I used This char tutorial for this project. Basicly I added beacon advertising mod with a connection mode to this project and I tried to changed minor and major of the device from the nRF Connect app. I also want to add a pass char to made a authorized system. But i am having a fatal error when i trying to add a pass char to my servis. Error is emerging at the our_service.c at line 209. I will be gratefull. Thank you!
My main.c:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
/** * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ #include "our_service.h" #include "our_service.c" #include <stdbool.h> #include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "app_error.h" #include "ble.h" #include "ble_hci.h" #include "ble_srv_common.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "nrf_sdh.h" #include "nrf_sdh_soc.h" #include "nrf_sdh_ble.h" #include "app_timer.h" #include "fds.h" #include "peer_manager.h" #include "bsp_btn_ble.h" #include "sensorsim.h" #include "ble_conn_state.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "nrf_pwr_mgmt.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #include "lutfu_beacon.h" #include "bsp.h" #include "nrf_soc.h" #define DEVICE_NAME "lutfu" /**< Name of device. Will be included in the advertising data. */ #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */ #define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */ #define APP_ADV_DURATION 45 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */ #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */ #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ #define SEC_PARAM_BOND 1 /**< Perform bonding. */ #define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */ #define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */ #define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */ #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */ #define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */ #define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */ #define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ //////////// #define APP_COMPANY_IDENTIFIER 0x0059 #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */ #define APP_TEMP_VALUE 0x00,0x00,0x00,0x00 #define APP_HUM_VALUE 0x00,0x00,0x00,0x00 #define APP_PRES_VALUE 0x00,0x00,0x00,0x00 #define APP_BEACON_SERVICE_INFO_LENGTH 0x0c static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */ static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */ static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */ static uint8_t m_enc_srdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */ /////////////// NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */ static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ /////////////////////////// static uint8_t telemetry_default_service_info[APP_BEACON_SERVICE_INFO_LENGTH] = { APP_TEMP_VALUE, APP_HUM_VALUE, APP_PRES_VALUE, }; static ble_gap_adv_data_t m_adv_data = { .adv_data = { .p_data = m_enc_advdata, .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX }, .scan_rsp_data = { .p_data = m_enc_srdata, .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX } }; static void delete_bonds(void) { ret_code_t err_code; NRF_LOG_INFO("Erase bonds!"); err_code = pm_peers_delete(); APP_ERROR_CHECK(err_code); } static void advertising_init(void) { //////////////////////////////////////////// NRF_LOG_INFO("advertising init"); uint32_t err_code; ble_advdata_t advdata, scanrsp; uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED; ble_advdata_manuf_data_t manuf_specific_data; manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER; manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info; manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH; //////////////////////////////////////////////// //// memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_NO_NAME; advdata.flags = flags; advdata.p_manuf_specific_data = &manuf_specific_data; // Build and set scan response data. ble_advdata_service_data_t service_data; service_data.service_uuid = 0x180A; service_data.data.p_data = (uint8_t *) telemetry_default_service_info; service_data.data.size = APP_BEACON_SERVICE_INFO_LENGTH; memset(&scanrsp, 0, sizeof(scanrsp)); scanrsp.name_type = BLE_ADVDATA_FULL_NAME; //scanrsp.p_tx_power_level = 8; scanrsp.p_service_data_array = &service_data; scanrsp.service_data_count = 1; //// m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; m_adv_params.p_peer_addr = NULL; // Undirected advertisement. m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY; m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL; m_adv_params.duration = 0; // Never time out. err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len); APP_ERROR_CHECK(err_code); err_code = ble_advdata_encode(&scanrsp, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params); APP_ERROR_CHECK(err_code); } static void advertising_start(bool erase_bonds) { if (erase_bonds == true) { delete_bonds(); // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event } else { NRF_LOG_INFO("advertising_start()\r\n"); ret_code_t err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG); APP_ERROR_CHECK(err_code); err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); APP_ERROR_CHECK(err_code); } } //////////////////////// // FROM_SERVICE_TUTORIAL: Declare a service structure for our application ble_os_t m_our_service; // OUR_JOB: Step 3.G, Declare an app_timer id variable and define our timer interval and define a timer interval APP_TIMER_DEF(m_our_char_timer_id); #define OUR_CHAR_TIMER_INTERVAL APP_TIMER_TICKS(1000) //1000 ms intervals /**@brief Callback function for asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } /**@brief Function for handling Peer Manager events. * * @param[in] p_evt Peer Manager event. */ static void pm_evt_handler(pm_evt_t const * p_evt) { ret_code_t err_code; switch (p_evt->evt_id) { case PM_EVT_BONDED_PEER_CONNECTED: { NRF_LOG_INFO("Connected to a previously bonded device."); } break; case PM_EVT_CONN_SEC_SUCCEEDED: { NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.", ble_conn_state_role(p_evt->conn_handle), p_evt->conn_handle, p_evt->params.conn_sec_succeeded.procedure); } break; case PM_EVT_CONN_SEC_FAILED: { /* Often, when securing fails, it shouldn't be restarted, for security reasons. * Other times, it can be restarted directly. * Sometimes it can be restarted, but only after changing some Security Parameters. * Sometimes, it cannot be restarted until the link is disconnected and reconnected. * Sometimes it is impossible, to secure the link, or the peer device does not support it. * How to handle this error is highly application dependent. */ } break; case PM_EVT_CONN_SEC_CONFIG_REQ: { // Reject pairing request from an already bonded peer. pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false}; pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config); } break; case PM_EVT_STORAGE_FULL: { // Run garbage collection on the flash. err_code = fds_gc(); if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES) { // Retry. } else { APP_ERROR_CHECK(err_code); } } break; case PM_EVT_PEERS_DELETE_SUCCEEDED: { advertising_start(false); } break; case PM_EVT_PEER_DATA_UPDATE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error); } break; case PM_EVT_PEER_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error); } break; case PM_EVT_PEERS_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error); } break; case PM_EVT_ERROR_UNEXPECTED: { // Assert. APP_ERROR_CHECK(p_evt->params.error_unexpected.error); } break; case PM_EVT_CONN_SEC_START: case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: case PM_EVT_PEER_DELETE_SUCCEEDED: case PM_EVT_LOCAL_DB_CACHE_APPLIED: case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED: // This can happen when the local DB has changed. case PM_EVT_SERVICE_CHANGED_IND_SENT: case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED: default: break; } } /**@brief Function for the Timer initialization. * * @details Initializes the timer module. This creates and starts application timers. */ static void timers_init(void) { NRF_LOG_INFO("timers init"); // Initialize timer module. ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; NRF_LOG_INFO("gap params init"); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the GATT module. */ static void gatt_init(void) { NRF_LOG_INFO("gatt init"); ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL); APP_ERROR_CHECK(err_code); } /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { NRF_LOG_INFO("services init"); uint32_t err_code; nrf_ble_qwr_init_t qwr_init = {0}; // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("services init middle"); //FROM_SERVICE_TUTORIAL: Add code to initialize the services used by the application. our_service_init(&m_our_service); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("services init end"); } /**@brief Function for handling the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module which * are passed to the application. * @note All this function does is to disconnect. This could have been done by simply * setting the disconnect_on_fail config parameter, but instead we use the event * handler mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { ret_code_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling a Connection Parameters error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { ret_code_t err_code; ble_conn_params_init_t cp_init; NRF_LOG_INFO("conn params init"); memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for starting timers. */ static void application_timers_start(void) { // OUR_JOB: Step 3.I, Start our timer app_timer_start(m_our_char_timer_id, OUR_CHAR_TIMER_INTERVAL, NULL); //To update temperature only when in a connection then don't call app_timer_start() here, but in ble_event_handler() } /**@brief Function for putting the chip into sleep mode. * * @note This function will not return. */ static void sleep_mode_enter(void) { ret_code_t err_code; err_code = bsp_indication_set(BSP_INDICATE_IDLE); APP_ERROR_CHECK(err_code); // Prepare wakeup buttons. err_code = bsp_btn_ble_sleep_mode_prepare(); APP_ERROR_CHECK(err_code); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { ret_code_t err_code = NRF_SUCCESS; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected."); /////////////// upload_mm_lutfu(); ///////////////// // LED indication will be changed when advertising starts. advertising_init(); advertising_start(false); upload_mm_lutfu(); break; case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected."); upload_mm_lutfu(); err_code = bsp_indication_set(BSP_INDICATE_CONNECTED); APP_ERROR_CHECK(err_code); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); //When connected; start our timer to start regular temperature measurements app_timer_start(m_our_char_timer_id, OUR_CHAR_TIMER_INTERVAL, NULL); break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("GATT Client Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("GATT Server Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTC_EVT_READ_RSP: // Disconnect on GATT Server timeout event. advertising_init(); advertising_start(false); break; default: // No implementation needed. break; } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; NRF_LOG_INFO("ble_stack init"); err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); //OUR_JOB: Step 3.C Set up a BLE event observer to call ble_our_service_on_ble_evt() to do housekeeping of ble connections related to our service and characteristics. NRF_SDH_BLE_OBSERVER(m_our_service_observer, APP_BLE_OBSERVER_PRIO, ble_our_service_on_ble_evt, (void*) &m_our_service); } /**@brief Function for the Peer Manager initialization. */ static void peer_manager_init(void) { ble_gap_sec_params_t sec_param; ret_code_t err_code; err_code = pm_init(); APP_ERROR_CHECK(err_code); memset(&sec_param, 0, sizeof(ble_gap_sec_params_t)); // Security parameters to be used for all security procedures. sec_param.bond = SEC_PARAM_BOND; sec_param.mitm = SEC_PARAM_MITM; sec_param.lesc = SEC_PARAM_LESC; sec_param.keypress = SEC_PARAM_KEYPRESS; sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES; sec_param.oob = SEC_PARAM_OOB; sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE; sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE; sec_param.kdist_own.enc = 1; sec_param.kdist_own.id = 1; sec_param.kdist_peer.enc = 1; sec_param.kdist_peer.id = 1; err_code = pm_sec_params_set(&sec_param); APP_ERROR_CHECK(err_code); err_code = pm_register(pm_evt_handler); APP_ERROR_CHECK(err_code); } /**@brief Clear bond information from persistent storage. */ /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated when button is pressed. */ static void bsp_event_handler(bsp_event_t event) { ret_code_t err_code; switch (event) { case BSP_EVENT_SLEEP: sleep_mode_enter(); break; // BSP_EVENT_SLEEP case BSP_EVENT_DISCONNECT: err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } break; // BSP_EVENT_DISCONNECT case BSP_EVENT_WHITELIST_OFF: if (m_conn_handle == BLE_CONN_HANDLE_INVALID) { err_code = ble_advertising_restart_without_whitelist(&m_advertising); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } } break; // BSP_EVENT_KEY_0 default: break; } } /**@brief Function for initializing the Advertising functionality. */ /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up. */ static void buttons_leds_init(bool * p_erase_bonds) { ret_code_t err_code; bsp_event_t startup_event; NRF_LOG_INFO("button leds init"); err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /**@brief Function for initializing the nrf log module. */ static void log_init(void) { NRF_LOG_INFO("LOG init"); ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { NRF_LOG_INFO("power management init"); ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). * * @details If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } /**@brief Function for application main entry. */ int main(void) { bool erase_bonds; // Initialize. log_init(); timers_init(); buttons_leds_init(&erase_bonds); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); peer_manager_init(); // Start execution. NRF_LOG_INFO("lutfu tutorial started."); upload_mm_lutfu(); application_timers_start(); advertising_start(erase_bonds); // Enter main loop. for (;;) { idle_state_handle(); } } /** * @} */
My our_service.c
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#include <stdint.h>
#include <string.h>
#include "nrf_gpio.h"
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18
uint8_t index = 18;
uint8_t value[4] = {0,0,0,0};
uint32_t err_code; // Variable to hold return codes from library and softdevice functions
ble_uuid_t service_uuid;
//ble_gattc_handle_range_t ble_gattc_handle_range;
const ble_gattc_handle_range_t ble_gattc_handle_range ={ 0x0001 , 0xFFFF };
ble_uuid_t char_uuid; ///ble_uuid
#include <stdint.h> #include <string.h> #include "nrf_gpio.h" #include "our_service.h" #include "ble_srv_common.h" #include "app_error.h" #include "lutfu_beacon.h" #include "nrf_log.h" #define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 uint8_t index = 18; uint8_t value[4] = {0,0,0,0}; uint32_t err_code; // Variable to hold return codes from library and softdevice functions ble_uuid_t service_uuid; //ble_gattc_handle_range_t ble_gattc_handle_range; const ble_gattc_handle_range_t ble_gattc_handle_range ={ 0x0001 , 0xFFFF }; ble_uuid_t char_uuid; ///ble_uuid // ALREADY_DONE_FOR_YOU: Declaration of a function that will take care of some housekeeping of ble connections related to our service and characteristic void ble_our_service_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context) { // OUR_JOB: Step 3.D Implement switch case handling BLE events related to our service. ble_os_t * p_our_service =(ble_os_t *) p_context; ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle; break; case BLE_GAP_EVT_DISCONNECTED: p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID; break; case BLE_GATTS_EVT_WRITE: NRF_LOG_INFO("write event."); uint8_t *data =(uint8_t *) p_evt_write->data; int i = 1; for (uint8_t *d = data; *d != '\0'; d++) { NRF_LOG_INFO("char value %x",*d); m_beacon_info[17+i] = *d; NRF_LOG_INFO("sent info to beacon info %x",m_beacon_info[17+i]); NRF_LOG_INFO("addition char value %x",i); i++; } // on_write(p_admin, p_ble_evt); break; default: // No implementation needed. break; } } /**@brief Function for adding our new characterstic to "Our service" that we initiated in the previous tutorial. * * @param[in] p_our_service Our Service structure. * */ static uint32_t our_char_add(ble_os_t * p_our_service) { // OUR_JOB: Step 2.A, Add a custom characteristic UUID uint32_t err_code; ble_uuid_t char_uuid; ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID; char_uuid.uuid = BLE_UUID_OUR_CHARACTERISTC_UUID; err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type); APP_ERROR_CHECK(err_code); // OUR_JOB: Step 2.F Add read/write properties to our characteristic ble_gatts_char_md_t char_md; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.read = 1; char_md.char_props.write = 1; // OUR_JOB: Step 3.A, Configuring Client Characteristic Configuration Descriptor metadata and add to char_md structure ble_gatts_attr_md_t cccd_md; memset(&cccd_md, 0, sizeof(cccd_md)); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; char_md.char_props.notify = 1; // OUR_JOB: Step 2.B, Configure the attribute metadata ble_gatts_attr_md_t attr_md; memset(&attr_md, 0, sizeof(attr_md)); attr_md.vloc = BLE_GATTS_VLOC_STACK; // OUR_JOB: Step 2.G, Set read/write security levels to our characteristic BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); // OUR_JOB: Step 2.C, Configure the characteristic value attribute ble_gatts_attr_t attr_char_value; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &char_uuid; attr_char_value.p_attr_md = &attr_md; // OUR_JOB: Step 2.H, Set characteristic length in number of bytes //uint8_t srac1[2] = APP_MINOR_VALUE; attr_char_value.max_len = 4; attr_char_value.init_len = 4; value[0]= m_beacon_info[18]; value[1]= m_beacon_info[19]; value[2]= m_beacon_info[20]; value[3]= m_beacon_info[21]; attr_char_value.p_value = value; // OUR_JOB: Step 2.E, Add our new characteristic to the service err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle, &char_md, &attr_char_value, &p_our_service->char_handles); APP_ERROR_CHECK(err_code); return NRF_SUCCESS; } uint32_t password_add(ble_os_t * p_our_service) { ble_gatts_char_md_t char_md; ble_gatts_attr_t attr_char_value; ble_uuid_t ble_uuid; ble_gatts_attr_md_t attr_md; ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID; ble_uuid.uuid = PASSWORD_CHAR; err_code = sd_ble_uuid_vs_add(&base_uuid, &ble_uuid.type); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("pass add 1 "); memset(&char_md, 0, sizeof(char_md)); char_md.char_props.write = 1; char_md.char_props.read = 1; char_md.p_char_user_desc = NULL; char_md.p_char_pf = NULL; char_md.p_user_desc_md = NULL; char_md.p_cccd_md = NULL; char_md.p_sccd_md = NULL; ble_gatts_attr_md_t cccd_md; memset(&cccd_md, 0, sizeof(cccd_md)); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; ble_uuid.type = p_our_service->uuid_type; ble_uuid.uuid = PASSWORD_CHAR; NRF_LOG_INFO("pass add 2"); memset(&attr_md, 0, sizeof(attr_md)); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); attr_md.vloc = BLE_GATTS_VLOC_STACK; attr_md.rd_auth = 0; attr_md.wr_auth = 0; attr_md.vlen = 0; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &ble_uuid; attr_char_value.p_attr_md = &attr_md; attr_char_value.init_len = 5; attr_char_value.init_offs = 0; attr_char_value.max_len = 5; attr_char_value.p_value = NULL; NRF_LOG_INFO("pass add 3 "); err_code = sd_ble_gatts_characteristic_add( p_our_service->service_handle, \ &char_md, \ &attr_char_value, \ &p_our_service->password_handles); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("pass add 4 "); return NRF_SUCCESS; } static uint32_t our_pass_add(ble_os_t * p_our_service) { // OUR_JOB: Step 2.A, Add a custom characteristic UUID uint32_t err_code; ble_uuid_t char_uuid; ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID; char_uuid.uuid = PASSWORD_CHAR; err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type); APP_ERROR_CHECK(err_code); // OUR_JOB: Step 2.F Add read/write properties to our characteristic ble_gatts_char_md_t char_md; memset(&char_md, 0, sizeof(char_md)); char_md.char_props.write = 1; // OUR_JOB: Step 3.A, Configuring Client Characteristic Configuration Descriptor metadata and add to char_md structure ble_gatts_attr_md_t cccd_md; memset(&cccd_md, 0, sizeof(cccd_md)); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm); cccd_md.vloc = BLE_GATTS_VLOC_STACK; char_md.p_cccd_md = &cccd_md; char_md.char_props.notify = 1; // OUR_JOB: Step 2.B, Configure the attribute metadata ble_gatts_attr_md_t attr_md; memset(&attr_md, 0, sizeof(attr_md)); attr_md.vloc = BLE_GATTS_VLOC_STACK; // OUR_JOB: Step 2.G, Set read/write security levels to our characteristic BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm); // OUR_JOB: Step 2.C, Configure the characteristic value attribute ble_gatts_attr_t attr_char_value; memset(&attr_char_value, 0, sizeof(attr_char_value)); attr_char_value.p_uuid = &char_uuid; attr_char_value.p_attr_md = &attr_md; // OUR_JOB: Step 2.H, Set characteristic length in number of bytes //uint8_t srac1[2] = APP_MINOR_VALUE; attr_char_value.max_len = 4; attr_char_value.init_len = 4; attr_char_value.p_value = value; // OUR_JOB: Step 2.E, Add our new characteristic to the service err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle, &char_md, &attr_char_value, &p_our_service->char_handles); APP_ERROR_CHECK(err_code); return NRF_SUCCESS; } void upload_mm_lutfu(){ NRF_LOG_INFO("m_beacon_info values."); NRF_LOG_INFO("beacon info %x",m_beacon_info[16]); NRF_LOG_INFO("beacon info %x",m_beacon_info[17]); NRF_LOG_INFO("beacon info %x",m_beacon_info[18]); NRF_LOG_INFO("beacon info %x",m_beacon_info[19]); NRF_LOG_INFO("beacon info %x",m_beacon_info[20]); NRF_LOG_INFO("beacon info %x",m_beacon_info[21]); } /**@brief Function for initiating our new service. * * @param[in] p_our_service Our Service structure. * */ void our_service_init(ble_os_t * p_our_service) { // FROM_SERVICE_TUTORIAL: Declare 16-bit service and 128-bit base UUIDs and add them to the BLE stack ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID; service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID; err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type); APP_ERROR_CHECK(err_code); // OUR_JOB: Step 3.B, Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection. p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID; // FROM_SERVICE_TUTORIAL: Add our service err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &service_uuid, &p_our_service->service_handle); APP_ERROR_CHECK(err_code); // OUR_JOB: Call the function our_char_add() to add our new characteristic to the service. our_char_add(p_our_service); NRF_LOG_INFO("our char add done"); our_char_add(p_our_service); our_pass_add(p_our_service); //password_add(p_our_service); NRF_LOG_INFO("pass add done"); }
My our_service.h
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#ifndef OUR_SERVICE_H__
#define OUR_SERVICE_H__
#include <stdint.h>
#include "ble.h"
#include <nrf_sdh_ble.h>
// FROM_SERVICE_TUTORIAL: Defining 16-bit service and 128-bit base UUIDs
#define BLE_UUID_OUR_BASE_UUID {{0x23, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}} // 128-bit base UUID
#define BLE_UUID_OUR_SERVICE_UUID 0xF00D // Just a random, but recognizable value
// ALREADY_DONE_FOR_YOU: Defining 16-bit characteristic UUID
#define BLE_UUID_OUR_CHARACTERISTC_UUID 0xBEEF // Just a random, but recognizable value
#define PASSWORD_CHAR 0x1001
// This structure contains various status information for our service.
#ifndef OUR_SERVICE_H__ #define OUR_SERVICE_H__ #include <stdint.h> #include "ble.h" #include "ble_srv_common.h" #include "nrf_ble_gatt.h" #include <nrf_sdh_ble.h> // FROM_SERVICE_TUTORIAL: Defining 16-bit service and 128-bit base UUIDs #define BLE_UUID_OUR_BASE_UUID {{0x23, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}} // 128-bit base UUID #define BLE_UUID_OUR_SERVICE_UUID 0xF00D // Just a random, but recognizable value // ALREADY_DONE_FOR_YOU: Defining 16-bit characteristic UUID #define BLE_UUID_OUR_CHARACTERISTC_UUID 0xBEEF // Just a random, but recognizable value #define PASSWORD_CHAR 0x1001 // This structure contains various status information for our service. // The name is based on the naming convention used in Nordics SDKs. // 'ble� indicates that it is a Bluetooth Low Energy relevant structure and // �os� is short for Our Service). typedef struct { uint16_t conn_handle; /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection).*/ uint16_t service_handle; /**< Handle of Our Service (as provided by the BLE stack). */ // OUR_JOB: Step 2.D, Add handles for the characteristic attributes to our struct ble_gatts_char_handles_t char_handles; ble_gatts_char_handles_t password_handles; /////pass char////////// uint8_t uuid_type; ////// ble_gatts_char_handles_t uuid_handles; }ble_os_t; ////////////////// ////////////////// /**@brief Function for handling BLE Stack events related to our service and characteristic. * * @details Handles all events from the BLE stack of interest to Our Service. * * @param[in] p_our_service Our Service structure. * @param[in] p_ble_evt Event received from the BLE stack. */ void ble_our_service_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context); /**@brief Function for initializing our new service. * * @param[in] p_our_service Pointer to Our Service structure. */ void our_service_init(ble_os_t * p_our_service); /**@brief Function for updating and sending new characteristic values * * @details The application calls this function whenever our timer_timeout_handler triggers * * @param[in] p_our_service Our Service structure. * @param[in] characteristic_value New characteristic value. */ void our_temperature_characteristic_update(ble_os_t *p_our_service, int32_t *temperature_value); #endif /* _ OUR_SERVICE_H__ */
My second header file lutfu_beacon.h:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#ifndef LUTFU_BEACON_H__
#define LUTFU_BEACON_H__
#define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */
//uint8_t APP_MAJOR_VALUE[2] = {0x01, 0x02 };
//uint8_t APP_MINOR_VALUE[2] = {0x03, 0x04 };
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = //< Information advertised by the Beacon.
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
#ifndef LUTFU_BEACON_H__ #define LUTFU_BEACON_H__ #define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */ #define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */ #define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */ #define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */ #define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */ #define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */ #define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */ #define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \ 0x45, 0x56, 0x67, 0x78, \ 0x89, 0x9a, 0xab, 0xbc, \ 0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */ //uint8_t APP_MAJOR_VALUE[2] = {0x01, 0x02 }; //uint8_t APP_MINOR_VALUE[2] = {0x03, 0x04 }; static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = //< Information advertised by the Beacon. { APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this // implementation. APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the // manufacturer specific data in this implementation. APP_BEACON_UUID, // 128 bit UUID value. APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons. APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons. APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in // this implementation. }; #endif /* LUTFU_BEACON_H__ */
