BLE Beacon with DFU not advertising
I am trying to add DFU service in ble_beacon example. I am using SDK14 and softdevice is S132_5.0.0 for 52-dk.
I have merged dfu example with ble_beacon and initiate only beacon advertising portion in main function, but after uploading softdevice and application my device is not advertising anything.
How do I add dfu service to ble_beacon?
 * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup bootloader_secure_ble main.c
 * @ingroup dfu_bootloader_api
 * @brief Bootloader project main file for secure DFU.
#include <stdint.h>
#include "boards.h"
#include "nrf_mbr.h"
#include "nrf_bootloader.h"
#include "nrf_bootloader_app_start.h"
#include "nrf_dfu.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_error.h"
#include "app_error_weak.h"
#include "nrf_bootloader_info.h"
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#define BOOTLOADER_BUTTON   (BSP_BUTTON_3)          /**< Button for entering DFU mode. */
                          /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG            1                                 /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                              /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                              /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                              /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                              /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                            /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                        /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                        /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                        /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                        /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                 /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    err_code = ble_advdata_set(&advdata, NULL);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
    m_adv_params.p_peer_addr = NULL;    // Undirected advertisement.
    m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.timeout     = 0;       // Never time out.
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    NRF_LOG_ERROR("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x", id, pc, info);
    NVIC_SystemReset();
void app_error_handler_bare(uint32_t error_code)
    (void)error_code;
    NRF_LOG_ERROR("Received an error: 0x%08x!", error_code);
    NVIC_SystemReset();
/**@brief Function for initialization of LEDs. */
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LED, NULL);
/**@brief Function for initializing the button module. */
static void buttons_init(void)
    nrf_gpio_cfg_sense_input(BOOTLOADER_BUTTON,
                             BUTTON_PULL,
                             NRF_GPIO_PIN_SENSE_LOW);
/**@brief Implementation to use button press to enter bootloader
bool nrf_dfu_button_enter_check(void)
    if (nrf_gpio_pin_read(BOOTLOADER_BUTTON) == 0)
        return true;
    return false;
/**@brief Function for initializing timers. */
static void timers_init(void)
/**@brief Function for doing power management. */
static void power_manage(void)
    ret_code_t err_code = sd_app_evt_wait();
/**@brief Function for application main entry. */
    log_init();
    timers_init();
    leds_init();
    ble_stack_init();
    advertising_init();
    advertising_start();
    NRF_LOG_INFO("Beacon example started.");
    // Enter main loop.
    for (;; )
            power_manage();
   /* uint32_t ret_val;
    (void) NRF_LOG_INIT(NULL);
    NRF_LOG_INFO("Inside main");
    leds_init();
    buttons_init();
    ret_val = nrf_bootloader_init();
    APP_ERROR_CHECK(ret_val);
    // Either there was no DFU functionality enabled in this project or the DFU module detected
    // no ongoing DFU operation and found a valid main application.
    // Boot the main application.
    nrf_bootloader_app_start(MAIN_APPLICATION_START_ADDR);
    // Should never be reached.
    NRF_LOG_INFO("After main");*/
