DFU in Experimental: ATT_MTU Throughput Example
I'd like to develop and base on the "Experimental: ATT_MTU Throughput Example" project.
Seems like the example project doesn't implement the DFU (aka, OAD).
How can I add this feature to the project easily? Do you have an example for that? Would you evaluate it as "risky" / "complicated"?
Thanks in advanced,
Amit
  • Hello Amit,
    You are correct. The throughput example from the SDK doesn't have DFU implemented. In fact, this example is not really made to build on, but meant as a demo to see how much a link can transfer using different connection parameters. I would actually recommend to not start with this example as a starting point for your application.
    If you haven't seen it already, I would recommend this guide which describes how to get started with DFU.
    So you first need a bootloader, and then you need a way to tell the bootloader to enter DFU mode. Typically, this is either by holding a specific button on startup, or to have a BLE service to trigger DFU mode. Which one do you see fit for your application?
    Edvin
  • The final result we're aiming for is to have a Central with BLE DFU.
    1. We wanted to use a peripheral_central example project in order to achieve that, and add the DFU functionality to it. Unfortunately all the peripheral_central projects are labeled as "experimental". Is one of those experimental examples more reliable and stable than other?
    2. Another option is maybe base on a peripheral with BLE DFU project and add the Central functionalities. Could we base on the Peripheral project example:  BLE Secure DFU example and add the Central role to it?
     Amit
  • What SDK version are you using?
    I think you should read through the guide that I linked to in the previous reply, to get an overview of how the bootloader works.
     What way do you intend to use to trigger DFU mode? A button or do you want to trigger it over BLE?
    What do you intend to send the actual update from (this is called a DFU master)? A Mobile phone? Or is the plan to connect it via something to a computer and use a serial interface?
  • - SDK version: nRF5SDK153059ac345
    - I want to update a fw version using BLE, (and in the future maybe using a cellular 4G connection)
    ... So I understand it is not possible to add the central role to an existing peripheral-with-DFU example project?
  • 1: Let me try again. How do you want to trigger the DFU mode? Do you understand what I mean by this?
    The reason I stress this question is that if you want to trigger this with a button press, you don't need to worry about this. It is already built into the bootloader. If your product doesn't have any buttons, you can use a BLE service to trigger DFU mode. Note that "trigger DFU mode" is not the same as "performing DFU update".
    2: Did you read through the guide that I linked to?
    3: The bootloader is a separate small application that is running on startup. Whenever you trigger DFU mode, the bootloader will not start the already present application but starts advertising (as a peripheral) as a DFU target. Then you have to connect to the bootloader via BLE. Now the bootloader is a peripheral, and the DFU master (the other part wich is sending the update) is the central. You don't need to change this.
    4: Please go through the guide. When you are done with the guide, please try the ble_app_buttonless example from ble_peripheral folder. I know that this is a peripheral, but you need to understand how this example works, and how it triggers DFU mode from the BLE service: buttonless DFU service.
