While importing the needed libraries for a project I stumbled upon an error in the app_error_handler_gcc.c and app_error_handler_iar.c files. The error is
nrflibraries\nRF5_SDK_15.3.0_59ac345\components\libraries\util\app_error_handler_iar.c(73): error: #18: expected a ")"
This happens in the following block of code:
void app_error_handler(ret_code_t error_code, uint32_t line_num, const uint8_t * p_file_name)
__ASM volatile(
"push {lr} \n"
/* reserve space on stack for error_info_t struct */
"sub sp, sp, %0 \n"
/* prepare error_info_t struct */
"str r0, [sp, %1] \n"
"str r1, [sp, %3] \n"
"str r2, [sp, %2] \n"
/* prepare arguments and call function: app_error_fault_handler */
"ldr.n r0, 1f \n"
"mov r1, LR \n"
"mov r2, sp \n"
/* call app_error_fault_handler */
"bl %c5 \n"
/* release stack */
"add sp, sp, %0 \n"
"pop {pc} \n"
"DATA \n"
"1: \n"
" DC32 %c4 \n"
: /* Outputs */
: /* Inputs */
"i" (APP_ERROR_ERROR_INFO_SIZE_ALIGNED_8BYTE),
"i" (APP_ERROR_ERROR_INFO_OFFSET_ERR_CODE),
"i" (APP_ERROR_ERROR_INFO_OFFSET_P_FILE_NAME),
"i" (APP_ERROR_ERROR_INFO_OFFSET_LINE_NUM),
"i" (NRF_FAULT_ID_SDK_ERROR),
"i" (app_error_fault_handler)
: /* CLobbers */
"r0", "r1", "r2"
The error points towards the start of : /* Outputs */
As I am not familiar with ASM and expect libraries to be working, I'd like to know how I can fix this.
