error 0x000000007 (Invalid parameter) in advertising_init()
My application is not advertising and after debugging i found error'7' in the line : err_code = ble_advertising_init(&m_advertising, &init); in the advertising_init() function.I am initializing this function after initializing all other functions.I am not able to  solve this error as i don't know what is the reason behind it.Code is attached for reference.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_nus.h"
#include "ble_nus_c.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "app_error.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_srv_common.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
//#include "ble_hrs.h"
//#include "ble_rscs.h"
//#include "ble_hrs_c.h"
//#include "ble_rscs_c.h"
#include "ble_conn_state.h"
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf.h"
#include "app_uart.h"
#include "nrf_uart.h" //or #include "nrf_uarte.h" to use EasyDMA
#if defined (UART_PRESENT)
#if defined (UARTE_PRESENT)
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define DEVICE_NAME                     "nRF Relay"                                 /**< Name of device used for advertising. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 256
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< Tag that identifies the SoftDevice BLE configuration. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size in octets. */
//#define HART_RATE_SERVICE_UUID_IDX      0                                           /**< Hart Rate service UUID index in array. */
//#define RSCS_SERVICE_UUID_IDX           1                                           /**< RSCS service UUID index in array. */
/**@brief   Priority of the application BLE event handler.
 * @note    You shouldn't need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
//static ble_hrs_t m_hrs;                                             /**< Heart Rate Service instance. */
//static ble_rscs_t m_rscs;                                           /**< Running Speed and Cadence Service instance. */
//static ble_hrs_c_t m_hrs_c;                                         /**< Heart Rate Service client instance. */
//static ble_rscs_c_t m_rscs_c;                                       /**< Running Speed and Cadence Service client instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_NUS_C_DEF(m_ble_nus_c);
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);              /**< Context for the Queued Write module.*/
//BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_discovery, 2);                      /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);
                                    /**< Scanning module instance. */
static uint16_t          m_conn_handle = BLE_CONN_HANDLE_INVALID;                   /**< Handle of the current connection. */
//static uint16_t m_conn_handle_hrs_c  = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the HRS central application */
//static uint16_t m_conn_handle_rscs_c = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the RSC central application */
/**@brief Names that the central application scans for, and that are advertised by the peripherals.
 *  If these are set to empty strings, the UUIDs defined below are used.
static char const m_target_periph_name[] = "Wagon_Master";
//#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
/**@brief UUIDs that the central application scans for if the name above is set to an empty string,
 * and that are to be advertised by the peripherals.
//static ble_uuid_t m_adv_uuids[] =
   // {BLE_UUID_HEART_RATE_SERVICE,        BLE_UUID_TYPE_BLE},
    //{BLE_UUID_RUNNING_SPEED_AND_CADENCE, BLE_UUID_TYPE_BLE}
static ble_uuid_t m_sr_uuids[] =
   {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = NRF_BLE_SCAN_SCAN_DURATION,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
    .extended      = true,
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    ble_gap_evt_adv_report_t const * p_adv =
                   p_scan_evt->params.filter_match.p_adv_report;
    ble_gap_scan_params_t    const * p_scan_param =
                   p_scan_evt->p_scan_params;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            // Initiate connection.
            err_code = sd_ble_gap_connect(&p_adv->peer_addr,
                                          p_scan_param,
                                          &m_scan.conn_params,
                                          APP_BLE_CONN_CFG_TAG);
        } break;
/**@brief Function for initialization the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param = &m_scan_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    if (strlen(m_target_periph_name) != 0)
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
                                       SCAN_UUID_FILTER,
                                       //&m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]
                                        &m_sr_uuids);
  /**  err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &m_adv_uuids[RSCS_SERVICE_UUID_IDX]);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
/**@brief Function for initializing the scanning.
static void scan_start(void)
    err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing the advertising and the scanning.
static void adv_scan_start(void)
    //check if there are no flash operations in progress
    if (!nrf_fstorage_is_busy(NULL))
        // Start scanning for peripherals and initiate connection to devices which
        // advertise Heart Rate or Running speed and cadence UUIDs.
        scan_start();
        // Turn on the LED to signal scanning.
        bsp_board_led_on(CENTRAL_SCANNING_LED);
        // Start advertising.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            adv_scan_start();
/**@brief Function for changing filter settings after establishing the connection.
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
                                           SCAN_NAME_FILTER,
/**if ((m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
                                          &m_sr_uuids );
   /** if ((m_conn_handle_hrs_c != BLE_CONN_HANDLE_INVALID) &&
        (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
    /**if ((m_conn_handle_rscs_c != BLE_CONN_HANDLE_INVALID) &&
                                           SCAN_UUID_FILTER,
                                           &m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]);
    //APP_ERROR_CHECK(err_code);
/**@brief Handles events coming from the Heart Rate central module.
/**static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_hrs_c = p_hrs_c_evt->conn_handle;
                NRF_LOG_INFO("HRS discovered on conn_handle 0x%x", m_conn_handle_hrs_c);
                filter_settings_change();
                err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                    m_conn_handle_hrs_c,
                                                    &p_hrs_c_evt->params.peer_db);
                // Initiate bonding.
                err_code = pm_conn_secure(m_conn_handle_hrs_c, false);
                if (err_code != NRF_ERROR_BUSY)
                // Heart rate service discovered. Enable notification of Heart Rate Measurement.
                err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break; // BLE_HRS_C_EVT_DISCOVERY_COMPLETE
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("Heart Rate = %d", p_hrs_c_evt->params.hrm.hr_value);
            err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, p_hrs_c_evt->params.hrm.hr_value);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
        } break; // BLE_HRS_C_EVT_HRM_NOTIFICATION
            // No implementation needed.
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
     //   case BLE_NUS_C_EVT_NUS_TX_EVT:
           // ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            //break;
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
/**@brief Handles events coming from  Running Speed and Cadence central module.
/**static void rscs_c_evt_handler(ble_rscs_c_t * p_rscs_c, ble_rscs_c_evt_t * p_rscs_c_evt)
    switch (p_rscs_c_evt->evt_type)
        case BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_rscs_c = p_rscs_c_evt->conn_handle;
                NRF_LOG_INFO("Running Speed and Cadence service discovered on conn_handle 0x%x",
                             m_conn_handle_rscs_c);
                err_code = ble_rscs_c_handles_assign(p_rscs_c,
                                                    m_conn_handle_rscs_c,
                                                    &p_rscs_c_evt->params.rscs_db);
                err_code = pm_conn_secure(m_conn_handle_rscs_c, false);
                // Running Speed Cadence Service discovered. Enable notifications.
                err_code = ble_rscs_c_rsc_notif_enable(p_rscs_c);
        } break; // BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
        case BLE_RSCS_C_EVT_RSC_NOTIFICATION:
            ble_rscs_meas_t rscs_measurment;
            NRF_LOG_INFO("Speed      = %d", p_rscs_c_evt->params.rsc.inst_speed);
            rscs_measurment.is_running                  = p_rscs_c_evt->params.rsc.is_running;
            rscs_measurment.is_inst_stride_len_present  = p_rscs_c_evt->params.rsc.is_inst_stride_len_present;
            rscs_measurment.is_total_distance_present   = p_rscs_c_evt->params.rsc.is_total_distance_present;
            rscs_measurment.inst_stride_length = p_rscs_c_evt->params.rsc.inst_stride_length;
            rscs_measurment.inst_cadence       = p_rscs_c_evt->params.rsc.inst_cadence;
            rscs_measurment.inst_speed         = p_rscs_c_evt->params.rsc.inst_speed;
            rscs_measurment.total_distance     = p_rscs_c_evt->params.rsc.total_distance;
            err_code = ble_rscs_measurement_send(&m_rscs, &rscs_measurment);
        } break; // BLE_RSCS_C_EVT_RSC_NOTIFICATION
/**@brief Function for assigning new connection handle to available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
    for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++)
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief   Function for handling BLE events from the central application.
 * @details This function parses scanning reports and initiates a connection to peripherals when a
 *          target UUID is found. It updates the status of LEDs used to report the central application
 *          activity.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
   /** switch (p_ble_evt->header.evt_id)
        // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
            NRF_LOG_INFO("Central connected");
            // If no Heart Rate sensor or RSC sensor is currently connected, try to find them on this peripheral.
           // if (   (m_conn_handle_hrs_c  == BLE_CONN_HANDLE_INVALID)
             //   || (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID))
                NRF_LOG_INFO("Attempt to find HRS or RSC on conn_handle 0x%x", p_gap_evt->conn_handle);
                err_code = ble_db_discovery_start(&m_db_discovery[0], p_gap_evt->conn_handle);
                if (err_code == NRF_ERROR_BUSY)
                    err_code = ble_db_discovery_start(&m_db_discovery[1], p_gap_evt->conn_handle);
            // Assign connection handle to the QWR module.
            multi_qwr_conn_handle_assign(p_gap_evt->conn_handle);
            // Update LEDs status, and check whether to look for more peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected,
        // update the LEDs status and start scanning again.
            if (p_gap_evt->conn_handle == m_conn_handle_hrs_c)
                NRF_LOG_INFO("HRS central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
            if (p_gap_evt->conn_handle == m_conn_handle_rscs_c)
                NRF_LOG_INFO("RSC central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
            if (   (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                // Start scanning.
                scan_start();
                // Update LEDs status.
            if (ble_conn_state_central_conn_count() == 0)
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_DISCONNECTED
            // No timeout for scanning is specified, so only connection attemps can timeout.
        } break;
            // Accept parameters requested by peer.
        } break;
        } break;
/**@brief   Function for handling BLE events from peripheral applications.
 * @details Updates the status LEDs used to report the activity of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("Peripheral connected");
            bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            multi_qwr_conn_handle_assign(p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Peripheral disconnected. conn_handle: 0x%x, reason: 0x%x",
            bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
        } break;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
        } break;
        case BLE_ADV_EVT_IDLE:
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        } break;
/**@brief Function for checking whether a bluetooth stack event is an advertising timeout.
 * @param[in] p_ble_evt Bluetooth stack event.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
    return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    uint16_t role        = ble_conn_state_role(conn_handle);
    // Based on the role this device plays in the connection, dispatch to the right handler.
    if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
        //ble_hrs_on_ble_evt(p_ble_evt, &m_hrs);
       // ble_rscs_on_ble_evt(p_ble_evt, &m_rscs);
    on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
       // ble_hrs_c_on_ble_evt(p_ble_evt, &m_hrs_c);
        //ble_rscs_c_on_ble_evt(p_ble_evt, &m_rscs_c);
        on_ble_central_evt(p_ble_evt);
/**@brief Heart Rate Collector initialization.
/**static void hrs_c_init(void)
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
    err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
/**@brief RSC collector initialization.
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing the Peer Manager.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to
 *                            wake the application up.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, NULL);
/**@brief Function for initializing the GAP.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device, including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    gap_conn_params.min_conn_interval = m_scan.conn_params.min_conn_interval;
    gap_conn_params.max_conn_interval = m_scan.conn_params.max_conn_interval;
    gap_conn_params.slave_latency     = m_scan.conn_params.slave_latency;
    gap_conn_params.conn_sup_timeout  = m_scan.conn_params.conn_sup_timeout;
/**@brief Function for initializing the GATT module.
/**static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
 * @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                         (err_code != NRF_ERROR_NOT_FOUND) )
                index = 0;
        case APP_UART_FIFO_ERROR:
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**void uart_event_handle(app_uart_evt_t * p_event)
    uint32_t       err_code;
            index++;
                do
                index = 0;
/**@brief Function for handling Queued Write module errors.
 * @details A pointer to this function is passed to each service that may need to inform the
 * @param[in]   nrf_error   Error code that contains information about what went wrong.
/**static void nus_data_handler(ble_nus_evt_t * p_evt)
        uint32_t err_code;
            do
/**@brief Function for initializing services that are be used by the application.
 * @details Initialize the Heart Rate, Battery and Device Information services.
  //  ble_hrs_init_t     hrs_init;
   // ble_rscs_init_t    rscs_init;
    uint8_t            body_sensor_location;
 ble_nus_init_t     nus_init;
//ble_nus_init_t   nus_init;
// Initialize NUS.
    // Initialize Queued Write module instances.
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
//nus_init.data_handler = nus_data_handler;
    // Initialize the Heart Rate Service.
   /** body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed or increased.
    hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
    hrs_init.bsl_rd_sec      = SEC_OPEN;
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize the Running Speed and Cadence Service.
    memset(&rscs_init, 0, sizeof(rscs_init));
    rscs_init.evt_handler = NULL;
    rscs_init.feature     = BLE_RSCS_FEATURE_INSTANT_STRIDE_LEN_BIT |
                            BLE_RSCS_FEATURE_WALKING_OR_RUNNING_STATUS_BIT;
    // Here the sec level for the Running Speed and Cadence Service can be changed or increased.
    rscs_init.rsc_feature_rd_sec   = SEC_OPEN;
    rscs_init.rsc_meas_cccd_wr_sec = SEC_OPEN;
    err_code = ble_rscs_init(&m_rscs, &rscs_init);
    APP_ERROR_CHECK(err_code);*/
        uint32_t err_code;
            do
/**@brief Function for initializing the advertising functionality.**/
    ble_advertising_init_t init;
//init.srdata.uuids_complete.uuid_cnt = sizeof(m_sr_uuids) / sizeof(m_sr_uuids[0]);
//init.srdata.uuids_complete.p_uuids = m_sr_uuids;
    init.advdata.name_type               = BLE_ADVDATA_SHORT_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
   // init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
   // init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
   // err_code = ble_advertising_init(&m_advertising, &init);
   // ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
/**static void advertising_init(void)
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    ble_uuid_t adv_uuids[] = {{BLE_UUID_NUS_SERVICE, m_nus.uuid_type}};
    //adv_uuids[0].uuid = BLE_UUID_NUS_SERVICE;
    //adv_uuids[0].type = m_nus.uuid_type;
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance      = false;
    advdata.flags                   = flags;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_set(&advdata, &scanrsp);
/**@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
          then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the application main entry.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timer_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    peer_manager_init();
    //hrs_c_init();
    //rscs_c_init();
    services_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Relay example started.");
 advertising_start();
    if (erase_bonds == true)
        // Scanning and advertising is done upon PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
        adv_scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Thank you
