PWM output with stable frequency
SDK: 15.3.0
Example: low_power_pwm
Device: EYSHJNZWZ (nRF52832)
I want to output PWM with a stable frequency.
In the above sample, PWM output with stable frequency was confirmed.
However, when the following processing was added, the frequency of the PWM output became unstable.
Perhaps the reason is that interrupt processing runs.
static	const	nrf_drv_timer_t	m_timer = NRF_DRV_TIMER_INSTANCE(2U);
static	void timer_init(void)
	ret_code_t	err_code;
	uint32_t	ticks;
	nrf_drv_timer_config_t timer_cfg	= NRF_DRV_TIMER_DEFAULT_CONFIG;
	err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, e_timer_short_handler);
	ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 1U);
	nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
Is there a way to perform stable PWM output regardless of other factors such as interrupts?
Is it possible to output PWM at the hardware level?
