SAADC reading changes after system finish booting
Hi everyone,
I am having problems reading the battery level using the SAADC. The main problem is that the reading is not consistent from when the device is booting to once the device has boot completely an is stable/IDLE.
During the initialization the reading is around 4.2 V for battery totally charged while later it drops to around 3.6 V.
Hardware Configuration:
To read the battery, I have a voltage divider connected to the AIN0 pin for reading the battery voltage. The resistor pulled to ground is 51K ohms while the one pulled to VBAT is 100k ohms. I had checked the voltage across both resistor with a multimeter and it stays consistent the whole time. So, it seems like a software problem.
Software Configuration:
For reading the battery, I am using a simple blocking approach using the SAADC in single mode in the pin AIN0. The SAADC is configured as:
   // SAADC configuration
    nrf_drv_saadc_config_t saadc_config;
    saadc_config.low_power_mode = true;
    saadc_config.resolution = SAADC_RESOLUTION;
    saadc_config.oversample = SAADC_OVERSAMPLE;
    // SAADC CHANNEL configuration
    channel_config.gain = NRF_SAADC_GAIN1_6;
    channel_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
    channel_config.acq_time = NRF_SAADC_ACQTIME_20US;
    channel_config.burst = SAADC_BURST_MODE;
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);              // Init SAADC channel
and then use the simple function `nrf_drv_saadc_sample_convert()` to read the battery, like:
    nrf_saadc_value_t value;
    ret_code_t err_code;
    saadc_init(false);
    err_code = nrf_drv_saadc_sample_convert(0, &value);
    saadc_uninit();
The oversampling and burst are currently disable, but I had tried those to with same result. I had also tried calibrate before the reading, use a buffer to get an average value or increase the acquisition time but none of those helped at all. I still got the same results.
One thing worthy to mention is that, the battery read changes after the LCD is turned on and the system uses SPI for communicate with the LCD hardware. This makes me wonder if there is a possibility that the SPI could cause problems with the SAADC somehow.
spw.
    So the SAADC readings is different depening on what state you are in? Does it only happen if you read the battery? Or does it happen if you try to read another source as well?
    Edvin
  • Hi Edvin,
    Mora than in the state, it depends on the LCD being ON, or not. One of my latest test has been:
    1- Boot the device normally. (this includes, turn on the LCD).
    2- Read the battery using the SAADC.
    3- Cut off the LCD power using the voltage regulator.
    4- Read the battery using the SAADC.
    In this test, the result was a correct battery reading after the LCD power was cut off (step 4), but not before cut the power (step 2).
    So, somehow, it seems like the LCD is interfering with the SAADC reading, but I have no idea how. Just as an extra piece of information, the LCD is the ili9341, and it's controlled through as SPI communication as I explained previously.
  • spw said:
    Honestly, it's not that I want a layout review or similar, I attached the layout because you requested it. I just want to figure it out this issue which to me seems a software issue.
     Sorry. I forgot. It is a month since I last saw this ticket.
    I am not sure whether this is a software or HW issue. Is it possible for me to recreate this on a DK without the LCD display?
    Can you try to measure with an oscilloscope instead of a multimeter? Maybe something is drawing power very shortly around the time when you are using the ADC? A multimeter will not be able to pick up these quick spikes/dips.
    BR,
    Edvin
  • Is it possible for me to recreate this on a DK without the LCD display?
    No, I don't think it is really possible to recreate it with a development kit. This is probably specific to the PCB & firmware developed.
    I don't think it is possible, I will try it, but I don't think there is a good way to connect the oscilloscope to the PCB in that specific point.
    I have tried to read continuously the battery using the SAADC in blocking mode, and doing nothing else on the firmware than that (No interruptions either). And all values seems the same result, so I don't think there are spikes/dips happening at the same time of the SAADC, unless these spikes/dips are very common.
    spw
  • Ok. Let us try a new approach? Have you done any changes to the SAADC settings? Do you have the same settings in NRFX_SAADC_CONFIG_... and SAADC_CONFIG_...?
  • I haven't done any changes, the configuration it's the same in sdk_config.h
  • Two suggestions, first use completely different software since a software issue is suspected; second take a measurement on Vbatt then take a measurement on Vdd to ensure something peculiar is not happening to the latter. Sample ADC twice in both cases to avoid SAADC issues described elsewhere; don't bother with calibration.
    To  run this sample ensure that the SAADC driver code you were using is not instantiated.
    // Analog positive and negative input channels have strange numbering:
    //  PSELP_NC           0UL  Not connected
    //  PSELP_AnalogInput0 1UL  AIN0
    //  PSELP_AnalogInput1 2UL  AIN1
    //  PSELP_AnalogInput2 3UL  AIN2
    //  PSELP_AnalogInput3 4UL  AIN3
    //  PSELP_AnalogInput4 5UL  AIN4
    //  PSELP_AnalogInput5 6UL  AIN5
    //  PSELP_AnalogInput6 7UL  AIN6
    //  PSELP_AnalogInput7 8UL  AIN7
    //  PSELP_VDD          9UL  VDD
    #define PSELP_AnalogInput0 1
    #define PSELP_VDD          9
    int16_t MeasureBattery(void)
        volatile int16_t AdcCounts = 0;
    #if 0
      // Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy
      while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain
        NRF_SAADC->CH[1].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                                  (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                                  (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                                  (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                                  (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                                  (SAADC_CH_CONFIG_TACQ_40us       << SAADC_CH_CONFIG_TACQ_Pos);
        // Configure the SAADC channel with battery as positive input, no negative input(single ended)
        NRF_SAADC->CH[1].PSELP = PSELP_AnalogInput0;  // Also do PSELP_VDD for Vdd supply
        NRF_SAADC->CH[1].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
        // Configure the SAADC resolution; 14-bit can be used but manual suggests not reliable for single sample
        // NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
        NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_12bit << SAADC_RESOLUTION_VAL_Pos;
        // Configure result to be put in RAM at the location of "AdcCounts" variable
        NRF_SAADC->RESULT.MAXCNT = 1;
        NRF_SAADC->RESULT.PTR = (uint32_t)&AdcCounts;
        // No automatic sampling, will trigger with TASKS_SAMPLE
        NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
        // Enable SAADC
        NRF_SAADC->ENABLE = 1;
        // Start the SAADC and wait for the started event
        NRF_SAADC->TASKS_START = 1;
        while (NRF_SAADC->EVENTS_STARTED == 0)
        NRF_SAADC->EVENTS_STARTED = 0;
        // Do a SAADC sample, will put the result in the configured RAM buffer
        NRF_SAADC->TASKS_SAMPLE = 1;
        while (NRF_SAADC->EVENTS_END == 0)
        NRF_SAADC->EVENTS_END = 0;
        // Stop the SAADC, since it's not used anymore
        NRF_SAADC->TASKS_STOP = 1;
        while (NRF_SAADC->EVENTS_STOPPED == 0)
        NRF_SAADC->EVENTS_STOPPED = 0;
        // second sample
        // Do a SAADC sample, will put the result in the configured RAM buffer.
        // Stop the SAADC, since it's not used anymore.
       // Disable SAADC
       NRF_SAADC->ENABLE = 0;
       return AdcCounts;
    #define PSELP_VDD          9
    #if 0
        // Enable SAADC
        // second sample
       // Disable SAADC
       return AdcCounts;
