How to allow Bonding when a button is pressed?
I'm using SDK 7.1, PCA10028 eval board, SD310 2.0.1
My application has no display, and a single button for input. I want to prevent bonding until the button is pressed. Looking at Nordic's documentation I found 1 sequence chart that shows bonding, this chart seems to be for "just works" bonding. Is there a sequence chart for bonding with a static passkey?
Looking through the example projects, most have either "just works" bonding, or bonding with display and entry peripherals.
What is the best approach for this project, with regards to bonding? Do I use a static passkey (hard-coded into the firmware) and when the button is pressed load it?
Is there a good example project that does something like this?
-Clint
