can we use CoreDebug->DHCSR to check if JLink is connected with Monitor Mode Debugging enabled?
    I need a way to dynamically disable watchdog when I do MMD debugging. I found the old trick, check bit 0 on CoreDebug->DHCSR, does not work any more in MMD. Is that expected? Is there any other way to let the device check if JLink is connected?
Thank you,
Min-Ching
