I want example timer + spi (SDK 14.2.0)
Hi, all.
I m trying to combine two example spi + timer using nRF52832.
But spi_event_handler function in the ex spi and timer event in the ex timer are crashed.
If I insert source code "nrf_drv_timer_enable(&TIMER_TEST);", program is died.
I want to result this problem.
Can you help me?
source code is as below.
//const nrf_drv_timer_t TIMER_TEST = NRF_DRV_TIMER_INSTANCE(0);
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
//    NRF_LOG_INFO("Transfer completed.");
//    if (m_rx_buf[0] != 0)
//        NRF_LOG_INFO(" Received:");
//        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
 * @brief Handler for timer events.
void timer_event_handler(nrf_timer_event_t event_type, void* p_context)
    NRF_LOG_INFO("SPI example.");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    // Timer
    uint32_t time_ms = 1000; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    //Configure TIMER_BMS for generating simple light effect - leds on board will invert his state one after the other.
    err_code = nrf_drv_timer_init(&TIMER_TEST, &timer_cfg, timer_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_TEST, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER_BMS, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    while (1)
        spi_xfer_done = false;
        __WFE();
        __WFI();
       // nrf_drv_spi_transfer
        NRF_LOG_FLUSH();
