Valgrind check detect pc-ble-driver memory leaks
I have integraded pc-ble-driver (https://github.com/NordicSemiconductor/pc-ble-driver/releases/tag/v4.1.1) on boundary device Nitrogen6x using Yocto.
I have not changed any code from pc-ble-driver and here is the Valgrind log on the example heart rate collector:
root@mydevice:~# valgrind --leak-check=full --show-leak-kinds=all heart_rate_collector_sd_api_v6
==577== Memcheck, a memory error detector
==577== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==577== Using Valgrind-3.14.0 and LibVEX; rerun with -h for copyright info
==577== Command: heart_rate_collector_sd_api_v6
==577==
Serial port used: /dev/ttyACM0
Baud rate used: 1000000
Info: Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
Status: 6, message: Target Reset performed
Status: 7, message: Connection active
Scan started
Received advertisement report with device address: 0x0469F89EA291
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
Scan started
^C==577==
==577== Process terminating with default action of signal 2 (SIGINT)
==577==    at 0x49F06C6: __libc_do_syscall (libc-do-syscall.S:49)
==577==    by 0x4A63A0B: read (read.c:26)
==577==    by 0x4A27E9F: _IO_file_underflow@@GLIBC_2.4 (fileops.c:524)
==577==    by 0x4A28945: _IO_default_uflow (genops.c:362)
==577==    by 0x4A24A23: getc (getc.c:40)
==577==    by 0x10D355: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== HEAP SUMMARY:
==577==     in use at exit: 6,396 bytes in 73 blocks
==577==   total heap usage: 2,733 allocs, 2,660 frees, 289,256 bytes allocated
==577==
==577== 4 bytes in 1 blocks are still reachable in loss record 1 of 72
==577==    at 0x483E970: malloc (vg_replace_malloc.c:299)
==577==    by 0x110079: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 4 bytes in 1 blocks are still reachable in loss record 2 of 72
==577==    at 0x483F158: operator new(unsigned int) (vg_replace_malloc.c:328)
==577==    by 0x122DD3: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 4 bytes in 1 blocks are definitely lost in loss record 3 of 72
==577==    by 0x10FF97: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 4 bytes in 1 blocks are definitely lost in loss record 4 of 72
==577==    by 0x11000B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 4 bytes in 1 blocks are definitely lost in loss record 5 of 72
==577==    by 0x110043: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 6 of 72
==577==    by 0x11B4E9: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 7 of 72
==577==    by 0x11B561: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 8 of 72
==577==    by 0x11B5D5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 9 of 72
==577==    by 0x11B649: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 10 of 72
==577==    by 0x11B6BD: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 11 of 72
==577==    by 0x116C1D: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 12 of 72
==577==    by 0x122465: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 13 of 72
==577==    by 0x122671: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 14 of 72
==577==    by 0x122DDF: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 8 bytes in 1 blocks are still reachable in loss record 15 of 72
==577==    by 0x11E043: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 16 of 72
==577==    by 0x13418B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11DECF: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 17 of 72
==577==    by 0x1341DF: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11DF1F: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 18 of 72
==577==    by 0x134233: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11DF73: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 19 of 72
==577==    by 0x11FA55: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 20 of 72
==577==    by 0x11F44B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11FAA5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 21 of 72
==577==    by 0x11BCD3: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 22 of 72
==577==    by 0x11BD55: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 23 of 72
==577==    by 0x11C387: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 24 of 72
==577==    by 0x11C3DB: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 25 of 72
==577==    by 0x122D09: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 26 of 72
==577==    by 0x122D85: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 12 bytes in 1 blocks are still reachable in loss record 27 of 72
==577==    by 0x123AB7: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x1262A5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 28 of 72
==577==    by 0x11E2E3: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 29 of 72
==577==    by 0x11B505: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 30 of 72
==577==    by 0x11B579: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 31 of 72
==577==    by 0x11B5ED: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 32 of 72
==577==    by 0x11B661: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 33 of 72
==577==    by 0x11B6D5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 16 bytes in 1 blocks are still reachable in loss record 34 of 72
==577==    by 0x122603: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 24 bytes in 1 blocks are still reachable in loss record 35 of 72
==577==    by 0x136B09: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 24 bytes in 2 blocks are still reachable in loss record 36 of 72
==577==    by 0x11FAF1: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 37 of 72
==577==    by 0x11DA39: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11DAF1: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x11B4E1: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 38 of 72
==577==    by 0x11B559: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 39 of 72
==577==    by 0x11B5CD: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 40 of 72
==577==    by 0x11B641: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 41 of 72
==577==    by 0x11B6B5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 28 bytes in 1 blocks are still reachable in loss record 42 of 72
==577==    by 0x1368BD: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x136649: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x10D27B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 32 bytes in 1 blocks are still reachable in loss record 43 of 72
==577==    by 0x1205FB: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 32 bytes in 1 blocks are still reachable in loss record 44 of 72
==577==    by 0x11E27D: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 33 bytes in 1 blocks are still reachable in loss record 45 of 72
==577==    by 0x1263F9: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==    by 0x121C51: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 33 bytes in 1 blocks are still reachable in loss record 46 of 72
==577==    by 0x119545: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 47 of 72
==577==    by 0x11B8B5: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 48 of 72
==577==    by 0x11B8EF: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 49 of 72
==577==    by 0x11B877: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 50 of 72
==577==    by 0x11B837: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 51 of 72
==577==    by 0x11B7F7: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 52 of 72
==577==    by 0x11B7B7: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 53 of 72
==577==    by 0x11B777: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 54 of 72
==577==    by 0x11B739: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 36 bytes in 1 blocks are still reachable in loss record 55 of 72
==577==    by 0x12246D: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 44 bytes in 1 blocks are still reachable in loss record 56 of 72
==577==    by 0x1260A3: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 48 bytes in 1 blocks are still reachable in loss record 57 of 72
==577==    by 0x110083: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 57 bytes in 1 blocks are still reachable in loss record 58 of 72
==577==    by 0x121839: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 77 bytes in 1 blocks are still reachable in loss record 59 of 72
==577==    by 0x121E3F: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 92 bytes in 1 blocks are still reachable in loss record 60 of 72
==577==    by 0x123503: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 120 bytes in 1 blocks are still reachable in loss record 61 of 72
==577==    by 0x126147: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 152 bytes in 1 blocks are possibly lost in loss record 62 of 72
==577==    at 0x4841590: calloc (vg_replace_malloc.c:752)
==577==    by 0x400C9B5: allocate_dtv (dl-tls.c:286)
==577==    by 0x400CFFB: _dl_allocate_tls (dl-tls.c:532)
==577==    by 0x486048D: allocate_stack (allocatestack.c:621)
==577==    by 0x486048D: pthread_create@@GLIBC_2.4 (pthread_create.c:669)
==577==    by 0x49333FF: std::thread::_M_start_thread(std::unique_ptr<std::thread::_State, std::default_delete<std::thread::_State> >, void (*)()) (in /usr/lib/libstdc++.so.6.0.25)
==577==    by 0x116C35: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 152 bytes in 1 blocks are possibly lost in loss record 63 of 72
==577==    by 0x122DFF: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 152 bytes in 1 blocks are possibly lost in loss record 64 of 72
==577==    by 0x11E05B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 160 bytes in 1 blocks are still reachable in loss record 65 of 72
==577==    by 0x122495: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 336 bytes in 1 blocks are still reachable in loss record 66 of 72
==577==    by 0x11004F: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 420 bytes in 1 blocks are still reachable in loss record 67 of 72
==577==    by 0x136653: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 496 bytes in 1 blocks are still reachable in loss record 68 of 72
==577==    by 0x110017: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 504 bytes in 1 blocks are still reachable in loss record 69 of 72
==577==    by 0x11E297: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 512 bytes in 1 blocks are still reachable in loss record 70 of 72
==577==    by 0x12685F: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 768 bytes in 1 blocks are still reachable in loss record 71 of 72
==577==    by 0x136B2B: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== 1,280 bytes in 1 blocks are still reachable in loss record 72 of 72
==577==    by 0x10FFCB: ??? (in /usr/bin/heart_rate_collector_sd_api_v6)
==577==
==577== LEAK SUMMARY:
==577==    definitely lost: 12 bytes in 3 blocks
==577==    indirectly lost: 0 bytes in 0 blocks
==577==      possibly lost: 456 bytes in 3 blocks
==577==    still reachable: 5,928 bytes in 67 blocks
==577==         suppressed: 0 bytes in 0 blocks
==577==
==577== For counts of detected and suppressed errors, rerun with: -v
==577== ERROR SUMMARY: 6 errors from 6 contexts (suppressed: 0 from 0)
Please have a check.
BR/Chencheng
