Bluetooth value reading and writing problem.
I managed to set the UUID section on my own, but I'm having trouble reading and writing some data. I'm changing the on_write function in Ble_nus.c, but I can't get results. Tell me where I'm wrong.
ble_nus.c
 * Copyright (c) 2012 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_NUS)
#include "ble.h"
#include "ble_nus.h"
#include "ble_srv_common.h"
#define NRF_LOG_MODULE_NAME ble_nus
#if BLE_NUS_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       BLE_NUS_CONFIG_LOG_LEVEL
#define NRF_LOG_INFO_COLOR  BLE_NUS_CONFIG_INFO_COLOR
#define NRF_LOG_DEBUG_COLOR BLE_NUS_CONFIG_DEBUG_COLOR
#else // BLE_NUS_CONFIG_LOG_ENABLED
#define NRF_LOG_LEVEL       0
#endif // BLE_NUS_CONFIG_LOG_ENABLED
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
#define BLE_UUID_NUS_TX_CHARACTERISTIC 0x0003               /**< The UUID of the TX Characteristic. */
#define BLE_UUID_NUS_RX_TX_CHARACTERISTIC 0x0002               /**< The UUID of the RX Characteristic. */
#define BLE_NUS_MAX_RX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the RX Characteristic (in bytes). */
#define BLE_NUS_MAX_TX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the TX Characteristic (in bytes). */
#define NUS_BASE_UUID                  {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
/**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the SoftDevice.
 * @param[in] p_nus     Nordic UART Service structure.
 * @param[in] p_ble_evt Pointer to the event received from BLE stack.
static void on_connect(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
    ret_code_t                 err_code;
    ble_nus_evt_t              evt;
    ble_gatts_value_t          gatts_val;
    uint8_t                    cccd_value[2];
    ble_nus_client_context_t * p_client = NULL;
    err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage,
                                 p_ble_evt->evt.gap_evt.conn_handle,
                                 (void *) &p_client);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
                      p_ble_evt->evt.gap_evt.conn_handle);
    /* Check the hosts CCCD value to inform of readiness to send data using the RX characteristic */
    memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
    gatts_val.p_value = cccd_value;
    gatts_val.len     = sizeof(cccd_value);
    gatts_val.offset  = 0;
    err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
                                      p_nus->rx_handles.cccd_handle,
                                      &gatts_val);
    if ((err_code == NRF_SUCCESS)     &&
        (p_nus->data_handler != NULL) &&
        ble_srv_is_notification_enabled(gatts_val.p_value))
        if (p_client != NULL)
            p_client->is_notification_enabled = true;
        memset(&evt, 0, sizeof(ble_nus_evt_t));
        evt.type        = BLE_NUS_EVT_COMM_STARTED;
        evt.p_nus       = p_nus;
        evt.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        evt.p_link_ctx  = p_client;
        p_nus->data_handler(&evt);
/**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the SoftDevice.
static void on_write(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
    ble_nus_evt_t                 evt;
    ble_nus_client_context_t    * p_client;
    ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
                                 p_ble_evt->evt.gatts_evt.conn_handle,
                      p_ble_evt->evt.gatts_evt.conn_handle);
    evt.p_nus       = p_nus;
    evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
    if ((p_evt_write->handle == p_nus->tx_handles.cccd_handle) &&
        (p_evt_write->len == 2))
            if (ble_srv_is_notification_enabled(p_evt_write->data))
                p_client->is_notification_enabled = false;
                evt.type                          = BLE_NUS_EVT_COMM_STOPPED;
            if (p_nus->data_handler != NULL)
		else if((p_evt_write->handle == p_nus->rx_handles.value_handle) &&
						(p_nus->data_handler != NULL))
				evt.type                  = BLE_NUS_EVT_RX_DATA;
        evt.params.rx_data.p_data = p_evt_write->data;
        evt.params.rx_data.length = p_evt_write->len;
        // Do Nothing. This event is not relevant for this service.
/**@brief Function for handling the @ref BLE_GATTS_EVT_HVN_TX_COMPLETE event from the SoftDevice.
static void on_hvx_tx_complete(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
    ble_nus_evt_t              evt;
        return;
    if (p_client->is_notification_enabled)
        evt.type        = BLE_NUS_EVT_TX_RDY;
        evt.p_nus       = p_nus;
void ble_nus_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
    if ((p_context == NULL) || (p_ble_evt == NULL))
        return;
    ble_nus_t * p_nus = (ble_nus_t *)p_context;
        case BLE_GAP_EVT_CONNECTED:
            on_connect(p_nus, p_ble_evt);
        case BLE_GATTS_EVT_WRITE:
            on_write(p_nus, p_ble_evt);
        case BLE_GATTS_EVT_HVN_TX_COMPLETE:
            on_hvx_tx_complete(p_nus, p_ble_evt);
            // No implementation needed.
uint32_t ble_nus_init(ble_nus_t * p_nus, ble_nus_init_t const * p_nus_init)
    ble_uuid_t            ble_uuid;
    ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
    ble_add_char_params_t add_char_params;
    VERIFY_PARAM_NOT_NULL(p_nus);
    VERIFY_PARAM_NOT_NULL(p_nus_init);
    // Initialize the service structure.
    p_nus->data_handler = p_nus_init->data_handler;
    /**@snippet [Adding proprietary Service to the SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_nus->uuid_type;
    ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
    // Add the service.
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_nus->service_handle);
    // Add the RX Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_NUS_RX_TX_CHARACTERISTIC;
    add_char_params.uuid_type                = p_nus->uuid_type;
    add_char_params.max_len                  = BLE_NUS_MAX_RX_CHAR_LEN;
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.read          = 1;
    add_char_params.char_props.write_wo_resp = 1;
		add_char_params.char_props.notify  			 = 1;
    add_char_params.read_access  = SEC_OPEN;
    add_char_params.write_access = SEC_OPEN;
		add_char_params.cccd_write_access = SEC_OPEN;
    return err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles);
    if(err_code!=NRF_SUCCESS)
        return err_code;
    // Add the TX Characteristic.
    return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles);
uint32_t ble_nus_data_send(ble_nus_t * p_nus,
                           uint8_t   * p_data,
                           uint16_t  * p_length,
                           uint16_t    conn_handle)
    ble_gatts_hvx_params_t     hvx_params;
    err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage, conn_handle, (void *) &p_client);
    if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL))
        return NRF_ERROR_NOT_FOUND;
    if (!p_client->is_notification_enabled)
    if (*p_length > BLE_NUS_MAX_DATA_LEN)
        return NRF_ERROR_INVALID_PARAM;
    memset(&hvx_params, 0, sizeof(hvx_params));
    hvx_params.handle = p_nus->tx_handles.value_handle;
    hvx_params.p_data = p_data;
    hvx_params.p_len  = p_length;
    hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
    return sd_ble_gatts_hvx(conn_handle, &hvx_params);
#endif // NRF_MODULE_ENABLED(BLE_NUS)
NORDIC                                                   HM-10
I want to make a UUID like HM-10.
  • Do I understand you correctly? You want to create a single characteristic with the properties NOTIFY, READ, WRITE and WRITE NO RESPONSE?
    Simon
  • Yes, I want to create a UUID that contains exactly NOTIFY, READ, WRITE  and WRITE NO RESPONSE, and send and receive data over this ID.
  • I modified the ble ble_nus_init(..) function in the ble_nus.c library in the following manner:
        add_char_params.uuid                     = BLE_UUID_NUS_RX_CHARACTERISTIC;
        add_char_params.char_props.write         = 1;
        add_char_params.char_props.read         = 1; //Added
        add_char_params.char_props.notify = 1;       //Added
        add_char_params.cccd_write_access = SEC_OPEN; //Added
    • I modified the RX characterstics, but you can change to UUID to whatever you would like
    • Now you are able to read from it and write to it (with and without response)
    • In order to notify the characteristic value to a central device, you need to use the function sd_ble_gatts_hvx(..)
      • Tell me if you want to elaborate more on this function
    • I would recommend you to not modify the ble_nus.c library directly, but instead create a copy (e.g. ble_nus2.c) since you may want to use this library with other projects, then you include the copied library in the Project Explorer window as shown below:
    Simon
