My system is going to run off a Lithium Ion battery.
I don't need to use the USB Interface on nRF52840.
Is it okay for me to leave VBUS, D+, D- floating?
And connect 4.2V Li+ Battery to VDDH?
Hani Abidi
Hani Abidi
As far and I know, there is no requirement to connect VBUS, D+, D-.
VDDH can accept upto 5.5V, so yes you can run with a li-ion battery with way.
LDO only:
DCDC:
Hi Hani
It's recommended to ground VBUS, as this activates an on-chip pull-down on DECUSB, which means you don't need to use the capacitor in the ref. design, which "saves" you a component. D+ and D- is fine to leave floating.
Sashi is absolutely correct in regards to the li-ion battery.
Simon
