BLE Beacon with DFU not advertising
I am trying to add DFU service in ble_beacon example. I am using SDK14 and softdevice is S132_5.0.0 for 52-dk.
I have merged dfu example with ble_beacon and initiate only beacon advertising portion in main function, but after uploading softdevice and application my device is not advertising anything.
How do I add dfu service to ble_beacon?
 * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup bootloader_secure_ble main.c
 * @ingroup dfu_bootloader_api
 * @brief Bootloader project main file for secure DFU.
#include <stdint.h>
#include "boards.h"
#include "nrf_mbr.h"
#include "nrf_bootloader.h"
#include "nrf_bootloader_app_start.h"
#include "nrf_dfu.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_error.h"
#include "app_error_weak.h"
#include "nrf_bootloader_info.h"
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#define BOOTLOADER_BUTTON   (BSP_BUTTON_3)          /**< Button for entering DFU mode. */
                          /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG            1                                 /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                              /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                              /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                              /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                              /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                            /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                        /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                        /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                        /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                        /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                 /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    err_code = ble_advdata_set(&advdata, NULL);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
    m_adv_params.p_peer_addr = NULL;    // Undirected advertisement.
    m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.timeout     = 0;       // Never time out.
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    NRF_LOG_ERROR("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x", id, pc, info);
    NVIC_SystemReset();
void app_error_handler_bare(uint32_t error_code)
    (void)error_code;
    NRF_LOG_ERROR("Received an error: 0x%08x!", error_code);
    NVIC_SystemReset();
/**@brief Function for initialization of LEDs. */
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LED, NULL);
/**@brief Function for initializing the button module. */
static void buttons_init(void)
    nrf_gpio_cfg_sense_input(BOOTLOADER_BUTTON,
                             BUTTON_PULL,
                             NRF_GPIO_PIN_SENSE_LOW);
/**@brief Implementation to use button press to enter bootloader
bool nrf_dfu_button_enter_check(void)
    if (nrf_gpio_pin_read(BOOTLOADER_BUTTON) == 0)
        return true;
    return false;
/**@brief Function for initializing timers. */
static void timers_init(void)
/**@brief Function for doing power management. */
static void power_manage(void)
    ret_code_t err_code = sd_app_evt_wait();
/**@brief Function for application main entry. */
    log_init();
    timers_init();
    leds_init();
    ble_stack_init();
    advertising_init();
    advertising_start();
    NRF_LOG_INFO("Beacon example started.");
    // Enter main loop.
    for (;; )
            power_manage();
   /* uint32_t ret_val;
    (void) NRF_LOG_INIT(NULL);
    NRF_LOG_INFO("Inside main");
    leds_init();
    buttons_init();
    ret_val = nrf_bootloader_init();
    APP_ERROR_CHECK(ret_val);
    // Either there was no DFU functionality enabled in this project or the DFU module detected
    // no ongoing DFU operation and found a valid main application.
    // Boot the main application.
    nrf_bootloader_app_start(MAIN_APPLICATION_START_ADDR);
    // Should never be reached.
    NRF_LOG_INFO("After main");*/
    So your device is not advertising after you flash the bootloader and the application?
    Are you sure it doesn't advertise as DfuTarg? If you have a bootloader, if your application is not transferred over DFU, or if you flash bootloader settings generated with the correct application, then the bootloader will reject the application, and start advertising "DfuTarg"
    If you have not seen it already, I recommend that you read through the DFU getting started guide.
  • Hi Edvin,
    Thanks for your reply.
    I have already gone through DFU getting atarted guide and it's working fine. Now I want to add dfu service with ble_beacon example. I have merged beacon and dfu code in main.c file. Now in main function I have only initialize ble_beacon and commented all the dfu function. but Device is not not emitting beacon signal after compiling and uploading code. Kindly check my main.c file. In-short I want to make main.c file in which if I comment out ble_beacon functions in main() then it will work like a dfu example and If I comment out dfu functions in main() then it will work like a ble_beacon example.
  • Oh, I thought you meant that you merged the hex files, but you actually merged the functions that is called in main.c. That will not work.
    This part in the middle of your main() function:
    // Enter main loop.
        for (;; )
                power_manage();
    is called your main loop. This means that it will never go past this, so it will never reach anything below these lines, such as ret_val = nrf_bootloader_init();
    Either way, that is not how the bootloader works. The bootloader is a separate project with a separate hex file that runs whenever you turn on your device. The reason it will not work to comment out either the bootloader part or the beacon part is that the project settings are different in the two projects. The bootloader is designed to be in the end of the flash area, and the beacon is designed to be right after the softdevice. You can find some information about this here:
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.3.0%2Flib_bootloader.html&cp=5_1_3_5_0_7&anchor=lib_bootloader_memory
    Typically, you have something in your application that says that "now I want to go into DFU mode". When this happens it will set some registers, and reset. After the reset it will start up the bootloader, and see that these registers are set, and then run into DFU mode. If these registers are not set, it will check that it has a valid application, and then run that application. I don't think you should try to challenge this structure.
    What you need to decide is how you want your application to enter DFU mode. A beacon is typically non-connectable, so you can't use BLE to tell it to enter DFU mode (there is no way to send BLE data to the beacon. It can only broadcast). Do you have a button that you can use to enter DFU mode?
    Edvin
    Information provided by you is helpful to me.
    Yes, I have a button on nrf beacon which I have to use to enter DFU mode. How can I do this? Actually my main.c file working well when I use only DFU mode.
  • Please do not (!) mix the two projects for bootloader and application together.
    Search for nrf_dfu_button_enter_check() in your bootloader project. If This button is pushed when the bootloader is started. You need to set BOOTLOADER_BUTTON to match your button.
    You need to decide how you want your application to reset (to start the bootloader). You want the sequence to be like this:
    Application normally running --> some user interface cause the application to call a reset --> bootloader start up --> button is held, putting the device in DFU mode.
    My suggestion is that when the button is pressed, it will reset the device, and then, since the button is held down, it will enter DFU mode.
