BLE APP UART
This example I got it working with nrf toolbox app, but I was wondering if this should work also with a win7 PC.
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/usbd_cdc_acm_example.html
I got this window:
But it never asked for a pairing code.
Karel.
  • Hi Karel,
    we do have the pc-ble-driver-py which is a serialization library over serial port that provides Python bindings for our nrf-ble-driver library.
    Best regards
    Bjørn
  • Hello Bjorn,
    I installed this driver, but my python3 installation complains:
    ModuleNotFoundError: No module named 'Queue'
    So installed using python2.7, it installs well, but it seems not to be able to import  pc_ble_driver_py.
    (can be due to my "abandoned" python2 installation...)
    On top I found this issue:
    https://github.com/NordicSemiconductor/pc-ble-driver-py/issues/64#issuecomment-477932904
    So probably it won't work with my nrf52840 dongle anyways...
    Karel.
  • Hello Bjorn,
    I wrote a little python script, it uses pygatt, which I believe does not work on windows...
    In linux it worked.
    Can you comment if this is the way to go?
    Karel.
    #!/usr/bin/env python
    import binascii
    import pygatt
    from time import sleep
    YOUR_DEVICE_ADDRESS = "11:22:33:44:55:66"
    # Many devices, e.g. Fitbit, use random addressing - this is required to connect.
    ADDRESS_TYPE = pygatt.BLEAddressType.random
    adapter = pygatt.GATTToolBackend()
    adapter.start()
    device = adapter.connect(YOUR_DEVICE_ADDRESS, address_type=ADDRESS_TYPE)
    uuid_write = None
    uuid_notify = None
    print("scanning {}:".format(YOUR_DEVICE_ADDRESS))
    for uuid in device.discover_characteristics().keys():
      if str(uuid) == "6e400002-b5a3-f393-e0a9-e50e24dcca9e": # write PC to BLE-UART...
        device.char_write(uuid, bytearray([0x33, 0x33, 0x30]))
        uuid_write = uuid
        continue
      if str(uuid) == "6e400003-b5a3-f393-e0a9-e50e24dcca9e": # notify PC from BLE-UART...
        uuid_notify = uuid
        continue
      print("Read UUID %s: " % (uuid))
      print("%s" % (binascii.hexlify(device.char_read(uuid))))
    print("notification mode..")
    def cb_ble_uart(handle, data):
      print("cb_ble_uart", data)
    device.subscribe(uuid_notify, cb_ble_uart)
    for i in range(10):
      device.char_write(uuid_write, bytearray([0x33, 0x33]))
      sleep(1)
  • Hi Karelv,
    Just to reply to your previous comment on pc-ble-drive-py installation.
    I have not used the python bindings of the pc-ble-driver, but conflicting python installations could be an issue.
    As for the nRF52840 dongle support, I know that its lagging a bit behind the pc-ble-driver thats written in C, which supports the nRF52840 dongle so if you're not locked to python, then you could use that instead.
    In linux it worked.
    Which Windows version are you using? Could be that there isnt proper support for BLE in your particular version or that pygatt has not been updated to support the windows driver. On linux I would guess that its using Bluez which usually works like a charm.
    I am not very experienced with pygatt so  might not be the right person to ask. I have a javascript library called noble and a c library called gattool on a Raspberry Pi.
    Best regards
    Bjørn
  • Hi Karelv,
    In linux it worked.
    Best regards
    Bjørn
