SD 140 7.0.1 flash size
nrf_sdm.h:144
#define SD_FLASH_SIZE 0x26000
 This is *wrong* value and causes assert at startup. It should be
#define SD_FLASH_SIZE 0x27000
 as written in release notes.
    This is not actually a bug. The SoftDevice itself is 0x26000, sine the first 0x1000 is used by the MBR. This is described in the API documentation for SD_FLASH_SIZE:
    /** @brief Defines the amount of flash that is used by the SoftDevice.
     *         Add @ref MBR_SIZE to find the first available flash address when the SoftDevice is installed
     *         just above the MBR (the usual case).
    You can find the definition of MBR_SIZE in nrf_mbr.h:
    /** @brief The size that must be reserved for the MBR when a SoftDevice is written to flash.
    This is the offset where the first byte of the SoftDevice hex file is written.*/
    #define MBR_SIZE                (0x1000)
  • FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x52000
    But if my linker file had 0x26000 when using SDK 15, will it be possible to do OTA update to new Soft Device and new SDK? I remember that linker file can not be changed and must stay the same when doing OTA update.
