record;
              rc = fds_record_open(&record_desc, &flash_record);
              APP_ERROR_CHECK(rc);
              flash_record.p_data=&m_deadbeef;
             rc = fds_record_update(&record_desc, &record);
             ret_code_t ret = fds_record_write(&record_desc, &record);
             APP_ERROR_CHECK(ret);
/**static void advertising_start(void)
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    bsp_board_led_on(ADVERTISING_LED);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            err_code = app_button_enable();
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            advertising_start();
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@snippet [UART Initialization] */
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
    ble_lbs_init_t     init     = {0};
ble_nus_init_t nus_init;
// Initialize NUS.
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@snippet [Handling the data received over UART] */
/**@brief  Function for initializing the UART module.
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .flow_control = APP_UART_FLOW_CONTROL_ENABLED,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_9600
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                      uart_error_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**static void ble_stack_init(void)
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Send button state change.");
            err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               BUTTON_DETECTION_DELAY);
static void sim808_init(void)
        printf("\r\nAT\r\n");
        nrf_delay_ms(500);
        printf("\r\nATE0\r\n");
        nrf_delay_ms(500);
        printf("\r\nAT+CIPSHUT\r\n");
        nrf_delay_ms(500);
        printf("\r\nAT+CIPMUX=0\r\n");
        nrf_delay_ms(500);
        printf("\r\nAT+CSTT=\"airtelgprs.com\",\"\",\"\"\r\n");
        nrf_delay_ms(500);
        printf("\r\nAT+CIICR\r\n");
        nrf_delay_ms(3000);
        printf("\r\nAT+CIFSR\r\n");
        nrf_delay_ms(1000);
        printf("\r\nAT+CIPSTART=\"TCP\",\"tcp://0.tcp.ngrok.io\",\"13857\"\r\n");
        nrf_delay_ms(3000);
        printf("\r\nAT+CGPSPWR=1\r\n");
        nrf_delay_ms(500);
        printf("\r\nAT+CIPSEND\r\n");
        nrf_delay_ms(500);
        printf("Sim is Active\n\x1A");
        nrf_delay_ms(500);
static void log_init(void)
/**static void power_management_init(void)
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    // Initialize.
ret_code_t rc;
 bool erase_bonds;
    log_init();
 uart_init();
 printf("\r\nBlinky Uart\r\n");
    leds_init();
    timers_init();
    buttons_init();
    sim808_init();
    power_management_init();
    ble_stack_init();
 (void) fds_register(fds_evt_handler);
    rc = fds_init();
    wait_for_fds_ready();
    fds_stat_t stat = {0};
    rc = fds_stat(&stat);
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    // Enter main loop.
    for (;;)
 uint8_t *data_1=NULL;
        fds_record_desc_t   record_desc_1;
        fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
        ret_code_t rc;
        rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &record_desc_1, &ftok);
            rc = fds_record_open(&record_desc_1, &flash_record);
            data_1 = (uint8_t *) flash_record.p_data;
            rc = fds_record_close(&record_desc_1);
            if(data_1!=NULL)
               { uint8_t lat_long[29]={0};
                 uint8_t *lat_long_1;
                 uint8_t *lat_long_2;
                uint8_t check;
                int j=0;
                int k=11;
                printf("\r\nAT+CGPSINF=0\r\n");
                nrf_delay_ms(1000);
                for(int i=0; i<UART_RX_BUF_SIZE ; i++)
                  app_uart_get(&check);
                  if(check=='+')
                      for(int j=0; j<29 ; j++)
                        app_uart_get(&lat_long[j]);
                lat_long_1=strtok(lat_long,":");
                lat_long_1=strtok(NULL,",");
                lat_long_2=strtok(NULL,",");
                nrf_delay_ms(10000);
                nrf_delay_ms(500);
                printf("wagon number is :%s\n\x1A",data_1);
                nrf_delay_ms(1000);
                nrf_delay_ms(1000);
                printf("location coordinates are :%s %s\n\x1A",lat_long_1,lat_long_2);
                nrf_delay_ms(5000);
                nrf_delay_ms(3000);
        idle_state_handle();
  • i am getting a warning
    What warning, exactly, are you getting?
    Where, exactly?
    Was it working before you modified it?
    Why not?
  •  @awneil  ''static declaration of 'advertising_start' follows non-static declaration'' this is the error i am getting so i changed it to non static.The peripheral blinky code was working before i modified it.
  • Was that the only warning you got?
    That's a standard 'C' issue - not specific to Nordic.
    It usually means that you've called a function before its declaration (prototype) or definition.
    When that happens, the compiler will create an implicit - or "default" - declaration. Then you get this warning when it comes to your definition.
    Quite possibly, the implicit declaration is not (quite) compatible with your actual definition.
    The answer is to either provide a prototype, or move the definition.
    Or both.
  • I made the changes in the code and its compliling and building successfully but it is still not advertising.What can be the issue?I have attached the code for reference.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "boards.h"
    #include "fds.h"
        #define c
        .adv_data =
        .scan_rsp_data =
    static struct
    } m_delete_all;
        "FDS_SUCCESS",
        "FDS_ERR_NULL_ARG",
        "FDS_ERR_NO_PAGES",
        "FDS_ERR_BUSY",
        "FDS_ERR_INTERNAL",
        "FDS_EVT_INIT",
        "FDS_EVT_WRITE",
        "FDS_EVT_UPDATE",
        "FDS_EVT_DEL_FILE",
        "FDS_EVT_GC",
        switch (p_evt->id)
            case FDS_EVT_INIT:
            case FDS_EVT_WRITE:
            } break;
            } break;
    #else
        __WFE();
            power_manage();
            uint32_t err_code;
        // Set up record.
            ret_code_t rc;
        /**c = c+1; */
    /**static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
                                                       NULL,
                                                       NULL);
            } break;
        if (led_state)
    // Initialize NUS.
        // Initialize LBS.
                                                       NULL,
                                                       NULL);
            } break;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                          uart_error_handle,
                           err_code);
        switch (pin_no)
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_delay_ms(3000);
            nrf_delay_ms(1000);
            nrf_delay_ms(3000);
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_delay_ms(500);
            nrf_pwr_mgmt_run();
        // Initialize.
    ret_code_t rc;
     bool erase_bonds;
        log_init();
     uart_init();
        leds_init();
        timers_init();
        buttons_init();
        sim808_init();
        ble_stack_init();
        rc = fds_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
            ret_code_t rc;
                if(data_1!=NULL)
                    uint8_t check;
                    int j=0;
                    int k=11;
                    nrf_delay_ms(1000);
                      if(check=='+')
                    nrf_delay_ms(500);
                    nrf_delay_ms(1000);
                    nrf_delay_ms(1000);
                    nrf_delay_ms(5000);
                    nrf_delay_ms(3000);
