fail to generate a TXDRDY Interrupt
I'm unable to configure the UART so, that it will generate the TXDRDY event. I have an UART that should send periodicaly 4 Byte sequences without hardware handshake. I'm able to send the very first byte, but I'm unable to generate the interrupts that I need to send the next consecutive bytes.
The end of the configuration looks like this:
    reg( STARTTX )  = 1;
    sd_nvic_EnableIRQ( UART0_IRQn );
    reg( TXDRDY )   = 0;
    reg( INTENSET ) = 0x80;
I send the first byte by calling a function send_byte() (and the first byte is received correctly):
void send_byte()
    reg( TXDRDY )   = 0;
    std::uint8_t next_byte = *write_ptr_;
    ++write_ptr_;
    reg( TXD ) = next_byte;
I expect this to cause an interrupt, when the byte was send. But my interrupt service function is never been called (veryfied by setting a brakepoint). Any idea, what I'm doing wrong here?
Edit: Now I found a working solution (by accident / experimenting):
void interrupt_serivce()
    reg( INTENCLR ) = 0x80;
    if ( write_ptr_ != write_buffer_.end() )
        send_byte();
template < class SystemVector >
void update( const SystemVector& v )
    if ( write_ptr_ == write_buffer_.end() )
        ***::pack_data< typename Configuration::consumed_signal_list_type >::pack( &write_buffer_[ 2 ], v );
        write_ptr_ = write_buffer_.begin();
        send_byte();
void send_byte()
    reg( TXDRDY )   = 0;
    reg( TXD )      = *write_ptr_;
    ++write_ptr_;
update() is the function that will be called periodically, fills a buffer and directly sends the first byte of the buffer. interrupt_serivce() is the interrupt service handler and is called, when a byte was transmitted.
What puzzles me is, why do I have to disable interups inbetween? If I do not reset the TXDRDY event, interrupts will not be generated. Why is this?
Thanks in advance
