nRF9160: LTE Sensor Gateway on Thingy:91
I am trying to fun the LTE Sensor Gateway on the Thingy:91.
The boards are missing from zephyr so I copied nrf52840_pca20035 and nrf9160_pca20035 from ncs\nrf\boards\arm.
When running samples/bluetooth/hci_uart.
The BLE and UART don't seem to be configured correctly. I get "warning: BT_CTLR_DTM_HCI" and "warning: BT_CTLR_ASSERT_HANDLER".
I created ncs\zephyr\samples\bluetooth\hci_uart\nrf52840_pca20035.overlay based on https://devzone.nordicsemi.com/f/nordic-q-a/51693/hci_uart-on-thingy-91
This still doesn't work.
Adding the lines below to nfr52840_pca20035\Kconfig.defconfig seem to fix the BLE issues? UART is not working so, I don't know if it is working.
config BT_CTLR
default BT
When running samples/nrf9160/lte_ble_gateway I get errors "warning: UART_2_NRF_UARTE" and "warning: UART_2_NRF_FLOW_CONTROL"
I see that nrf9160_pca20035ns.overlay is missing from the folder but I am not sure how to modify it. There is no status light configured.
Help?
    The Thingy:91 is not configured for this use-case at this time. A colleague of mine tested this a couple of days ago, and here it the changes/files used:
    thingy_91_lte_changes.zip
    nrf_changes.diff applies to ncs/nrf
    zephyr_changes.diff applies to ncs/zephyr
    nrf52840_pca20035.conf and .overlay should be placed in ncs/zephyr/samples/bluetooth/hci_uart/
    nrf9160_pca20035.overlay should be placed in ncs/nrf/samples/lte_ble_gateway/
    Use Segger RTT viewer to view the log output. Note that you need to manually keep the nRF52 in reset for several seconds before releasing it. Holding it in reset is done by grounding TP8 (apply patch to enable reset pin). On the nRF91-DK we are using a GPIO line between the nRF52 and nRF91 in order to reset the nRF52. I believe it should be possible to add this functionality to the thingy:91 as well, by using one of the lines originally used by the UART, e.g. pin 20. But there are some bugs on the master branch at the moment, so this reset functionality is currently not working reliably.
  • Sigurd,
    Thank you!
    Is there a command in Git to use the diff file or should I manually make the changes?
    Thanks
  • You could try the command git apply, if it does not work, make the changes manually
  • Awesome!
    hci_uart seemed to take. I did still get a warning.
    warning: BT_UART_ON_DEV_NAME (defined at drivers/bluetooth/hci/Kconfig:74) was assigned the value
    'UART_1' but got the value ''.
    lte_ble_gateway is failing.
    warning: BSD_LIBRARY (defined at C:/Nordic_SDK/ncs/nrf\lib\bsdlib/Kconfig:8) was assigned the value
    'y' but got the value 'n'.
    warning: AT_CMD (defined at C:/Nordic_SDK/ncs/nrf\drivers\at_cmd/Kconfig:9) has direct dependencies BSD_LIBRARY with value n, but is currently being y-selected by the following symbols:
     - AT_HOST_LIBRARY (defined at C:/Nordic_SDK/ncs/nrf\lib\at_host/Kconfig:9), with value y, direct dependencies y (value: y)
     - LTE_LINK_CONTROL (defined at C:/Nordic_SDK/ncs/nrf\drivers\lte_link_control/Kconfig:7), with value y, direct dependencies y (value: y)
    C:/Nordic_SDK/ncs/nrf/subsys/net/lib/nrf_cloud/src/nrf_cloud_transport.c:272:3: error: #error Missing NRF_CLOUD_CLIENT_ID
    C:/Nordic_SDK/ncs/nrf/drivers/at_cmd/at_cmd.c:12:10: fatal error: bsd_limits.h: No such file or directory
     #include <bsd_limits.h>
    compilation terminated.
    [93/187] Building C object zephyr/modules/nordic/CMakeFile..._modules__hal__nordic.dir/nrfx/drivers/src/nrfx_twim.c.obj
    ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' --build 'C:\Nordic_SDK\ncs\nrf\build'
