Getting started with nRF91
I am testing a nRF9160DK board. I am located in Italy, so LTE-M SIMs would not work.
I have received some NB-IOT SIMs from TIM/Olivetti; I found a compiled sample "at_client.hex" on your site and it seems to be working, even if the programmer app said "Device type unknown" after programming.
I assume that LTE green means that NB-IOT goto connected. The connection information looks fine too.
"Telecom Italia" is the former name of TIM.
I installed the whole toolchain following instructions in the Getting Started Assistant (I had to update some references in the requirements.txt files) and compiled the Asset Tracker application but it seems unable to connect.
I verified that:
/* Set network mode to Narrowband-IoT */
static const char network_mode[] = "AT%XSYSTEMMODE=0,1,0,0";
is active in lte_lc.c
I suspect something is not fine in my setup because I am unable to load the other  project for the "nrf_desktop" application choosing either nrf9160_pca10090 or the ns version.
Do you have a compiled hex of the asset_tracker application that is expected to run with NB-IOT so that I can understand if the problem is with the SIM or the toolchain.
I have installed arm_segger_embedded_studio_v420a_win_x64_nordic from the link in getting started; It offers to upgrade to SEGGER Embedded Studio for ARM version 4.22; should I perform the upgrade?
    Could you try adding CONFIG_LTE_NETWORK_MODE_NBIOT=y to the prj.conf file?
    That should set the asset tracked to utilise NB-IoT.
  • I had already added:
    # Added for NBIOT as suggested by
    # devzone.nordicsemi.com/.../203734
    CONFIG_LTE_LEGACY_PCO_MODE=y
    Which activated the line:
  • Can you provide some output from the LTE Link Monitor to show us what's going on with the device?
    Question, does your SIM provider "TIM/Olivetti" offer dynamic IPs over their network. Connection to the nRF Cloud occurs through dynamic MQTT to AWS and this means the endpoint of the connection could be any of a huge list of IP addresses.
    Vodafone NB-IoT Evaluation SIMs do not provide this and require whitelisted IPs so it's good to check as this has caught me out in early development but as it was only for this sample application, it was easy to get around.
    The fact that the Asset Tracker is using: static const char network_mode[] = "AT%XSYSTEMMODE=0,1,0,0"; is a good sign that everything should be set to the NB-IoT version.
  • 2019-10-01T16:48:01.376Z INFO Application data folder: C:\Users\CMAG\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-10-01T16:48:01.424Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2019-10-01T16:48:01.424Z DEBUG App path: C:\Users\CMAG\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-10-01T16:48:01.424Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-10-01T16:48:01.424Z DEBUG nRFConnect path: C:\Users\CMAG\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-10-01T16:48:01.424Z DEBUG HomeDir: C:\Users\CMAG
    2019-10-01T16:48:01.424Z DEBUG TmpDir: C:\Users\CMAG\AppData\Local\Temp
    2019-10-01T16:48:01.426Z VERBOSE Could not fetch serial number for serial port at COM1
    2019-10-01T16:48:04.700Z INFO Modem port is opened
    2019-10-01T16:48:04.706Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-01T16:48:04.718Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-10-01T16:48:04.720Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:04.740Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-10-01T16:48:04.779Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:07.458Z DEBUG modem >> AT\x0D\x0A
    2019-10-01T16:48:07.462Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.538Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-01T16:48:10.543Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-01T16:48:10.553Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:10.555Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-01T16:48:10.561Z DEBUG modem << +CGSN: "352656100044349"\x0D\x0A
    2019-10-01T16:48:10.562Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.565Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-01T16:48:10.571Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-01T16:48:10.572Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.577Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-01T16:48:10.581Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-01T16:48:10.584Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.586Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-01T16:48:10.591Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-01T16:48:10.592Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.593Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100044349
    2019-10-01T16:48:10.594Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-01T16:48:10.600Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-10-01T16:48:10.600Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.609Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-01T16:48:10.617Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D\x0A
    2019-10-01T16:48:10.621Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.628Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-01T16:48:10.631Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-10-01T16:48:10.633Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.635Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-10-01T16:48:10.643Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.647Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-01T16:48:10.652Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-10-01T16:48:10.655Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.660Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-10-01T16:48:10.664Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.672Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-01T16:48:10.680Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-10-01T16:48:10.682Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.687Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-01T16:48:10.693Z DEBUG modem << +CGDCONT: 0,"IP","","",0,0\x0D\x0A
    2019-10-01T16:48:10.695Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.702Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-01T16:48:10.707Z DEBUG modem << +CGACT: 0,0\x0D\x0A
    2019-10-01T16:48:10.708Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:10.713Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-10-01T16:48:10.717Z DEBUG modem << OK\x0D
    2019-10-01T16:48:10.721Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-01T16:48:10.727Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.730Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-01T16:48:10.734Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.742Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-01T16:48:10.749Z DEBUG modem << +CEREG: 2,2,"88F9","07A38752",9\x0D
    2019-10-01T16:48:10.752Z DEBUG modem << \x0A
    2019-10-01T16:48:10.753Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.761Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-01T16:48:10.765Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.769Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:10.774Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:10.776Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.780Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-01T16:48:10.783Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.793Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-01T16:48:10.798Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-01T16:48:10.799Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.808Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-01T16:48:10.813Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-01T16:48:10.814Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:10.822Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-01T16:48:10.842Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-01T16:48:10.844Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.850Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-01T16:48:10.857Z DEBUG modem << 222013206523243\x0D\x0A
    2019-10-01T16:48:10.858Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:10.859Z INFO IMSIdentity: 222013206523243
    2019-10-01T16:48:13.400Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:13.416Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:13.419Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:17.401Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:17.415Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:17.418Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.541Z DEBUG modem << +CGEV: ME PDN ACT 0,0\x0D\x0A\x00
    2019-10-01T16:48:19.553Z DEBUG modem << +CNEC_ESM: 50,0\x0D\x0A\x00
    2019-10-01T16:48:19.559Z DEBUG modem << +CEREG: 1,"88F9","07A38752",9\x0D\x0A\x00
    2019-10-01T16:48:19.564Z DEBUG modem << +CIND: "service",1\x0D\x0A\x00
    2019-10-01T16:48:19.574Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-01T16:48:19.582Z DEBUG modem << +CGDCONT: 0,"IP","nbiot.tids.tim.it","10.16.31.197",0,0\x0D\x0A
    2019-10-01T16:48:19.583Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.589Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2019-10-01T16:48:19.593Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:19.595Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-01T16:48:19.599Z DEBUG modem << +CGACT: 0,1\x0D
    2019-10-01T16:48:19.600Z DEBUG modem << \x0A
    2019-10-01T16:48:19.600Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.602Z DEBUG modem >> AT+COPS?\x0D\x0A
    2019-10-01T16:48:19.607Z DEBUG modem << +COPS: 0,2,"22201",9\x0D\x0A
    2019-10-01T16:48:19.610Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.613Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2019-10-01T16:48:19.617Z DEBUG modem << %XCBAND: 20\x0D\x0A
    2019-10-01T16:48:19.618Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.625Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-01T16:48:19.633Z DEBUG modem << +CGDCONT: 0,"IP","nbiot.tids.tim.it","10.16.31.197",0,0\x0D\x0A
    2019-10-01T16:48:19.634Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:19.640Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-01T16:48:19.644Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2019-10-01T16:48:19.645Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:21.400Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:21.416Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:21.418Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:25.399Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:25.406Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:25.407Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:29.400Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-01T16:48:29.414Z DEBUG modem << +CESQ: 99,99,255,255,255,37\x0D\x0A
    2019-10-01T16:48:29.414Z DEBUG modem << OK\x0D
    2019-10-01T16:48:30.606Z DEBUG modem << +CEREG: 1,"88FA","07A7FC52",9\x0D
    2019-10-01T16:48:30.616Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2019-10-01T16:48:30.619Z DEBUG modem << OK\x0D\x0A
    2019-10-01T16:48:30.623Z DEBUG modem >> AT+COPS?\x0D\x0A
    2019-10-01T16:48:30.628Z DEBUG modem << +COPS: 0,2,"22201",9\x0D
    2019-10-01T16:48:30.629Z DEBUG modem << \x0A
    2019-10-01T16:48:30.630Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:30.633Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2019-10-01T16:48:30.641Z DEBUG modem << %XCBAND: 20\x0D\x0A
    2019-10-01T16:48:30.642Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:30.645Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-01T16:48:30.657Z DEBUG modem << +CGDCONT: 0,"IP","nbiot.tids.tim.it","10.16.31.197",0,0\x0D\x0A
    2019-10-01T16:48:30.658Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-01T16:48:30.661Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-01T16:48:30.675Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2019-10-01T16:48:30.676Z DEBUG modem << OK\x0D\x0A\x00
    asset_tracker.txt
    at_client ended in a correct connection (at least to TIM base station).
    I uploaded both files using the Programmer app of nRF Connect.
    The asset tracker file is the merged.hex file found in C:\Projects\ncs\nrf\applications\asset_tracker\build_nrf9160_pca10090ns\zephyr after compiling
    TIM SIMs should not be restricted as Vodafone are. Anyway, if you have a working hex file for NB-IOT I would like to check it out to exclude the problem is with the SIM.
  • Maybe I am making a mistake in building the application: I am just building the NS version; on Zephyr site (docs.zephyrproject.org/.../index.html) the options are:
    1. Building Secure/Non-Secure Zephyr applications
    2. Building a Secure only application
    There is no option for building a NS application only.
    Am I missing something?
