Switch antenna connector
I have used for my application the reference design of NRF52832.
The connector MURATA MM8130-2600 is used to have the choice between the PCB antenna and an external antenna.
But this switching connector is just compatible with measurment antenna which is very expensive.
Do you know a switching equivalent connector compatible with cheap bluetooth antenna connector? I have found IPEX and HIROSE connectors but they are not available with the common distributors.
Or do you recommand another solution to switch between a PCB antenna and an external antenna?
Thank you in advance.
